Charlie Newman Posted October 7, 2025 Report Posted October 7, 2025 Hi all, if I remember correctly you can create chases within cue stacks. If you can do this, how can one edit those? Need to have a repeated set of states, and a chase is unfortunately the best option (unless I'm missing something), as you can't trigger cue stacks from other cue stacks. Thank you in advance! Quote
kgallen Posted October 8, 2025 Report Posted October 8, 2025 You create a chase on a fresh playback. Then you trigger and release that chase playback from cues in your main cue stack. To be able to get at states in your chase you use SHIFT-Playback GO to get to the state you want to edit without the chase running on. Then you edit the state using UPDATE as you would any other cue. https://www.zero88.com/manuals/zeros/cues-playbacks/chases Quote
Charlie Newman Posted October 8, 2025 Author Report Posted October 8, 2025 Ah perfect, thank you ! Forgot you could trigger cue stacks. Quote
