dandev Posted March 28, 2023 Report Share Posted March 28, 2023 I made a bunch of cues, and at cue 4 I recorded an effect into it. In all of the other cues after cue 4, the effect continues. How can I disable this without having to re-record my cues, as well as how to prevent this problem in the future? Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 28, 2023 Report Share Posted March 28, 2023 Go into the first cue where you don't want the effect to run (probably cue 5). Effect->No Effect Update, but ensure SmartTag is turned off (blue stripe). Subsequently make sure SmartTag is turned back on if that's your usual programming state (usually it will be). This has most likely happened if you set the intensity to zero on the fixtures in the effect, then with SmartTag on, the Effect Off instruction won't have been recorded. Quote Link to comment Share on other sites More sharing options...
