Harold Posted December 1, 2024 Report Posted December 1, 2024 I've finally figured out what was causing an issue. I half busk / half program music performances in our theater. Normally I use our movers for highlighting members of the bands. There have been a number of times when I press the button (set for Go Snap) to preset a mover and the light goes full and then swings into place. It seems that "After" I change from one page to the other, the glitch happens one time. Have I missed a setting? Now that I've isolated the problem I would like to fix it. Also, is there an estimate for the updated firmware update? Cheers, Harold Quote
kgallen Posted December 1, 2024 Report Posted December 1, 2024 Hi @Harold and welcome! Check if the Page Handover setting (change to Enabled) helps out. https://www.zero88.com/manuals/zeros/setup/settings/operational#page Regardless it seems like the behaviour you observe is a little unhelpful so hopefully @Jon Hole will take a look at your report and see if there is an issue there. Quote
Jon Hole Posted December 4, 2024 Report Posted December 4, 2024 Hi @Harold, I can't recreate this issue - are you able to send me your showfile please, and let me know exactly which playbacks & fixtures you're seeing this on - ideally with step-by-step instructions. Thank you! Quote Jon Hole linkedin.com/in/jonhole
Harold Posted March 11, 2025 Author Report Posted March 11, 2025 Hello, I I had a few hours and finally worked out the cause. When I change pages, if I don't give a 2 second pause before using "Go Snap" to preset movers, they light up 100% and swing into position. It was just my hands moving a little fast for the console. I'll need to make it muscle memory to force a pause. I love having the extra pages! Cheers, Harold Quote 1 Quote
