I occasionally use a Leapfrog 48 desk at a small theatre in the UK, and it has recently (I think) gained the ability to disable "page handover" on "playbacks" (previously called "submasters"). It's a brilliant feature but it seems to have a fatal flaw - there's no quick way to clear them all. Or is there? I can't find any documentation about this.
So that's my question - how can I quickly clear all the active playbacks, if they are scattered around the 20 available pages?
For context, I use playbacks quite often to add effects to live music shows - things like spotlighting soloists, changing colours to follow the mood, pulsing for a disco effect, chases and so on. The problem is there are only 10 of them and I typically have more effects than that. There are 20 pages though so in theory 200 effects are available to me, but until now "page handover" meant only 10 could be actively in use at any one time.
Then I discovered someone had disabled the page handover feature (I think) and now I can bring up multiple effects on any of the 20 pages. Fantastic! The only problem is, at the end of the song I faded to black using the master fader and tried to clear everything ready for the next scene by pulling down all 10 playbacks and pressing CLEAR a couple of times and it didn't work! I seem to be required to cycle through 20 pages of playbacks looking for the active ones and clear them individually. Meanwhile the audience is in the dark and getting restless. That's unacceptable and so the feature is useless.
Surely there must be a way, though? I would have expected multiple CLEAR presses or perhaps SHIFT + CLEAR or something would do it, but I couldn't find a way (in the time available, I only have occasional access). Am I missing something?
Phil McKerracher
www.mckerracher.net
  • 5 months later...
Update: I finally got this to work in the simulation using Clear + Fader buttons. Still more than 10 button presses but a big improvement. So, many thanks for that tip.
I'll have a chance to try it on the real board later this week.
I think I've found a solution for my other question as well.
Phil McKerracher
www.mckerracher.net
Update: Tried this on the real board in the theatre and it didn't work. The board has been upgraded from a Leapfrog 48 to a Solution which might explain that. But what DID work was better - Clear + Submasters. This cleared them all in two button presses, which is great.
Except when it doesn't. 😞
It's not reliable - some faders still sometimes had to be cleared manually by cycling through submaster pages, finding active submasters and raising and lowering the fader. It doesn't always happen and I didn't manage to find the crucial difference between the ones that clear and ones that don't in the time available.
Phil McKerracher
www.mckerracher.net
