Zulu Posted May 14, 2023 Report Share Posted May 14, 2023 Hi, im using FLX S24. I have a scene lit, and I want to use playback flash but to momentarily broadcast a new scene, which is a mixture of new (higher intensity) lights, but also zeroing other lights to intensify the momentary flash. Something to do with priorities? Help! many thanks, Dave Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 14, 2023 Report Share Posted May 14, 2023 Hi Dave, If you hold Z/SHIFT, and tap a playback’s button, this will “Solo” the playback (if the playback only contains a single cue). Does this achieve what you’re after? Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Zulu Posted May 17, 2023 Author Report Share Posted May 17, 2023 Thanks, Ed. This sounds perfect… I’ll try it tomorrow. cheers, Dave Quote Link to comment Share on other sites More sharing options...
Zulu Posted May 17, 2023 Author Report Share Posted May 17, 2023 Ed, I tried this…. Perfect! Exactly what I was looking for. many thanks, Dave 1 Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 18, 2023 Report Share Posted May 18, 2023 Hi Dave, 14 hours ago, Zulu said: Ed, I tried this…. Perfect! Exactly what I was looking for. Brilliant - pleased to hear it. It is possible to configure playback buttons, so that they solo when pressed, rather than flash. This means you don't have to hold the Z/SHIFT key to access solo. To set a playback's button to solo, hold SETUP and tap the playback button you wish to configure. Then from the Button Function options at the bottom, choose Solo. Hope this helps, Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
