pierotec Posted December 10, 2018 Report Posted December 10, 2018 Hi, how can I configure pause on a cue/stack, without excluding the GO button. Thank you
Edward Z88 Posted December 10, 2018 Report Posted December 10, 2018 Hello, To configure a playback button's function, hold SETUP and tap a playback's button to enter its settings. When in the playback settings there is a line of options to customise the button function. By default, a cue stack will have a normal button function of Go, however if you hold SHIFT and tap the button it will Go but ignore fade times, referred to as "Go (Snap)". You can therefore change the shifted button function to "Pause" if you wish. To do this hold Z/SHIFT, and choose "Pause" from the button options, and then release Z/SHIFT. Click OK on the settings window, and now when you hold SHIFT and tap the playback's button it will act as a pause. Hope this helps, any queries let me know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Edward Z88 Posted December 10, 2018 Report Posted December 10, 2018 1 minute ago, pierotec said: tried ok thanks No problem. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
