Forgive me if I've misunderstood the original post, but following this, here's a fixture file.. With this, we're using sub-fixtures instead of regular parameters in one single fixture like other fixtures would. This allows you to separate two parts of what we want to achieve here - to use this singular fixture as having the 'Lamp' (Intensity) defined as your actual dimming light (in your case - two linked to the same channel), and then configure the 'Scroll' part separately of the fixture to be on a different address, achieving your initial wish to 'link' the scrollers to the 'Intensity' of your incandescent fixture, where both the Intensity and two scrollers (together) can be as far apart in the DMX universe as you need, but the lamp must be the lower address (meaning the scroll can only be a DMX address after the lamp). Note that if you define the Scroll part of the fixture to be on e.g. DMX 57, that will be the first scroller. The second scroller will therefore be on DMX 58, with the Intensity being anywhere you wish (e.g. DMX 3 - completely away from the scrollers), again 'linking' the scrollers to the intensity. You will need to replace the Dimmer fixture you currently have patched in for your intensity with this one, but don't worry - the lamp intensity will work exactly the same, but giving you the additional scrollers. The scrollers will then actively 'listen' to the intensity and when it is at 0, the scrollers will use Move on Dark. We can see this in action with the grey background of fixture 1 on the second screenshot - the Scroll1 and Scroll2 values were both moving on dark at that time. And remember to always back up your show file before making critical changes like this. When patching this new fixture in after loading the .ift via SETUP > Load > IFT File, a 'Part' column will be added to the Fixture Schedule. This will indicate the Lamp and Scroll parts of the fixture as described above. See pictures and fixture file (.ift) below... Lamp + 2 Scrollers.ift
yea as @Davidmk says I don’t think you can keep the dummy lamp dark, you might as well just patch a scroller. Is there any scope to duplicate DMX address patching? Can’t currently get my brain sufficiently off work to think this through but I’ll give it some thought.
kgallen started following Scrollers and Move on Dark
The scroller uses the intensity channel of the associated fixture to know when ‘dark’ (as I’m sure you’re well aware). Scroller probably only has colour attributes. You might have to patch the lamp+scroller and patch the ‘lamp’ to an unused DMX address then use that bogus lamp fixture intensity to control your move on dark. I think early days of my FLX I asked a similar type of question and it just came down to you need that linked intensity channel to support move on dark. I know you probably don’t have time or access but this is a candidate for having a play to see what methods can be used to fool the desk whilst maintaining a usable workflow. I don’t think anyone left here knows how the desk actually uses the fixture information under lamp+scroller to know what cheats are viable.
Davidmk started following Is there an archive of Zero88 software versions? and Scrollers and Move on Dark
