Ian_p Posted March 18, 2024 Report Posted March 18, 2024 Hi. Another puzzler - I have some Stairville Showbar pro 16wx10, and as I’ve split the 6 into different groups - I had to create another new fixture. I used the same one as I had created for the others, and when bringing up the intensity it immediately strobes. The default strobe value is 255, I wind this off to zero, press record, fixture button, then the ‘home’ symbol and select default. All good. however the moment I start to try to use it again - it has flipped back to strobe value of 255. This is frustrating as I believe I am following the process to set the default - but it just won’t stick. any ideas what I’m doing wrong?
Davidmk Posted March 18, 2024 Report Posted March 18, 2024 1 hour ago, Ian_p said: press record, fixture button, then the ‘home’ symbol and select default I think it's selecting the fixture button that spoils it so it should be... press record then the ‘home’ symbol and select default No doubt @Edward Z88 will be along in the morning to confirm or correct this. 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
DALX Posted March 19, 2024 Report Posted March 19, 2024 (edited) The default setting for when creating a fixture for Strobe is 255 but most fixtures want a default setting of zero. I set this default to zero when creating a new fixture, but occasionally forget to and have to go back and edit the default value for strobe to zero. The manual for your bar shows strobe as 0...255 Stroboscopic effect (o% to 100%) Edited March 19, 2024 by DALX left out set
Edward Z88 Posted March 19, 2024 Report Posted March 19, 2024 17 hours ago, Ian_p said: however the moment I start to try to use it again - it has flipped back to strobe value of 255. This is frustrating as I believe I am following the process to set the default - but it just won’t stick. To store values for a fixture that is currently @ 0% intensity, you must make sure that the "SmartTag" funciton is off in the Record Options. Therefore: Select your fixtures Adjust the Strobe parameter to the required value, and adjust no other parameters Press and hold Record to open the Record Options Ensure that "SmartTag" is disabled. If the button has a red stripe, tap it so it goes blue Double tap RECORD Tap the Home icon Choose to store as "Default" Hope this helps. 1 Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Ian_p Posted March 26, 2024 Author Report Posted March 26, 2024 Thanks Edward - to be honest I managed to get the strobe to stick to 0 - but not via the above - I just tried to do it as I had above and on the 5th time it worked. Not sure if or what I did different.
