delicolor Posted November 26, 2025 Report Posted November 26, 2025 I vaguely remember being able to adjust a setting so that the fixture level window could be set to show greyed out missing fixtures in order to keep the numbers in alignment with the faders. However I just made a new patch for a new venue and any skipped fixtures are just skipped, e.g. if there is no fixture 11 it displays 10 next to 12. If I load my regular (FLX) show into the FLX-S which doesn't have fixture 11 it is shown greyed out between 10 and 12. I've searched the online manual for likely words and gone through the menus but no luck. I remember an older prompt on earlier ZEROS for leapfrog to display 20 or 24 fixtures but that was a while back. Can anyone nudge me in the right direction or is it more of a hack? Cheers, Ian Quote
kgallen Posted November 26, 2025 Report Posted November 26, 2025 Is it related to ‘Hide Fader Pages’ here? https://www.zero88.com/manuals/zeros/setup/settings/operational Quote
delicolor Posted November 26, 2025 Author Report Posted November 26, 2025 I did check that out just to make sure but that just stops the desk scrolling beyond allocated blocks of channels or scenes on the page button, something I use anyway as it is useful. Quote
Archie D Posted November 26, 2025 Report Posted November 26, 2025 14 hours ago, delicolor said: I remember an older prompt on earlier ZEROS for leapfrog to display 20 or 24 fixtures but that was a while back. The ability to change views within the Output Window between 20 or 24 fixtures is possible with channel width located in 'Window Setup', but only for Solution / XL, Leapfrog 48/96, Orb, OrbXF and SCD Server Pro. This button is on the top bar of the Output Window, but unfortunately (as far as I can see), it is not available for FLX, FLX S or ZerOS Server. In response to your original question, you may be thinking of the 'Hide Unpatched' option within this popup window that will stop any unpatched fixtures being shown in the Output Window perhaps? See below: Quote Archie - Student Student of lighting design & operation Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Level 6 DMX, Sirius 24 & 48 (x2), Sirius 500, Lightmaster XLS, Fat Frog, Diablo, Orion, Alphapack 2, 4x Zero 88 Focus 650 Fresnels
