It’s easy, you’ll be fine! -
Thank you very much for your advice. At the moment, I don’t feel confident enough to do this by myself so I think I will leave it for now, try and get my confidence up and look about doing it when I’ve got a bit more experience or I can ask somebody to help me. Thank you for your advice, I really appreciate it. Kind regards, Archie - Last week
Ordered yesterday, arrived today. I'll see if I can do anything tomorrow with the desk. Thank you again for the advice. - Earlier
kgallen started following JesterML LCDs blank [still backlit] and MFK lcd top row malformed
I'll let you know soon 😉
