Davidmk started following Blind edit without impact from life scene
- 1 reply
- 1
Kauz started following Is 8.0 really buggy? and Blind edit without impact from life scene
I mean.. not to lead too far away from the post's original topic with my message below, but if we're on the topic of analysing ZerOS... relatively recently I loaded ZerOS up and had a play around. I'm not sure if it has been discussed before, but I discovered that ZerOS used to have (or still has - I just cannot seem to find it) a partial theme editor for the external monitor's UI appearance.. in newer versions it seems to have disappeared though. This was on ZerOS version 7.8.2.39, so that software version was released just nearing the end of 2016 and was the last available one for Frog 2. I also found a "Testbed" window, which was most definitely for development purposes of displaying cells, buttons, tickboxes, dropdowns, and other UI elements that need to be presented by the software. Below, I've attached three screenshots that I took today to show here. The first two relate to the "Display Palette Editor" (theme editor, one screenshot is the default view and the other is when I'd edited some colours such as the background to be green and button text to be pink) and "Testbed" for UI elements. P.S. admins - I apologise if sharing this isn't allowed for development reasons, please delete my post if that is the case Safety notice - if you somehow find this on your console (I won't say how I got these windows, to prevent any misuse of it or people potentially making mistakes) - I definitely don't recommend changing any values at all, because when resetting the desk, it won't reset these values. -
@Archie D @MD1125 You are out of my experience here. Nearest I've been was programming PDP11s 50yrs ago. No desire to return to that level of detail -
@MD1125, thank you very much for sharing and outlining this. Analysing network traffic.. I wouldn't have figured that out straight off! That's really interesting to see how ZerOS handles inputs from the mobile apps. I recognise the Z88R part of the string - presumably meaning "Zero 88 Remote". When I opened some of the obfuscated files that ZerOS contains (built on a linux system), most begin with "Z88C" from what I remember, presumably meaning "Zero 88 Console", so I can see the links starting to form... -
I was just in general interested in how all of it works I guess. No direct purpose, just pure interest. Oh and regarding the theoretical direct string input: I was actually able, after some playing around, to fully emulate the traffic between the Monitor and FLX S24 by opening my own TCP connection to the FLX and then send the same strings it does from the Monitor App. From what I've looked at in the traffic it first sends a string to initialize, then one carrying the Password, and then you have (in theory) full control over the Keyboard. By sending these strings: "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 00 0a 00 00 00 00 00 00 00", "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 03 61 00 00 00 00 00 00 00", "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 01 0a 00 00 00 00 00 00 00", You can emulate you typing an "@" on your keyboard, same goes for any other keys you might press, so by expanding this system you could (theoretically) make your own API I guess, just not directly for colour, although that would also work if you kinda pre-record where the mouse has to press. And as far as "debugging" these strings goes, they seem to be actually rather structured, example: First string for @ -> "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 00 0a 00 00 00 00 00 00 00" Z 8 8 R D k e y Presumably key data "5a 38 38 52 01 00 00 00 1d 00 00 00 44 4b 65 79 00 00 00 00 03 61 00 00 00 00 00 00 00" -
@Archie D I'm not sure what the level of control @MD1125 described is for. It would be easier to get a long DMX cable and move the desk. I use OSC to get quick access to colours, positions, effects and other stuff when I'm busking. I record what I might want as cues in playbacks and send a go PB/cue by OSC from a screen next to the desk. I don't use it when programming the show file in the first place. -
Ah, @Davidmk, I do apologise for posting over your post, the forum page didn't update for me showing your post when you posted it while I was writing mine. Archie
