  1. Past hour
  2. Hi @Oliver_74, You can import patches (without other show file data such as memories) via Setup -> Load -> Select File -> 'Setup Only' or 'Setup & Palettes', which will load the console's setup (including patch, defaults, settings etc.), and palettes if specified. Be aware that when loading files, it clears the previous show file on the desk, so make sure to create a backup. You could create some 'sample' patch files by setting the patch up, and saving that file. Then, once you load one of those files, you can start programming straight away with your patch loaded in from a 'sample' file you created. If you select 'Load Complete Show', it will load all data contained within that show file. If you mean that you want to import a specific part of the patch into another show file's patch, this is unfortunately not possible. Hope this helps.
  3. Today
  4. Hi, I had a few colour leds patched pairwise, now each of those has it’s own chnl nr / dmx adress… Since I work in a small theatre, where a lot of acts perform often, i have to change the patch in each existing show… is there a way to import a patch? thanks Oliver
  5. Last week
  6. These have just appeared on a recycled web site FLX 4096 Controller AUD$4,290.00. They say they have 10+
  7. Earlier
  8. @kgallen Thank you. I shall give that a try now we are back after the summer break.
  9. I'll take a look at everything that was said, and probably come back to report. Thanks for the help!
  10. Is it CSC you are thinking of That would be it! Thank-you.
  11. Is it CSC you are thinking of? (https://www.ctrelectronics.co.uk/csc-show-control.php)
  12. That is indeed an option, can't afford either a Mac or Cuelab myself though. I'll be taking a look at Miltiplay though and there is another Windows program but the name escapes me just now.
  13. OSC is really useful from my perspective for when you just want to run your show off one main control centre, but not having lights + sound (and possibly projection) all programmed in on a singular machine. If that one machine goes down, you've lost all lights, all sound and all projection. Whereas, if you run lights separately with the computer controlling sound and projection, while a lighting console is controlling LX separately, if the main computer goes down then you still have light on stage and can control that independently. Something like this can be done with OSC via QLab (with Network Messages) however QLab does require a license for this, or using something like Multiplay (another sound + projection cue-based tool) as @Neil Macmillan has used, is another option that is free to use (but still very very good!). So, if you are looking for a cue-based solution and you use a Mac, QLab is probably the best option (you could have a "magic sheet" as @Davidmk has, using Cue Carts within QLab). These "cue carts" can fire Network Messages over OSC to trigger certain cues on the LX console, like a soundboard but for lights. However, if you use Windows, Multiplay is also a good option (not sure about cue carts on it though). If you're on a Mac and instead of using QLab, you want to use Multiplay, you could run it via Wine but this won't run natively on your Mac and I'm not sure if OSC would work with how Wine handles things, but it could be worth a try. Unfortunately QLab on Windows isn't an option as it is developed primarily on the Apple platform, and so relies on Apple infrastructure for features such as AppleScript integration. QLab Network Message Cues - https://qlab.app/docs/v5/networking/network-cues/ QLab Cue Carts - https://qlab.app/docs/v4/general/cue-carts/ If you do use Multiplay, I very much point you to Neil's video! (I used it myself when having a play with OSC over Multiplay to my Phantom ZerOS setup, so thank you very much Neil for making that video). Best of luck with what you want to do with OSC.
  14. Good stuff. In my world it's mostly busking so I'm using TouchOSC to give me a "magic sheet" where I can select colours, positions, effects, whatever by touching a button. The buttons fire specific cues in cue stacks. For example, I might have a stack with cues to set colour (and only colour) on some wash lights. Each cue has a 2s fade time. The buttons each trigger one of these cues and, because it is a cue stacks, I get the fade and the old colour gets faded out. I also have a button that releases the stack so, for example, I can release the effects stack when I'm done with it.
  15. My post on the topic of OSC use with the Zero88 FLX S24 may be of interest. All free software and might give you a start in understanding the process.
  16. So, OSC requires the desk to be networked with some device (& software) that can send OSC commands. The available commands are detailed in the manual at https://www.zero88.com/manuals/zeros/setup/triggers/osc. These let the external device/software trigger certain actions on the desk, for example playing a cue on a playback. The desk cannot send OSC and therfore cannot provide feedback to the sending device. Networking the desk and the sending device need not be complex. Connecting both to a normal domestic router would be sufficient but note that the router must NOT be connected to the Internet. Some routers can get a bit funny without an Internet connection What you use to send the OSC commands is up to you but a popular piece of software is TouchOSC by Hexler. There are two versions of this. The original version (Mk1) allows you to define a control surface with (among other things) buttons, sliders and rotary controls. This version is free but is not as flexible as the new version. The new version can be used like the original one but has more features including a scripting language with which you can achieve quite complex results but, for access to this you will need to get a licence. There is a very reasonable, one off, fee for the licence. I don't think OSC can receive inputs from game controllers but check this out for yourself on the Hexler website. TouchOSC can be run on Windows, Android, Linux, iOS and macOS. More information can be obtained from the Hexler website https://hexler.net/touchosc Other software is available, all you need is to be able to send OSC commands as defined in the ZeroOS manual but I have no first hand knowledge of what is available and its suitability. Hope this is helpful in getting you started.
  17. Good Evening to all, I've recently seen some stuff about OSC and how it can be used (not particularly on ZerOS) for variety of actions for example remote controllers like Gamepads or types of decks like streamdecks. It's not that I have a special occasion or need for it, but I was curious about it and how it can work on the flx s24 deck. The only thing I've seen is software like Companion for Streamdecks or TouchOSC for other things but I don't really know how I would go on from there. And yea just for the fun of it, is it possible to use game controllers as light controllers through OSC? Any helpful websites or guides I can check out there (that maybe don't require too much knowledge of networking beforehand (I'm working on that tho)) Thanks if anyone got something Jan
  18. --Rewritten for clarity-- Thank you, I do look forward to the news of this, apologies that I was no use of advice. My issue, with the help of others, was thought to be a section of a ribbon cable had come partially disconnected or loose, not allowing data to come through fully to the LCDs.. if not at all while still being back-lit. Not sure if that is the case or not but we shall hopefully find out, I still have yet to open my Jester ML yet again to find the issue.. been a bit busy over the holidays! Issue hasn't happened in some time though, still keeping an eye out for it.
  19. @kgallen sort of agree, in theory. Less convinced in practice. Got to open it up to replace a fader - let you know what I find. Ian Knight, you are sorely missed.
  20. @Davidmk unless the desk is continually rebooting due to intermittent power I doubt such a fault would only affect the LCDs. Happy to be proven wrong!
  21. @Archie D @kgallen Having acquired a Jester ML24 I've had this sort of problem. Not exactly the same but involving litvup but blank LCDs. It's like the ML end of the desk has hung. I've noticed that the 4pin XLR power connection isn't very positive and I think, maybe, the screen issue is connected to disturbances of the power cable. New 4pin XLRs on order but what do you think, will replacing the power connection help with my intermittent issue?
  22. That is true.. I received a Juggler which had no PSU so I was stuck with the single one from the JesterML I have.
  23. Yes, but all too often the cheapest old desks are missing their PSUs and it would have to be pretty bad to be cheaper than a PSU in any case.
  24. There was one on eBay a few weeks ago with a flight case, I think it has gone though. To get a genuine power supply, it could be a possibility to buy or search for a really really beaten up old desk, use that power supply and either grab spares from that desk/try to restore it?
  25. I'm researching Jester MLs at the moment (I'm buying one). Looks to me like all the Frogs & Jesters used the same PSU (5537500 42w 4 pin XLR PSU). Haven't found a genuine Zero88 one in the UK yet but there's a french site saying they have stock. Some versions of replacement ones have an earthing difference that can result in "DMX flutter".
  26. Not sure what you could do with this or whether it's any help, but here is the original supplier and model of switching power supply that Zero 88 used for their desks. https://sinpro.com/en/product/show.aspx?num=441&find1=8 https://sinpro.com/en/product/pro_search_show.aspx?num=441&page=2&spcnum=4955
  27. I seem to recall that the manual we had for the fat frog we used to have in our venue said a PC (old style, desktop) with the right connector on could be used as a substitute. Check the manual, see if I'm right and, if I am, it's only a matter of obtaining one (out of a scrap PC maybe), cutting off the connectors and soldering on a 4 pin XLR Alternatively, Ultralight sound might have an original or replacement.
  28. If you have no luck elsewhere, it's probably worth posting on the Blue Room too as there will be a lot of these desks (and the others I list) out in the wild. https://www.blue-room.org.uk/forum/2-lighting/
  29. Yes, that's correct it was Ian's post. Hopefully there may be someone out there with some info on this.
