Pipo
Everything posted by Pipo
reverse: the same option you have on your fixtures (clockwise- counterclockwise) swap: pan=tilt, tilt=pan correct me if i'm wrong
burger...............cheese
You Englishmen always have to do it the opposite way: driving on the wrong side of the road,.........
Maybe this sounds stupid but is it possible to change the direction of the thumbwheel?
Maybe i'm saying things wrong: example: the shape i'm using is a circle, i put the x and y parameter at 50, speed 10, so all the fixtures are moving in the same way, now i put position into the fan-first-mode. No problem so far, but when i want to set the offset to 60% it stays at 0 no mather how much i spin the wheel, then if i put it into fan-last or fan-middle then i can put the offset to 60%!! And sometimes its the other way around.
"Maybe :idea: " for those people who want sx-buttons on their frog it would be nice to have an expansion-wing rather than changing flash-buttons into sx-buttons. But from a technical point of view i think this idea sucks, because i really don't know if it would be possible to connect it in some way. :?: :?: :?:
Would it be possible in the future to add a 6 or 12-channel-dimmer to the fixture-list, so i can control 12 PAR64 with only one fixture-selection-button. I think this would be very useful on the mambo!
My desk(mambo) crashed this weekend(and other times) while programming: almost every time the desk autosaves the show, it crashes. The desk had saved the entire show but at 100% it stops and keeps displaying 'saving show 100%'.Only a reset helps. While programming a shape and using the fan and offset-function there is always something not working: If i change position from relative to fan-first there is no way i can change the offset-parameter, but then when i put it into fan-last it works fine.
or you can just create some memories and add a jump to it, so that when memory 1 is finished it goes to memory 2,....
Tell me about FrogII!!!!!!!!
we are working on the dutch version of the mambo at the moment
not yet, will be available in the next update
On the zero88 site, on the product description of the Frog, i saw there is an FROG Autochase function, however i can't find anything back in the manual.
Visualisation (and getting DMX out of Phantom Frog)
Pipo replied to alcrooks's topic in Frog Range MK1
the color and gobo you can find on the parameter list of your fixtures but for position and rotating gobos you will have to find out at the show! There is no visualiser for the PhantomFrog, i don't need it anyway, might be useful for color and beamshape, but preprogramming position always sucks even if you have wysiwyg, there is always something different on the set! -
How do i become a beta-tester?
Can u put a date on the latest issue of the mambo? So i know if i have to print it or not! Thanks
Wouldn't it be useful to have some BETA-testers?
just a question, to which bass frequency does the desk react and is it possible to change it? Have had some problems because to me it seems the desk reacts to any kind of sound or do I drink to much on job?
Dag Yves Zeg eens wat het probleem is met uw fixtures, heb nl. ook een mambo. Het probleem in het Engels is me niet echt duidelijk. Of mail effe, pld@pandora.be
Is it possible to add an extra useful feature to the desk? Here it comes: Could it be made possible when you go from position-pallet #1 to #2 that you can add a time that it needs to go from #1 to #2 example fixtures are focused in the stage center on pallet#1, and now you want to go to pallet#2 where the fixtures cover the whole stage. AND this transfer has to take 5 seconds. What i suggest is that when you go to pallet#2 press and hold position and then press a function key(f1-f4) so that you can adjust the transfer time on the LCD display with the +/- buttons, and then press position pallet#2. Is this a useful feature or not? :idea: :idea: :idea: :idea: :idea:
Just joking K-Nine, so tell me about the update, what's new?
I will pay you with Buddweiser Franck Are you going to be at ACF or is it just DCD and Rolight? CU
