Tom1234 Posted October 17, 2022 Report Share Posted October 17, 2022 Hi all I have been having some issues adding new fixtures to my Jester ML24, and so was wanting to buy a cheap Par Can -Equinox MaxiPar Quad LED Par Can to test a few things out. However when looking on the fixture library, I realise that this light is not on the list. I there a way of adding it? Many thanks Tom Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 18, 2022 Report Share Posted October 18, 2022 Hi @Tom1234 12 hours ago, Tom1234 said: when looking on the fixture library, I realise that this light is not on the list. I there a way of adding it? Yes there is - your best option is to email a link to your fixture's English manual to fixturesupport@zero88.com. We will then be able to provide you with a fixture file for you to load into your Jester ML24. It is worth noting that if your fixture has a simple mode such as 3-channel RGB, you will be able to use the simple LED fixtures that are included in the Jester ML24. These can be found in Assign Fixtures -> Add Fixtures -> Fixture Library -> Standard Fixtures -> Conventionals If you have any questions, please let us know. Edward Quote Link to comment Share on other sites More sharing options...
Tom1234 Posted October 18, 2022 Author Report Share Posted October 18, 2022 Hi Edward thank you very much. Along the similar lines, is there a way to see how many channels a fixture is taking up from the desk or would one have to read that from the light display screen. Cheers Tom Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 19, 2022 Report Share Posted October 19, 2022 Hi Tom, 11 hours ago, Tom1234 said: is there a way to see how many channels a fixture is taking up from the desk or would one have to read that from the light display screen. When patching fixtures into the Jester, the number of channels used by a fixture is usually displayed at the end of the fixture's name. For example "12Ch". Edward Quote Link to comment Share on other sites More sharing options...
