  1. Yesterday
  2. Hi @Davidmk Of course you’re right - I just wanted to note that the use mode might be restricting what @ATC Tech might be trying to do if they’d opted for Cue Only thinking it would be ‘simpler’ but might be hampering them.
  3. Last week
  4. @kgallen Not disputing your point but @ATC Tech seems to want snapshot pallettes and cues for reasons best known to them. What's bothering them is that subsequent changes to the pallette were not reflected in the cue. While I don't usually use snapshot pallettes or cues I do have playbacks with multiple cues that I use for busking where tracking defeats the purpose by moving on dark right to the last cue regardless of which cue I triggered (by OSC). Tracking isn't always your friend. I would agree that normal colour/beam/shape/position pallettes are more versatile and, thus, useful and easier to change though.
  5. Are you in Cue Only mode? You seem to need to record-all (snapshots) using Shift+Record. This is rarely a good thing - it effectively nulls many desk features like playback overlaying, tracking, move on dark. You are effectively using the desk in a very basic mode.
  6. Just an update on this... the fix seems to be that, the same as when you record a Pallette you need to use "Shift/Record" you also need to use Shift/Record when you record the Pallette to the Cue Stack/Fader. Any updates to teh scene in teh Pallette seem to now be refleced in teh Fadr without further actions.
  7. Thank you, I might have a go then. Best wishes, Archie
  8. It’s easy, you’ll be fine!
  9. Thank you very much for your advice. At the moment, I don’t feel confident enough to do this by myself so I think I will leave it for now, try and get my confidence up and look about doing it when I’ve got a bit more experience or I can ask somebody to help me. Thank you for your advice, I really appreciate it. Kind regards, Archie
  10. Earlier
  11. Don't worry, with the page you provided me with the 'common' subdomain, there are workarounds 😉 https://backstage.zero88.com/a-z Thank you very much.
  12. It's not on the Wayback machine unfortunately @Archie D, but here's the old link anyway: https://common.zero88.com/a-z Sorry I couldn't have been of more help.
  13. For each connector I would: - Remove the clip - Pull the IDC connector out of the receptical - Replug - Replace the clip Go systematically around the console doing this.
  14. Hi, an update. Not too successful, but partially. We lay the console down, unscrewed the six access screws holding the front panel on, (i also put the earthing wriststrap on before doing this), and upon opening the console there was no obvious disconnection of the ribbon cable but we pushed down the clips to make sure it was secure. One was solid, the other flexed a bit on pushing. We then closed the console up, securing one screw top and bottom in the middle of the set of screwholes and turned it on. All worked perfectly. So we turned it back over, put the four remaining corner screws in, turned it over, plugged it back in, the fault was back. Do you think I need to replace the clip that had some flex in it? Do you think that is the issue with the intermittent fault on the LCD displays?
  15. I've stayed away from it for now, but more recently I've noticed the desk will start freezing after about 4-6h of programming unless I restart it which isn't entirely ideal.
  16. I'll have a look when I get home (I fear I may have deleted my bookmark), but that's a good shout
  17. Hi all, from what I'm aware of (and the replies I've received), they don't seem to have any plans of getting the Android apps back on the appstore and for now are just sending the APKs out. I doubt we'll have any further updates to the apps at this rate.
  18. Ordered yesterday, arrived today. I'll see if I can do anything tomorrow with the desk. Thank you again for the advice.
  19. @pierotec That's good news. Thanks for sharing.
  20. I can confirm that the Flx S48 console worked well using about 2000 channels with 2 Artnet node and 13 used universes
  21. Only if I’m doing work on a board out of the system - in circuit, CMOS chips aren’t quite as vulnerable. I’m assuming you’re not running your feet on a nylon carpet first! But if you have a wrist band then might as well use it.
  22. Thanks for your reply @kgallen, that's something great to go off if I take a look inside. Do you use an earthing wristband thingy when you open up your Fat Frog?
  23. Just guessing but there is probably a ribbon cable dedicated to the displays (separate to wheels, buttons etc). I’m sure that was the case when I opened my Fat Frog a few weeks back. If you’re up for opening it I’d check that as a common cause - ie highly unlikely all LCDs themselves went bad at the same time!
  24. Just an update - I've turned on the desk again to see if the issue had gone (due to intermittence) and I am now presented with this on the bottom LCD: However, when tapping C, B or P buttons, the top LCD goes back to normal instead of the offset lines as shown below:
  25. Hi all, I have an issue with my JesterML that seems intermittent. It appears to only have started having this issue since a few days ago. The issue is when I turn on and boot up the desk, the main LCD is blank (but still backlit), same with the wheel LCD. The top MFK lcd is showing content, but slightly malformed on the top row (see pics below). Bottom MFK lcd seems fine so far. This issue sometimes happens when I turn the desk on, and sometimes doesn't happen. DMX output still works fine, same with monitor VGA output from the back ports. Buttons all still work, so do the wheels, as the red LEDs in the buttons do change when I press them to the desired option I want to select. It's the LCDs that are the issue. Another thing to add is that on the top MFK lcd, when I select either Colour, Beamshape or Position, the four horizontal bars you see disappear and it just goes to how picture E shows. Picture A: Whole desk view Picture B: The MFK LCDs Picture C : Main LCD Picture D : Wheel LCD Picture E: four horizontal bars have now disappeared after selecting C, B or P Pictures are attached below. If anyone knows the problem here, I would be incredibly grateful if you could help me. Thank you. Perhaps it is a loose connection inside, but maybe something damaged? I'm not sure. I wanted to be careful and not open the desk just yet in case something goes wrong. Picture A Picture B Picture C Picture D Picture E
  26. I'll let you know soon 😉
  27. No, but I've used nearly 1024 and that was OK although it was a few versions ago. Just wondering if anyone has gone further.
  28. Why, have you noticed problems with more than 1024 channels?
