  1. Today
  2. Hi @invisible It sounds like you’ve defined the fixture correctly. Are you testing this by pushing a fader? You will probably find that the fader has 8 bit resolution. However if you programme a cue with a fade you should find that the console fades with 16 bit resolution. That is what happens on my FLX - 8 bit on the fader, 16 bit from a memory. Here’s a thread where we were talking about this (FLX-S in this case):
  3. Yesterday
  4. Hello, I'm trying to set up some Cameo Root Par 6 in 11ch mode on my Jester TLXtra. In this mode they support a 16 bit dimmer on channel 1 (MSB) and 2 (LSB); I created the fixture with the Fixture Type Editor, selected 16bit for the dimmer, and assigned the two channels accordingly. When I load this fixture into the console it seems to only use 8 bit though (very noticeable on LED spots, as there is a significant jump in brightness between 0 and 1%, which is exactly why there is a 16 bit dimmer in the first place). According to the manual: "16-bit parameters are displayed on the desk as two sets of values (eg 127-255) to indicate the level of both channels", but my desk only displays 1 value (0-100%) on the dimmer wheel. In fact it almost seems as if the dimmer doesn't even use the full 8-bit resolution but actually "%". What am I missing? regards, Stephan
  5. Last week
  6. An inhibit doesn't set the intensity level it limits what the maximum intensity can be so you can still have playbacks that set something less than 100% and they will still work as expected. e.g. You create two playbacks one of them (a) sets a fixture to 50%, the other (b) sets another fixture to 100% then you create an inhibit playback (i) with both fixtures at 100% (it doesn't have to be 100% but it usually is). With (i) at full, (a) and (b) work normally - 50% and 100%. With (i) at 50%, (a) will be at 25% and (b) at 50% With (i) at 0%, both (a) and (b) will be at 0% One thing to notice is that after you have created (i) you need to take it to 100% once to make it effective - if you just leave it at 0% it doesn't inhibit at all. A spin off of this is that, if the fader isn't quite making it to 100% (because it needs cleaning for example) you can never make it work. I generally find it is easier to delete and re-create inhibits than to try updating them if you need to add or remove fixtures. It's quite a powerful option but you have to get your head around it. Incidentally, there's also parking but I'm not sure if you can do that on S series. Or you could change the fixture defaults, this would put the ambients on unless you had a playback to set them off but the GM or an inhibit that included them would still put them out.
  7. Yes it a direct quote from the vari-lite reply to our Lighting designer/operator who reported the problem at the beginning of July and got the reply yesterday.
  8. @Phil Kiernan are these your words of from Vari-lite? ie is this the firmest suggestion yet there will be at least one more ZerOS release?
  9. Thanks that answers a second question: what inhibit is for😁 l’ve been using the FlxS since 2018? and never found out I’ll give it a try.. but, if I get that right, there’s no way to include a on the fly programmed playback to that group during the show, because all playback faders have to be at 100% when setting a fader as inhibit fader? Thank you 🙂
  10. We've been having the same problem. Sent the file to Vari-Lite and we have eventually got this reply. 'The crash in ZerOS 8.0.0.8 is referencing a palette that doesn't exist. This will be fixed in the next software release, for now I would try to avoid doing it. (Specifically, typing POSITION 26 ENTER.)'
  11. Is it possible that this was caused (even though you downgraded to a previous version than 8.0.0) by the show file being an 8.0.0 show file (e.g. you created the show file while on v8.0.0) instead of a show file of the version you downgraded to? I'm not entirely sure but could it possibly be the case?
  12. Make sure you are using record (not update) and have disabled SmartTag. See manual here.
  13. I've just replied about this in another post. I tried updating the colour default so i didn't have to select a colour each time to see it but instead it assigned a random clour and now wont change it. Updating colours seems to be fine though.
  14. Not by themselves but I tried to alter the default colour on some LED washes and it just refused. Also tried to unblock cues by both the update method and the global method in set up and neither worked so lots of my MID didn't work and had to do loads of point cues. Just really fed up with the desk now.
  15. SimonH
    Is 8.0 really buggy?
  16. No and yes. Normally the dedicated grand master controls all the intensity channels. However, in the last few versions of ZerOS the grand master can be programmed the same as any other fader so it is possible to re-program it as an inhibit fader for just the fixtures you want to include. Of course the S series do not have a dedicated GM fader so I guess you are referring to an MFF set to grand master so, for you, the solution is to NOT set it as grand master. Instead, select all the fixtures except your ambience ones, set them to full and record that on the MFF you wish to use as the GM. Then hold down setup and press the fader's button and select Inhibit on the playback settings menu. Note that using inhibit means the playback button will not be Blackout and there is isn't a way to replicate this.
  17. Hi, I‘m sure sure the question appeared before, but i can’t find it: Is it possible to keep fixtures just used for ambience lights on during a master blackout? thanx for your help Oliver
  18. Earlier
  19. Probably looks slightly different from when you saw it if the website had a partial redesign on the frontend after you saw it.
  20. Can't believe I didn't notice this haha, looks slightly different from what I remember 🤦‍♂️
  21. Hi @Davidmk Of course you’re right - I just wanted to note that the use mode might be restricting what @ATC Tech might be trying to do if they’d opted for Cue Only thinking it would be ‘simpler’ but might be hampering them.
  22. @kgallen Not disputing your point but @ATC Tech seems to want snapshot pallettes and cues for reasons best known to them. What's bothering them is that subsequent changes to the pallette were not reflected in the cue. While I don't usually use snapshot pallettes or cues I do have playbacks with multiple cues that I use for busking where tracking defeats the purpose by moving on dark right to the last cue regardless of which cue I triggered (by OSC). Tracking isn't always your friend. I would agree that normal colour/beam/shape/position pallettes are more versatile and, thus, useful and easier to change though.
  23. Are you in Cue Only mode? You seem to need to record-all (snapshots) using Shift+Record. This is rarely a good thing - it effectively nulls many desk features like playback overlaying, tracking, move on dark. You are effectively using the desk in a very basic mode.
  24. Just an update on this... the fix seems to be that, the same as when you record a Pallette you need to use "Shift/Record" you also need to use Shift/Record when you record the Pallette to the Cue Stack/Fader. Any updates to teh scene in teh Pallette seem to now be refleced in teh Fadr without further actions.
  25. Thank you, I might have a go then. Best wishes, Archie
  26. Thank you very much for your advice. At the moment, I don’t feel confident enough to do this by myself so I think I will leave it for now, try and get my confidence up and look about doing it when I’ve got a bit more experience or I can ask somebody to help me. Thank you for your advice, I really appreciate it. Kind regards, Archie
  27. Don't worry, with the page you provided me with the 'common' subdomain, there are workarounds 😉 https://backstage.zero88.com/a-z Thank you very much.
  28. It's not on the Wayback machine unfortunately @Archie D, but here's the old link anyway: https://common.zero88.com/a-z Sorry I couldn't have been of more help.
