Hi all, hope you are well.
I was just curious.. from when to when were the Jugglers being manufactured?
Usually, on a page (for example the Jester Series https://www.vari-lite.com/global/products/jester-series) it tells you when they were manufactured, this case being 2008-2017 for the ML range. However, on the Juggler page (https://www.vari-lite.com/global/products/juggler) it does not mention the manufacture date anywhere.
I am aware that the Jester Series superseded the Juggler, but does anybody know this information per chance? Many thanks for any info you can supply me with.
Archie - Student
Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Level 6 DMX, Level 12, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, 4x Zero 88 Focus 650 Pebble Convex's, Linebacker, Demux 48 (x2)
Juggler was a ‘simple’ 2-preset desk so I don’t think it was superseded by Jester which is a programmable desk.
I think the lineage was more like:
Level series -> Juggler
Alcora/Elara -> Jester
Illusion -> Jester TL, ML
Sirius -> Frogs
Stage Electrics had Juggler in stock (albeit clearance) earlier this year. I’ve not seen Jesters on sale new for a long time.
So in answer to your question, Juggler could have been current until 2021/22 timeframe I recon. The datasheet says ‘(c) 2018-2021 Signify’ as a copyright date. The Juggler manual says 2005. So it was around for some time.
Maybe search on the forum to see if Jon mentioned a discontinue date.
Strange, I did hear somewhere that the Jester did, although it just could be my head playing tricks on me. You are probably right in what you've presented here with the line-up of consoles, so I appreciate the confirmation.
It also can store memories (or 'steps' as it calls them, each step being part of a 'sequence') as well as having the ability of being in 2 preset mode. I've had a play with mine at home and although rather simple in the operation of it, I admire its simplicity.
Thank you for the information you have provided me regarding the data sheet and the manual dates, I think I can try and work on figuring out dates with the info provided.
I will continue to do some more digging on the forums as you have advised. Thank you again and have a lovely day!
Archie - Student
1 hour ago, Charlie Newman said:
seems like the Signify folks got rid of it
Bad luck then. By chance do you (or anyone else) happen to remember the URL to that page, or have it saved anywhere?
We could always check https://web.archive.org/ on the wayback machine to see if anybody archived it..
Or do you mean this page? https://backstage.zero88.com/control (further down it has legacy products - they just give the same descriptions as on the Vari-Lite pages)
Archie - Student
  • 2 weeks later...
  • Like 1
3 hours ago, Charlie Newman said:
Sorry I couldn't have been of more help.
Don't worry, with the page you provided me with the 'common' subdomain, there are workarounds 😉
https://backstage.zero88.com/a-z
Thank you very much.
  • Like 1
Archie - Student
On 8/7/2025 at 4:14 PM, Charlie Newman said:
looks slightly different from what I remember
Archie - Student
