- Past hour
kgallen started following Is 8.0 really buggy? and Jester TLXtra and 16 bit dimmer channels
Hi @invisible It sounds like you’ve defined the fixture correctly. Are you testing this by pushing a fader? You will probably find that the fader has 8 bit resolution. However if you programme a cue with a fade you should find that the console fades with 16 bit resolution. That is what happens on my FLX - 8 bit on the fader, 16 bit from a memory. Here’s a thread where we were talking about this (FLX-S in this case):
Hello, I'm trying to set up some Cameo Root Par 6 in 11ch mode on my Jester TLXtra. In this mode they support a 16 bit dimmer on channel 1 (MSB) and 2 (LSB); I created the fixture with the Fixture Type Editor, selected 16bit for the dimmer, and assigned the two channels accordingly. When I load this fixture into the console it seems to only use 8 bit though (very noticeable on LED spots, as there is a significant jump in brightness between 0 and 1%, which is exactly why there is a 16 bit dimmer in the first place). According to the manual: "16-bit parameters are displayed on the desk as two sets of values (eg 127-255) to indicate the level of both channels", but my desk only displays 1 value (0-100%) on the dimmer wheel. In fact it almost seems as if the dimmer doesn't even use the full 8-bit resolution but actually "%". What am I missing? regards, Stephan
Keep ambience lights on during masterblackout
An inhibit doesn't set the intensity level it limits what the maximum intensity can be so you can still have playbacks that set something less than 100% and they will still work as expected. e.g. You create two playbacks one of them (a) sets a fixture to 50%, the other (b) sets another fixture to 100% then you create an inhibit playback (i) with both fixtures at 100% (it doesn't have to be 100% but it usually is). With (i) at full, (a) and (b) work normally - 50% and 100%. With (i) at 50%, (a) will be at 25% and (b) at 50% With (i) at 0%, both (a) and (b) will be at 0% One thing to notice is that after you have created (i) you need to take it to 100% once to make it effective - if you just leave it at 0% it doesn't inhibit at all. A spin off of this is that, if the fader isn't quite making it to 100% (because it needs cleaning for example) you can never make it work. I generally find it is easier to delete and re-create inhibits than to try updating them if you need to add or remove fixtures. It's quite a powerful option but you have to get your head around it. Incidentally, there's also parking but I'm not sure if you can do that on S series. Or you could change the fixture defaults, this would put the ambients on unless you had a playback to set them off but the GM or an inhibit that included them would still put them out. -
Yes it a direct quote from the vari-lite reply to our Lighting designer/operator who reported the problem at the beginning of July and got the reply yesterday.
@Phil Kiernan are these your words of from Vari-lite? ie is this the firmest suggestion yet there will be at least one more ZerOS release?
Thanks that answers a second question: what inhibit is for😁 l’ve been using the FlxS since 2018? and never found out I’ll give it a try.. but, if I get that right, there’s no way to include a on the fly programmed playback to that group during the show, because all playback faders have to be at 100% when setting a fader as inhibit fader? Thank you 🙂 -
We've been having the same problem. Sent the file to Vari-Lite and we have eventually got this reply. 'The crash in ZerOS 8.0.0.8 is referencing a palette that doesn't exist. This will be fixed in the next software release, for now I would try to avoid doing it. (Specifically, typing POSITION 26 ENTER.)'
Is it possible that this was caused (even though you downgraded to a previous version than 8.0.0) by the show file being an 8.0.0 show file (e.g. you created the show file while on v8.0.0) instead of a show file of the version you downgraded to? I'm not entirely sure but could it possibly be the case?
Make sure you are using record (not update) and have disabled SmartTag. See manual here.
I've just replied about this in another post. I tried updating the colour default so i didn't have to select a colour each time to see it but instead it assigned a random clour and now wont change it. Updating colours seems to be fine though.
Not by themselves but I tried to alter the default colour on some LED washes and it just refused. Also tried to unblock cues by both the update method and the global method in set up and neither worked so lots of my MID didn't work and had to do loads of point cues. Just really fed up with the desk now.
Davidmk started following Keep ambience lights on during masterblackout
No and yes. Normally the dedicated grand master controls all the intensity channels. However, in the last few versions of ZerOS the grand master can be programmed the same as any other fader so it is possible to re-program it as an inhibit fader for just the fixtures you want to include. Of course the S series do not have a dedicated GM fader so I guess you are referring to an MFF set to grand master so, for you, the solution is to NOT set it as grand master. Instead, select all the fixtures except your ambience ones, set them to full and record that on the MFF you wish to use as the GM. Then hold down setup and press the fader's button and select Inhibit on the playback settings menu. Note that using inhibit means the playback button will not be Blackout and there is isn't a way to replicate this. -
Oliver_74 started following Keep ambience lights on during masterblackout
Hi, I‘m sure sure the question appeared before, but i can’t find it: Is it possible to keep fixtures just used for ambience lights on during a master blackout? thanx for your help Oliver
kgallen started following Update Snapshot on a Playback Fader
It’s easy, you’ll be fine! -
