- Past hour
Yes it a direct quote from the vari-lite reply to our Lighting designer/operator who reported the problem at the beginning of July and got the reply yesterday.
kgallen started following Is 8.0 really buggy?
@Phil Kiernan are these your words of from Vari-lite? ie is this the firmest suggestion yet there will be at least one more ZerOS release?
Keep ambience lights on during masterblackout
Thanks that answers a second question: what inhibit is forš lāve been using the FlxS since 2018? and never found out Iāll give it a try.. but, if I get that right, thereās no way to include a on the fly programmed playback to that group during the show, because all playback faders have to be at 100% when setting a fader as inhibit fader? Thank you š -
We've been having the same problem. Sent the file to Vari-Lite and we have eventually got this reply. 'The crash in ZerOS 8.0.0.8 is referencing a palette that doesn't exist. This will be fixed in the next software release, for now I would try to avoid doing it. (Specifically, typing POSITION 26 ENTER.)'
Is it possible that this was caused (even though you downgraded to a previous version than 8.0.0) by the show file being an 8.0.0 show file (e.g. you created the show file while on v8.0.0) instead of a show file of the version you downgraded to? I'm not entirely sure but could it possibly be the case?
Make sure you are using record (not update) and have disabled SmartTag. See manual here.
I've just replied about this in another post. I tried updating the colour default so i didn't have to select a colour each time to see it but instead it assigned a random clour and now wont change it. Updating colours seems to be fine though.
Not by themselves but I tried to alter the default colour on some LED washes and it just refused. Also tried to unblock cues by both the update method and the global method in set up and neither worked so lots of my MID didn't work and had to do loads of point cues. Just really fed up with the desk now.
Davidmk started following Keep ambience lights on during masterblackout
No and yes. Normally the dedicated grand master controls all the intensity channels. However, in the last few versions of ZerOS the grand master can be programmed the same as any other fader so it is possible to re-program it as an inhibit fader for just the fixtures you want to include. Of course the S series do not have a dedicated GM fader so I guess you are referring to an MFF set to grand master so, for you, the solution is to NOT set it as grand master. Instead, select all the fixtures except your ambience ones, set them to full and record that on the MFF you wish to use as the GM. Then hold down setup and press the fader's button and select Inhibit on the playback settings menu. Note that using inhibit means the playback button will not be Blackout and there is isn't a way to replicate this. -
Oliver_74 started following Keep ambience lights on during masterblackout
Hi, Iām sure sure the question appeared before, but i canāt find it: Is it possible to keep fixtures just used for ambience lights on during a master blackout? thanx for your help Oliver
Can't believe I didn't notice this haha, looks slightly different from what I remember š¤¦āāļø
Hi @Davidmk Of course youāre right - I just wanted to note that the use mode might be restricting what @ATC Tech might be trying to do if theyād opted for Cue Only thinking it would be āsimplerā but might be hampering them.
kgallen started following Update Snapshot on a Playback Fader
Itās easy, youāll be fine! -
Thank you very much for your advice. At the moment, I donāt feel confident enough to do this by myself so I think I will leave it for now, try and get my confidence up and look about doing it when Iāve got a bit more experience or I can ask somebody to help me. Thank you for your advice, I really appreciate it. Kind regards, Archie -
Don't worry, with the page you provided me with the 'common' subdomain, there are workarounds š https://backstage.zero88.com/a-z Thank you very much.
