One option for editing show cues to create a new show, is to select Save and type a new file name in the show file box. You can then copy a Playback Copy Playbacks into another Playback to edit, while keeping the original playback cues unchanged. You can then copy multiple cues as described by Edward in this post Copying Multiple Cues. I have copied blocks of files using the Copy in Z Key to make up a new set of cues, using an external keyboard to select ranges of cues, then did a Renumber in the new Playback. On FLX S, the renumber function is for 1:1 renumbering, unless you have a USB keyboard connected. You can add new cues to the Playback using Record > Z Key> type in cue number, then press Playback flash key. You cannot copy a block of cues from one Playback to another, but you can copy one cue at a time from one Playback into another Playback Copy Playbacks .
Easy Way to import patch @ existing shows
Hi Oliver, Yes, when loading show files in any capacity, show data is removed from the console's memory and replaced with the contents of the requested file to load. I'm not sure of a way to import a patch into an existing show file without this happening, I don't think it is possible, unfortunately. An alternate method, however - you could note down each patch configuration in a spreadsheet, and when the time comes, edit the existing patch in the desk to align with your spreadsheet data. Additionally, if you're not already aware, you are able to edit show files using the PC emulator, Phantom ZerOS. This will allow you to load a show file into Phantom ZerOS, in your case - edit the patch, re-save onto USB and load back into the physical desk when you are at the venue. This can be a massive save on time for when you don't have access to the physical desk, helping with your swap-overs. Regards. -
Oliver_74 started following Easy Way to import patch @ existing shows
Hi Archie, thanks for your answer. unfortunately this clears all Cues/Playbacks…so it’s not the right way for me to modify existing shows 😉 -
Hi, I had a few colour leds patched pairwise, now each of those has it’s own chnl nr / dmx adress… Since I work in a small theatre, where a lot of acts perform often, i have to change the patch in each existing show… is there a way to import a patch? thanks Oliver
These have just appeared on a recycled web site FLX 4096 Controller AUD$4,290.00. They say they have 10+
I'll take a look at everything that was said, and probably come back to report. Thanks for the help!
Is it CSC you are thinking of That would be it! Thank-you.
Is it CSC you are thinking of? (https://www.ctrelectronics.co.uk/csc-show-control.php)
That is indeed an option, can't afford either a Mac or Cuelab myself though. I'll be taking a look at Miltiplay though and there is another Windows program but the name escapes me just now.
OSC is really useful from my perspective for when you just want to run your show off one main control centre, but not having lights + sound (and possibly projection) all programmed in on a singular machine. If that one machine goes down, you've lost all lights, all sound and all projection. Whereas, if you run lights separately with the computer controlling sound and projection, while a lighting console is controlling LX separately, if the main computer goes down then you still have light on stage and can control that independently. Something like this can be done with OSC via QLab (with Network Messages) however QLab does require a license for this, or using something like Multiplay (another sound + projection cue-based tool) as @Neil Macmillan has used, is another option that is free to use (but still very very good!). So, if you are looking for a cue-based solution and you use a Mac, QLab is probably the best option (you could have a "magic sheet" as @Davidmk has, using Cue Carts within QLab). These "cue carts" can fire Network Messages over OSC to trigger certain cues on the LX console, like a soundboard but for lights. However, if you use Windows, Multiplay is also a good option (not sure about cue carts on it though). If you're on a Mac and instead of using QLab, you want to use Multiplay, you could run it via Wine but this won't run natively on your Mac and I'm not sure if OSC would work with how Wine handles things, but it could be worth a try. Unfortunately QLab on Windows isn't an option as it is developed primarily on the Apple platform, and so relies on Apple infrastructure for features such as AppleScript integration. QLab Network Message Cues - https://qlab.app/docs/v5/networking/network-cues/ QLab Cue Carts - https://qlab.app/docs/v4/general/cue-carts/ If you do use Multiplay, I very much point you to Neil's video! (I used it myself when having a play with OSC over Multiplay to my Phantom ZerOS setup, so thank you very much Neil for making that video). Best of luck with what you want to do with OSC.
Good stuff. In my world it's mostly busking so I'm using TouchOSC to give me a "magic sheet" where I can select colours, positions, effects, whatever by touching a button. The buttons fire specific cues in cue stacks. For example, I might have a stack with cues to set colour (and only colour) on some wash lights. Each cue has a 2s fade time. The buttons each trigger one of these cues and, because it is a cue stacks, I get the fade and the old colour gets faded out. I also have a button that releases the stack so, for example, I can release the effects stack when I'm done with it.
Neil Macmillan started following OSC usage
My post on the topic of OSC use with the Zero88 FLX S24 may be of interest. All free software and might give you a start in understanding the process.
Davidmk started following JesterML LCDs blank [still backlit] and MFK lcd top row malformed and OSC usage
So, OSC requires the desk to be networked with some device (& software) that can send OSC commands. The available commands are detailed in the manual at https://www.zero88.com/manuals/zeros/setup/triggers/osc. These let the external device/software trigger certain actions on the desk, for example playing a cue on a playback. The desk cannot send OSC and therfore cannot provide feedback to the sending device. Networking the desk and the sending device need not be complex. Connecting both to a normal domestic router would be sufficient but note that the router must NOT be connected to the Internet. Some routers can get a bit funny without an Internet connection What you use to send the OSC commands is up to you but a popular piece of software is TouchOSC by Hexler. There are two versions of this. The original version (Mk1) allows you to define a control surface with (among other things) buttons, sliders and rotary controls. This version is free but is not as flexible as the new version. The new version can be used like the original one but has more features including a scripting language with which you can achieve quite complex results but, for access to this you will need to get a licence. There is a very reasonable, one off, fee for the licence. I don't think OSC can receive inputs from game controllers but check this out for yourself on the Hexler website. TouchOSC can be run on Windows, Android, Linux, iOS and macOS. More information can be obtained from the Hexler website https://hexler.net/touchosc Other software is available, all you need is to be able to send OSC commands as defined in the ZeroOS manual but I have no first hand knowledge of what is available and its suitability. Hope this is helpful in getting you started.
Good Evening to all, I've recently seen some stuff about OSC and how it can be used (not particularly on ZerOS) for variety of actions for example remote controllers like Gamepads or types of decks like streamdecks. It's not that I have a special occasion or need for it, but I was curious about it and how it can work on the flx s24 deck. The only thing I've seen is software like Companion for Streamdecks or TouchOSC for other things but I don't really know how I would go on from there. And yea just for the fun of it, is it possible to use game controllers as light controllers through OSC? Any helpful websites or guides I can check out there (that maybe don't require too much knowledge of networking beforehand (I'm working on that tho)) Thanks if anyone got something Jan
--Rewritten for clarity-- Thank you, I do look forward to the news of this, apologies that I was no use of advice. My issue, with the help of others, was thought to be a section of a ribbon cable had come partially disconnected or loose, not allowing data to come through fully to the LCDs.. if not at all while still being back-lit. Not sure if that is the case or not but we shall hopefully find out, I still have yet to open my Jester ML yet again to find the issue.. been a bit busy over the holidays! Issue hasn't happened in some time though, still keeping an eye out for it. -
