	  Control fixtures Intensity & Colour via a custom ProgramMD1125 replied to MD1125's topic in FLX S24 & FLX S48 Well yeah, under 2.3 of the Monitor EULA it states: "Licensee will not, nor will it permit others to, modify, adapt, translate, reverse engineer, decompile, or disassemble the Software or any component thereof (including the Documentation), or create derivative works based on the Software (including the Documentation), except to the extent such foregoing restriction is prohibited by applicable law." and under 5.12: "Licensee acknowledges that confidential aspects of the Software (including any proprietary source code) are a trade secret of Cooper Lighting Solutions UK Ltd., the disclosure of which would cause substantial harm to Cooper Lighting Solutions UK Ltd. that could not be remedied by the payment of damages alone. Accordingly, Cooper Lighting Solutions UK Ltd. will be entitled to preliminary and permanent injunctive and other equitable relief for any breach of this Section 5.12." In this case for example, sharing where this is: Would be allowed, because it kinda falls under intended use, but I think sharing real source code or "trade secrets" wouldn't.
	Control fixtures Intensity & Colour via a custom ProgramDavidmk replied to MD1125's topic in FLX S24 & FLX S48 Based on a non-scientific appraisal of forum comments, I think you'd make yourselves very popular with the community (but probably not with official support) if you found a way to extract the patch from a show file. Something that could be loaded in a spreadsheet would be good. (I have a feeling that there is a prohibition on reverse engineering the software though)
	  Control fixtures Intensity & Colour via a custom ProgramArchie D replied to MD1125's topic in FLX S24 & FLX S48 I mean.. not to lead too far away from the post's original topic with my message below, but if we're on the topic of analysing ZerOS... relatively recently I loaded ZerOS up and had a play around. I'm not sure if it has been discussed before, but I discovered that ZerOS used to have (or still has - I just cannot seem to find it) a partial theme editor for the external monitor's UI appearance.. in newer versions it seems to have disappeared though. This was on ZerOS version 7.8.2.39, so that software version was released just nearing the end of 2016 and was the last available one for Frog 2. I also found a "Testbed" window, which was most definitely for development purposes of displaying cells, buttons, tickboxes, dropdowns, and other UI elements that need to be presented by the software. Below, I've attached three screenshots that I took today to show here. The first two relate to the "Display Palette Editor" (theme editor, one screenshot is the default view and the other is when I'd edited some colours such as the background to be green and button text to be pink) and "Testbed" for UI elements. P.S. admins - I apologise if sharing this isn't allowed for development reasons, please delete my post if that is the case Safety notice - if you somehow find this on your console (I won't say how I got these windows, to prevent any misuse of it or people potentially making mistakes) - I definitely don't recommend changing any values at all, because when resetting the desk, it won't reset these values.
	Control fixtures Intensity & Colour via a custom ProgramDavidmk replied to MD1125's topic in FLX S24 & FLX S48 @Archie D @MD1125 You are out of my experience here. Nearest I've been was programming PDP11s 50yrs ago. No desire to return to that level of detail
	  Control fixtures Intensity & Colour via a custom ProgramArchie D replied to MD1125's topic in FLX S24 & FLX S48 @MD1125, thank you very much for sharing and outlining this. Analysing network traffic.. I wouldn't have figured that out straight off! That's really interesting to see how ZerOS handles inputs from the mobile apps. I recognise the Z88R part of the string - presumably meaning "Zero 88 Remote". When I opened some of the obfuscated files that ZerOS contains (built on a linux system), most begin with "Z88C" from what I remember, presumably meaning "Zero 88 Console", so I can see the links starting to form...
	  Control fixtures Intensity & Colour via a custom ProgramMD1125 replied to MD1125's topic in FLX S24 & FLX S48 I was just in general interested in how all of it works I guess. No direct purpose, just pure interest. Oh and regarding the theoretical direct string input: I was actually able, after some playing around, to fully emulate the traffic between the Monitor and FLX S24 by opening my own TCP connection to the FLX and then send the same strings it does from the Monitor App. From what I've looked at in the traffic it first sends a string to initialize, then one carrying the Password, and then you have (in theory) full control over the Keyboard. By sending these strings: "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 00 0a 00 00 00 00 00 00 00", "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 03 61 00 00 00 00 00 00 00", "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 01 0a 00 00 00 00 00 00 00", You can emulate you typing an "@" on your keyboard, same goes for any other keys you might press, so by expanding this system you could (theoretically) make your own API I guess, just not directly for colour, although that would also work if you kinda pre-record where the mouse has to press. And as far as "debugging" these strings goes, they seem to be actually rather structured, example: First string for @ -> "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 00 0a 00 00 00 00 00 00 00" Z 8 8 R D k e y Presumably key data "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 03 61 00 00 00 00 00 00 00"
	Control fixtures Intensity & Colour via a custom ProgramDavidmk replied to MD1125's topic in FLX S24 & FLX S48 @Archie D I'm not sure what the level of control @MD1125 described is for. It would be easier to get a long DMX cable and move the desk. I use OSC to get quick access to colours, positions, effects and other stuff when I'm busking. I record what I might want as cues in playbacks and send a go PB/cue by OSC from a screen next to the desk. I don't use it when programming the show file in the first place.
	  Control fixtures Intensity & Colour via a custom ProgramArchie D replied to MD1125's topic in FLX S24 & FLX S48 Ah, @Davidmk, I do apologise for posting over your post, the forum page didn't update for me showing your post when you posted it while I was writing mine. Archie
	  Control fixtures Intensity & Colour via a custom ProgramArchie D replied to MD1125's topic in FLX S24 & FLX S48 Hello @MD1125, Welcome to the Zero 88 forum. Yes, this is correct. The ZerOS Monitor and Remote apps rely directly on the console, therefore all processing when performing actions on the remote apps is done on the console itself, and rather not your own device apart from sending the x and y coordinates like you say. I believe this unfortunately won't be directly possible, as ZerOS only accepts communication to the console via the methods @kgallen outlined regarding MIDI and OSC, however the FLX S is unable to use MIDI as it doesn't have a physical port. This is correct as well, however I am going to highlight 'Macros' as a part of this. There are two types of Macros within ZerOS. Fixture Macros, and User Macros. Fixture Macros are available on the FLX S, but User Macros aren't. On the other hand, if you did have access to User Macros for example on a full size FLX (max 240 macros) or a Solution (max 400 macros), you could theoretically: Record -> Tap 'Macro' -> Select a macro to record to -> Keys -> Type the syntax commands you would like (Keys will also record presses such as 'Home') -> Tap 'Macro' again to stop recording -> Tap 'Clear' to clear the syntax line. If you use Solution for this, you need to instead tap the Macro's MFK to stop recording I think. Doing this is of course rather painful, and will only let you control specific fixtures at specific levels you have already programmed into the console, and if using the full size FLX it will eat into your macro count relatively quickly (max 240) depending on how you use this, but it will allow you to control the macro you have just programmed via the OSC protocol, which you could use in your own codebase as you wish to control the intensity levels of specific fixtures. For example, if I then programmed a macro via the following: Record -> Macro -> Macro 1 -> Keys -> '1 thru 10 Home' -> Macro I could then execute that exact combination of key presses on the console by firing a command over the OSC protocol: /zeros/macro/1 (if I recorded it as Macro 1). You could record singular colours using Macros as well. I am aware that you are on the FLX S, and that this unfortunately won't be possible for your console regarding User Macros, but I thought I would take the chance to share this information in case it is of use for the future for you (who knows...). It definitely isn't the best way of doing things, but it is a little workaround that I found to partially work. So, in answer to your question, you could fire 1 enter @100 enter, but just not on the FLX S.
	Davidmk started following Control fixtures Intensity & Colour via a custom Program
	Control fixtures Intensity & Colour via a custom ProgramDavidmk replied to MD1125's topic in FLX S24 & FLX S48 What do you actually want to achieve with this? Not in terms of what you would do if you were at the desk, more in terms of what it looks like on stage.
	  Control fixtures Intensity & Colour via a custom Programkgallen replied to MD1125's topic in FLX S24 & FLX S48 I believe you’re correct. I think MIDI and OSC can only trigger pre programmed cues. Others will know better than me though.
	  Control fixtures Intensity & Colour via a custom ProgramMD1125 replied to MD1125's topic in FLX S24 & FLX S48 Well the problem with OSC is, from the commands provided in this documentation file it appears to me as if it can only receive these: Cues Playbacks Macros, Grandmaster & Blackout It could be that I just overlooked the file but on the FLX S24 OSC does not seem to have individual colour control that is not pre-programmed
	kgallen started following Control fixtures Intensity & Colour via a custom Program
	  Control fixtures Intensity & Colour via a custom Programkgallen replied to MD1125's topic in FLX S24 & FLX S48 OSC or MIDI would be the usual remote control methods. Others on here have experience of these and will no doubt be along shortly (I have no experience of using them). You could search the Forum for OSC, there are quite a few detailed threads. User @Davidmk has a lot of OSC experience so you could look at posts by him in the FLX/FLX-S and Solution forums. examples:
	MD1125 changed their profile photo
	MD1125 started following Control fixtures Intensity & Colour via a custom Program
	Hi, I was just in general interested how the whole ZerOS and the remote apps etc. work together and wether I could remotely for example via my own "code" send data / packets to change colours, intensity etc. So I looked into that a bit but I was wondering if there is a easier method to do so. I thought maybe the Monitor App has an easy API to reverse Engineer but from what I’ve observed when inspecting network traffic between the ZerOS Monitor App and the FLX: The Monitor app doesn’t appear to have it's own UI, as it's just displaying the raw image stream sent from the console (please correct me if I’m mistaken). The FLX sends this UI as raw image data, and in return, the app sends mouse coordinates (x, y) and state changes (down, up, move) back to the console, which then updates the display. In theory, it looks like I could send raw hex strings (e.g. "1 enter @100 enter") but I really hope theres an easier way I overlooked. So my main question is: Is there an easier or officially supported way to remotely control the FLX (S24) to change colours or intensity via the standard DMX universe — ideally by sending packets directly over Ethernet from custom code? I’ve checked out a few options, but they don’t seem to fit: Triggers: Only seem to fire cues/playbacks, not direct channel control. KiNET: Doesn’t appear compatible with my setup. Philips Hue: Works only with Hue devices, as far as I can tell. Any advice or insight would be really appreciated! Thanks in advance!
	How reliable is "Revert rig back" in RigSync?Charlie Newman replied to delicolor's topic in FLX S24 & FLX S48 No problem, good luck!
	Davidmk started following FLX: Command Line Text Goes Red and Changes won't save! and Force software update
	Sounds like you might have a corrupt show file. I've had these sorted out by support in the (pre Vari-Lite) past. Might be worth asking them if they can check it for you.
	There is a sort of backspace key (<-) on the keypad that removes the last thing in the command line which you can use to remove things until it stops being red. A common hiccup is pressing one of the colour/beam/shape/position/effect keys which makes it think its going to get a pallette number next and then entering something that's not a pallette number. Done that a few times, never quite sure exactly where I went wrong.
	  How reliable is "Revert rig back" in RigSync?delicolor replied to delicolor's topic in FLX S24 & FLX S48 There is a ladder to a high perch where I should be able to see what make/model the nearest wash is and they are probably all the same. I'll see if the tester can sniff out the RDM and failing that work it out the hard way. Thanks for your comment though!
	It had been set to flash, rather than Go(Fade). I will set back after current show is finished. We have been running the show on one of the sub-masters which works fine. Thanks for the hint.
	FLX: Command Line Text Goes Red and Changes won't save!Charlie Newman replied to MikeF's topic in FLX Usually the command line goes red if you've entered invalid syntax, or tried to exceed the allowed parameters. Is something similar happening when you try to save and/or record? Have you attempted to hit "Clear" only once before saving so the command line is empty? Hope these help!
	MikeF started following FLX: Command Line Text Goes Red and Changes won't save!
	Hi I've been using our FLX for 3 years now in our small rural theatre. We have live bands, plays, panto, dance shows, comedians - a wide variety of shows, so am probably a reasonably competent user. Occasionally, when I go to save a new cue, update an edited cue or even save or update a position palette, the command line text turns to red and it will not save the cue or edit. The only way to move forward is to "Clear" and re-create the cue/update/palette or edit all over again and it will usually save/update the 2nd time around. As you can probably imagine, this is frustrating and time-consuming, especially when busy plotting a big show on a tight schedule and it's not always easy to re-create the lighting state you've just spent 10 minutes building! The issue seems to happen more often with more complex lighting states involving movers (we use Chauvet Intimidator Hybrid 140SRs) but it also happens at other times and seems to be happening more frequently now. I suspect the issue may be related to memory in the desk. The desk fails the FeRAM test but, from other posts on here, it seems this is nothing to worry about. Has anybody encountered this issue before? Any thoughts, ideas, help, greatly appreciated! Thanks in advance. Mike - Regal Tenbury Wells, UK
	kgallen started following Force software update
	There’s the USB Creator flow for FLX (not FLX-S) console recovery: https://www.zero88.com/manuals/zeros/software-updates/zeros-usb-creator
