To clarify, for Update you need to get up the options box to turn off SmartTag. For FLX this is press and hold the Update key. -
kgallen started following Zoom par led and Stopping Movers after a cue with an effect running
Hi @Worcester RGSTech This is a common gotcha on ZerOS consoles. I don’t know the exact syntax on Solution, sorry, but assuming you have a fairly recent ZerOS then you need to Update the cue with Effect Off with SmartTag turned off. 1. Select the fixtures of interest 2. Effect Off 3. Update 4. Turn off SmartTag 5. Tap the Playback button holding that cue Almost certainly the blackout cue was recorded with SmartTag on in which case it doesn’t record the Effect Off instruction, just the fixtures going to intensity 0. This means your fixtures keep dancing when they are dark. Yep Jon and Edward are gone but there are user-folk on here who can still help you. -
If I record a cue running an effect in which movers are moving on a preset pattern, figure of 8 for example, does anyone know if there is a way of stopping them moving whilst blacked out in the next cue? I have tried multiple ways and the only successful method seems to be to record them in a position at a very low intensity when stopping the effect. I don't want them moving around whilst blacked out, especially as their subsequent cue will likely be in a static position as a special. I don't doubt that not so many months ago Edward or Jon would have been on with a solution. Alas we seem to have been hung out to dry these days.
Johnbel74 joined the community
@DMH@RJP The SPAM postings seem to be on the increase with over 40 in last 24 hours plus others highlighted but still on the forum. Please can some trusted forum members be promoted in a way to allow removal of these posts?
Hi @SoleJan Blue UP to the sky, green DOWN to the grass. (Blue means that channel intensity went up, green it went down.) White, it's a blocking value, purple it's tracked. Red from the programmer (highest priority), yellow for some other controller. Red background is Parked. Grey background (for a short time) is moving on dark. They're all here: https://www.zero88.com/manuals/zeros/desktops-windows/output-window#colours
Hey again, little thing to ask again about the Monitor. (btw, got Remote working via Emulator thanks for providing the link) In the attached file 5 of the Briteq Theatres intensity are marked blue while one is green. Is that to indicate a change from the previous Cue? My first thought was, it indicates dynamic change of Int. in a Cue i.g. like a ramp up effect, but the theatres dont have any like that on in the Cue. This is no problem but im interested as for why this is. Jan
Hi, This is probably a tagging issue. Are you trying to record the zoom change only and the fixture intensity is zero? Clear the programmer: CLEAR-CLEAR Change your zoom setting Press and hold RECORD until the record options box comes up Tap on SmartTag to make the stripe red Tap the required Playback button You should now find that the Playback (submaster in your words) moves the zoom - and only the zoom. If this achieves what you need then you should do some training on tagging and how SmartTag works. This is a video specifically on tagging, but it might be that you need some other backgrounders first if you're quite new to more advanced lighting consoles: Whole FLX S video training series:
Bonjour, J'ai vérifié tous mes submasters, En maintenant la touche view, tout est sur zéro .
Bonjour. Il peut être utile de vérifier le temps de propagation dans le playback que vous avez enregistré. Pour cela, maintenez la touche VIEW enfoncée et appuyez sur votre playback/submaster. Vous devriez maintenant voir la mémoire de votre playback, contenant le contenu du submaster que vous avez mentionné. Vérifiez que le temps sous le paramètre de propagation est à 0,0 seconde. J'espère que cela devrait fonctionner ? Archie (translated with google translate, apologies for any mistakes)
Bonjour, Je rencontre un problème en enregistrant mes pars LED avec zoom sur les submasters . 1 je choisis le focus souhaiter, je l'enregistre dans un submaster. 2 en l'envoyant via le fader du submaster, je vois le zoom bouger (ce qui n'arrive pas dans le master playback) Pourriez-vous me dire comment procéder ? Merci 👍
@Veit0r Agree so much with @kgallen. They are great desks and make so much possible. The logic is biased towards programming shows and running them on the button but you can turn all that off and take control yourself if you want to. Enjoy your journey of discovery and come back to this forum if you need help.
@Veit0r fantastic! That’s great to hear. Hope your events go well! Thanks for letting us know. You know where we are if you have any other queries. As we’ve found there are some tricky areas. These consoles are a lot more powerful than they appear from the outside - they look a lot like a simple old-skool lighting desk but because of full support for tracking, move on dark, overlaying playbacks with LTP and HTP, it can very quickly require much more experience and familiarity with more advanced concepts. I’ve seen from other posts that this can confound, confuse and frustrate users who haven’t yet gained that knowledge and experience.
Hi! Just a little follow up.. it works! Thanks - we are happy now. School is able to do all the programming for the artistic graduation now and I'm a lot more confident in helping out. Great to have both of you helping.
Davidmk started following Some channels altering their default intensity "by themselves"
I don't think I can actually help here - beyond asking dumb questions on the off chance you haven't already asked yourself them. So it's the actual default value, as in showing 69% yellow in the outputs window, the channel fader showing zero in the faders window (in channel mode), the UDKs released in the fader window (in playback mode)? What about in source mode - does the channel show D? Given how difficult it can be to set defaults (and get them to stick) deliberately, its hard to believe they got set accidentally (although a macro could do it). Is it, perhaps, down to dodgy faders - have you done a test mode start up? Then again, they didn't get parked somewhere along the line (red background)? (I did say dumb questions.)
I've had an odd thing happen twice now running 8.0.0. We use the desk to busk a number of looks from the subs and wings with static states on the UDKs, with program changes very infrequent and generally done by me. Last week I had a report of some lights being on unexpectedly and when I looked into it a number of fixtures had picked up default values of 69%. (Not the fixtures complained about however!) I saved the show and reset the values, doing some minor tidying up of default and home levels. However I reloaded the show I originally saved and all was as expected. Today I got another call and a different set of lights were sitting at 92% with all faders down (ther than GM, which still controlled them). A restore of my tweaked showfile put it back to normal. I'm thinking two possiblities here, firstly maybe the 2032 needs swapping out, or secondly someone new is driving the desk and they are more "experimental" in playing back the looks, having discovered an obscure bug in the process. Has anyone else encountered something similar?
SoleJan changed their profile photo
Alright thanks to you both, In my memory ZerOS Remote was just easier for remote programming and I've got a project where I'm not at the console while programming (and its easier to be remote there). I saw the keyboard shortcuts on ZerOS Monitor but with the Remote you had it on the display, like the syntax or the position grid. But I'm sure I'll figure something out.
Archie D started following Remote Control
Hi there. There is a specific ZerOS Monitor app that was produced for Windows. There is also a MacOS version if you prefer. However, there was not a ZerOS Remote app produced for Windows for public use (to my knowledge, I saw Edward using ZerOS Remote on Windows in a training video). Anyhow, ZerOS Monitor on a laptop or desktop does function as a sort of "remote", as it allows for keyboard shortcuts to be entered, such as R for record or U for update. They are downloadable at the links below provided by the ZerOS Software page on Vari-Lite's website. ZerOS Monitor (Windows): https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/zeros-monitor-2.0.0.zip ZerOS Monitor (iPadOS, iOS & MacOS): https://itunes.apple.com/gb/app/zeros-monitor/id1033159176 For Android, you can of course use the APK files listed in the thread, kindly provided by kgallen. If you prefer to look at the page to verify the download links: https://www.vari-lite.com/global/products/zeros-software
Well there is PhantomZerOS which is a full console for Windows. But I’m not aware of a monitor/remote app for Windows, only Android/iOS devices.
Thanks! So to run a Monitor like app you have to do it through a Android Emulator? There isn't one for Windows itself?
Hi Archie, thanks very much for the message and the update. Funny old thing you finding that on Ebay. Yes, still have the FLX and wing to go but I have now taken that out of the touring flightcase. I suppose I better get this advertisement revised now. Anyway best of luck with the dongle and glad it is all working for you.
kgallen started following Remote Control
See this thread for the Android apps:
SoleJan joined the community
Hello, I may be a little late for this, but what exactly was the reason for ZerOS Monitor to be removed from Android and ZerOS only funtioning on iOS? Is there another way of using external devices (preferably Windows) as a Remote? I Thanks up front. Jan.
