Hello
I have a question about saving positions in a palette.
When I move a moving head to a specific position and change the zoom, and then save it to the Positions palette, it only saves the position, but not the zoom (beam shape).
I've tried many options in the Record window, but to no avail.
However, if I move to the position, adjust the zoom, and then save it to the position via Update, it includes the zoom.
Why doesn't the console save both parameters (position and beam shape) in the Positions palette?
Greetings, Goofy
Translated with Google from German to English
On the assumption assumption that you are running ZerOS and the process is similar to ZerOS on FLX...
On FLX, after pressing Record you press position again then, in the record options window, you turn off SmartTag, tap/click the Beam button until the stripe is green then you tap/click the pallette you are recording to. The pallette should have the letters B and P on it after recording.
The process is described under Advanced Pallettes in the manual.
Apologies if this is no help - I've only used FLX, never had the pleasure of an Orb.
2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC. Avolites T3 with Titan on PC.
Thanks for your help.
Both links worked.
I didn't know about pressing the position button a second time...I only have the old manual for the ORB XF from 2011.
Next time I'll also look at the manual from the link in your reply.
Have a nice week.
Greetings, Goofy
You're welcome. Just pleased I was close enough to help. Sorry about the link - I had it on the screen in Chrome and copied it in, no idea why that didn't work.
It's always easier to find stuff in the manual if you already have some idea of how to do it. 😁
I think your link was fine. When I tried it again it went straight to the right page. Phone browser weirdness maybe!
with the manual I think you *have* to know it’s there somewhere. The Search just doesn’t work for me, it finds too much stuff and too much unrelated stuff…
So true.
