  1. Past hour
  2. @pierotec That's good news. Thanks for sharing.
  3. Yesterday
  4. I can confirm that the Flx S48 console worked well using about 2000 channels with 2 Artnet node and 13 used universes
  5. Last week
  6. Only if I’m doing work on a board out of the system - in circuit, CMOS chips aren’t quite as vulnerable. I’m assuming you’re not running your feet on a nylon carpet first! But if you have a wrist band then might as well use it.
  7. Thanks for your reply @kgallen, that's something great to go off if I take a look inside. Do you use an earthing wristband thingy when you open up your Fat Frog?
  8. Just guessing but there is probably a ribbon cable dedicated to the displays (separate to wheels, buttons etc). I’m sure that was the case when I opened my Fat Frog a few weeks back. If you’re up for opening it I’d check that as a common cause - ie highly unlikely all LCDs themselves went bad at the same time!
  9. Just an update - I've turned on the desk again to see if the issue had gone (due to intermittence) and I am now presented with this on the bottom LCD: However, when tapping C, B or P buttons, the top LCD goes back to normal instead of the offset lines as shown below:
  10. Hi all, I have an issue with my JesterML that seems intermittent. It appears to only have started having this issue since a few days ago. The issue is when I turn on and boot up the desk, the main LCD is blank (but still backlit), same with the wheel LCD. The top MFK lcd is showing content, but slightly malformed on the top row (see pics below). Bottom MFK lcd seems fine so far. This issue sometimes happens when I turn the desk on, and sometimes doesn't happen. DMX output still works fine, same with monitor VGA output from the back ports. Buttons all still work, so do the wheels, as the red LEDs in the buttons do change when I press them to the desired option I want to select. It's the LCDs that are the issue. Another thing to add is that on the top MFK lcd, when I select either Colour, Beamshape or Position, the four horizontal bars you see disappear and it just goes to how picture E shows. Picture A: Whole desk view Picture B: The MFK LCDs Picture C : Main LCD Picture D : Wheel LCD Picture E: four horizontal bars have now disappeared after selecting C, B or P Pictures are attached below. If anyone knows the problem here, I would be incredibly grateful if you could help me. Thank you. Perhaps it is a loose connection inside, but maybe something damaged? I'm not sure. I wanted to be careful and not open the desk just yet in case something goes wrong. Picture A Picture B Picture C Picture D Picture E
  11. I'll let you know soon 😉
  12. No, but I've used nearly 1024 and that was OK although it was a few versions ago. Just wondering if anyone has gone further.
  13. Why, have you noticed problems with more than 1024 channels?
  14. Hi all. The iOS apps are now back on the App Store in their original capacity and under the same links they were before. ZerOS Monitor -> https://apps.apple.com/gb/app/zeros-monitor/id1033159176 ZerOS Remote -> https://apps.apple.com/gb/app/zeros-remote/id367342433 (cc: @Charlie Newman @Philh @ATC Tech)
  15. Thanks David. I’ll give it a go with update.
  16. I haven't tried what you are describing but my guess is that it's something to to with using 'overwrite" rather than "update". I think it is disassociating the playback from the pallette (as it would if you deleted and recreated the pallette). As a full FLX user, I'm not sure if you can do this but bring the playback up, select a fixture that should have values from the pallette and check the screen. If the playback is still associated with the pallette then the pallette name will show rather than numerical values. Same goes (I think) for the wheel labels. Obviously you could bring up the playback, select the fixtures, apply the pallette and update or overwrite the cue but that's going to get tedious if you have used the pallette in multiple cues. I'd suggest using update instead. Note that changing the group will not add or remove fixtures from the cue or the pallette. Also note, this is guesswork. I've not tried it. Hope it helps though.
  17. Hello EVeryone, Please help as I must be doing someting wrong here... I have an FLX S48 running ZerOS 8. I create an "All Lights" Group and having selected that I create a "Look" and record that Look as a Snapshot (Shift+Record) to the Beam Pallete and I see that it says "ICBPE" in the pallete so I believe I have recorded all attributes of the look to the Pallette. I can bring back that Look on stage by selecting the All Lights Group and touching the approperate Beam Pallete. Having brought the Look on stage via the Beam Pallete I record it to a Playback Fader by Clicking Record and the appoperate Fader Button. Going into Playbacks and bringing up that fader puts the correct Look on-stage... So Far So Good. Later, I need to change the Look so set the new look on-stage and I re-record (shift + record) the same Beam Pallete and select "Overwrite" to record everthing. However bring up the Playback Fader still shows the previous look and not the new look on the Beam Pallete. Selecting All Lights and touching the Beam Pallete correctly brings the new Look on-stage. I understood that I could "reference" the Beam Pallet on the Playback fader and any changes to the Pallet would then automatically reflect back into the Playback Fader.. SO, am I doing someitng wrong or does that not work? Thansk Craig
  18. Perhaps the crashes within programming are related to something memory-wise within ZerOS 8.0? You may be right there. I don't have a FLX myself, but as @SimonH mentioned, the desks running 8.0 crashed especially when programming moving lights, which usually handle more parameters than regular LED stuff and of course dimmers. I'm not entirely sure, but could the issue be related to where as you are programming a LX state, the data for parameters are held in some sort of temporary memory system (aka you know where in the output window, all the intensity values are red when not recorded/saved anywhere yet), and once recorded it never gets cleared from that internal memory as it usually should (due to the fact there is no reason to hold what you are currently programming, as it has been recorded) leading to the desk overloading itself to the point where the memory becomes full and eventually resulting in a crash. Obviously, once a reboot is performed, that temporary memory is cleared and all is well until the memory builds up again. Just a thought and a theory.
  19. I've just had my FLX (running ZerOS 8.0) back from a 2 week hire and had no end of complaints regarding regular crashes I advised them to downgrade, but they were nervous to do so with a busy show schedule. I've also had a couple crashes during programming sessions, fortunately never when running a show. I wonder if it has something to do with the programmer?
  20. Yes but the crucial bit is the bugs were ironed out.
  21. SimonH
    Is 8.0 really buggy?
  22. All clear, I'd already done some tests in the meantime. With current fixtures, it's very easy to manage a significant number of channels, but 2048 channels is a good number for a console of this type. I was more interested in being able to use many universes. Thank
  23. I was setting up a basic showfile for a new client's venue from scratch a bit back and installed v8 before starting. I had a crash in programming and while I couldn't be sure it wouldn't have happened with the old version (I've had crashes with v7.14.3) I regressed the desk and started again. Since then I haven't dared try v8 again. Only rational if you consider how bad it looks if you are working in a professional venue, spurning their house desk, and have to restart your own mid show. Back in the day, when I had a day job in IT, the rule was never install an even numbered release. The even numbered ones (and that especially includes .0 ones) tend to have new features, the odd ones have the bug fixes to the even ones. Maybe that's a still a good rule to follow
  24. I know that, in theory, ZerOS desks can handle a maximum number of DMX addresses spread over upto 64 universes but I'd be really interested to know the number of channels people are actually using without problems. Anyone using over 1024?
  25. With the release of ZerOS 8 the number of licensed channels in a FLXS48 is 2,048. https://www.vari-lite.com/global/news/releases/zeros-8-0 which can be patched across 64 universes. https://www.zero88.com/storage/downloads/manuals/zeros-en.pdf "On all ZerOS consoles, including FLX, FLX S24 & FLX S48, ZerOS allows fixtures to be patched across 64 universes without wasting unused channels. Any two of these universes can be sent out over the two DMX outputs. The total number of used channels across the 64 universes must not exceed the number of universes your console is licensed to output. All 64 universes can be distributed over an Ethernet network using either “Art-Net”, “Streaming ACN” or “CITP”.'
  26. Anyone else found their FLX crashing on a regular basis since installing 8.0? We have 2 here and I used our spare at the beginning of the year on an external show after it had returned from the repair guy and loaded 8.0 on to it. During plotting the desk froze on numerous occassions especially when programming the moving lights. My main desk in the venue continued to run 7.13 with no problems at all including using the movers once they returned. 2 weeks ago, having forgotten about the desk crashes I installed 8.0 onto the main desk and we've had half a dozen freezing/crashing issues. Swapped over to the spare desk and the same so have now dialled both back to 7.14 and will see how that goes. No-one left at Zero to report it to or who seems to care so looks like I'll be losing all the upgrades that came with 8.0
  27. OK, it seems there's no limit up to 64 universes, even though the specs mention up to 4 universes. But going into more detail, I can, for example, manage 96 fixtures of 40 channels each across 12 universes and therefore manage 3840 channels, because in this case too the specs mention a maximum of 2048 channels.🤔
  28. Earlier
  29. In theory you can put channels across 64 universes. Might depend more on the ArtNet node handling two controllers. https://www.zero88.com/manuals/zeros/patching/available-channels
