Charlie Newman Posted November 18, 2024 Report Posted November 18, 2024 So when I have only dimmer channels selected, I don't get intensity on an encoder wheel at all, so I can't manually fade. Anyway to bypass this?
kgallen Posted November 18, 2024 Report Posted November 18, 2024 Press the Z key. Make sure in the cue stack window your blue selection box is in the Name column, not the time columns. In Setup you can force Intensity onto the first encoder at all times. https://www.zero88.com/manuals/zeros/z-key/z-encoders?filter=3 https://www.zero88.com/manuals/zeros/selection-and-intensity/intensity-wheel That any use?
Charlie Newman Posted November 18, 2024 Author Report Posted November 18, 2024 Just what I was looking for, thanks!
