  1. Today
  2. Hi @kgallen Thank you, I'll give this a try. I'm running ZerOS 7.14.... the most recent version. I'm not sure that the Solution has SmartTag or whether it uses another name, but I imagine that it will be reasonably obvious. Thank you. Simon
  3. Hi @Worcester RGSTech This is a common gotcha on ZerOS consoles. I don’t know the exact syntax on Solution, sorry, but assuming you have a fairly recent ZerOS then you need to Update the cue with Effect Off with SmartTag turned off. 1. Select the fixtures of interest 2. Effect Off 3. Update 4. Turn off SmartTag 5. Tap the Playback button holding that cue Almost certainly the blackout cue was recorded with SmartTag on in which case it doesn’t record the Effect Off instruction, just the fixtures going to intensity 0. This means your fixtures keep dancing when they are dark. Yep Jon and Edward are gone but there are user-folk on here who can still help you.
  4. If I record a cue running an effect in which movers are moving on a preset pattern, figure of 8 for example, does anyone know if there is a way of stopping them moving whilst blacked out in the next cue? I have tried multiple ways and the only successful method seems to be to record them in a position at a very low intensity when stopping the effect. I don't want them moving around whilst blacked out, especially as their subsequent cue will likely be in a static position as a special. I don't doubt that not so many months ago Edward or Jon would have been on with a solution. Alas we seem to have been hung out to dry these days.
  5. Last week
  6. @DMH@RJP The SPAM postings seem to be on the increase with over 40 in last 24 hours plus others highlighted but still on the forum. Please can some trusted forum members be promoted in a way to allow removal of these posts?
  7. Hi @SoleJan Blue UP to the sky, green DOWN to the grass. (Blue means that channel intensity went up, green it went down.) White, it's a blocking value, purple it's tracked. Red from the programmer (highest priority), yellow for some other controller. Red background is Parked. Grey background (for a short time) is moving on dark. They're all here: https://www.zero88.com/manuals/zeros/desktops-windows/output-window#colours
  8. Hey again, little thing to ask again about the Monitor. (btw, got Remote working via Emulator thanks for providing the link) In the attached file 5 of the Briteq Theatres intensity are marked blue while one is green. Is that to indicate a change from the previous Cue? My first thought was, it indicates dynamic change of Int. in a Cue i.g. like a ramp up effect, but the theatres dont have any like that on in the Cue. This is no problem but im interested as for why this is. Jan
  9. Earlier
  10. jmd
    Zoom par led
    Merci 👍
  11. Hi, This is probably a tagging issue. Are you trying to record the zoom change only and the fixture intensity is zero? Clear the programmer: CLEAR-CLEAR Change your zoom setting Press and hold RECORD until the record options box comes up Tap on SmartTag to make the stripe red Tap the required Playback button You should now find that the Playback (submaster in your words) moves the zoom - and only the zoom. If this achieves what you need then you should do some training on tagging and how SmartTag works. This is a video specifically on tagging, but it might be that you need some other backgrounders first if you're quite new to more advanced lighting consoles: Whole FLX S video training series:
  12. jmd
    Zoom par led
  13. jmd
    Zoom par led
    Bonjour, J'ai vérifié tous mes submasters, En maintenant la touche view, tout est sur zéro .
  14. Bonjour. Il peut être utile de vérifier le temps de propagation dans le playback que vous avez enregistré. Pour cela, maintenez la touche VIEW enfoncée et appuyez sur votre playback/submaster. Vous devriez maintenant voir la mémoire de votre playback, contenant le contenu du submaster que vous avez mentionné. Vérifiez que le temps sous le paramètre de propagation est à 0,0 seconde. J'espère que cela devrait fonctionner ? Archie (translated with google translate, apologies for any mistakes)
  15. Bonjour, Je rencontre un problème en enregistrant mes pars LED avec zoom sur les submasters . 1 je choisis le focus souhaiter, je l'enregistre dans un submaster. 2 en l'envoyant via le fader du submaster, je vois le zoom bouger (ce qui n'arrive pas dans le master playback) Pourriez-vous me dire comment procéder ? Merci 👍
  16. @Veit0r Agree so much with @kgallen. They are great desks and make so much possible. The logic is biased towards programming shows and running them on the button but you can turn all that off and take control yourself if you want to. Enjoy your journey of discovery and come back to this forum if you need help.
  17. @Veit0r fantastic! That’s great to hear. Hope your events go well! Thanks for letting us know. You know where we are if you have any other queries. As we’ve found there are some tricky areas. These consoles are a lot more powerful than they appear from the outside - they look a lot like a simple old-skool lighting desk but because of full support for tracking, move on dark, overlaying playbacks with LTP and HTP, it can very quickly require much more experience and familiarity with more advanced concepts. I’ve seen from other posts that this can confound, confuse and frustrate users who haven’t yet gained that knowledge and experience.
  18. Hi! Just a little follow up.. it works! Thanks - we are happy now. School is able to do all the programming for the artistic graduation now and I'm a lot more confident in helping out. Great to have both of you helping.
  19. I don't think I can actually help here - beyond asking dumb questions on the off chance you haven't already asked yourself them. So it's the actual default value, as in showing 69% yellow in the outputs window, the channel fader showing zero in the faders window (in channel mode), the UDKs released in the fader window (in playback mode)? What about in source mode - does the channel show D? Given how difficult it can be to set defaults (and get them to stick) deliberately, its hard to believe they got set accidentally (although a macro could do it). Is it, perhaps, down to dodgy faders - have you done a test mode start up? Then again, they didn't get parked somewhere along the line (red background)? (I did say dumb questions.)
  20. I've had an odd thing happen twice now running 8.0.0. We use the desk to busk a number of looks from the subs and wings with static states on the UDKs, with program changes very infrequent and generally done by me. Last week I had a report of some lights being on unexpectedly and when I looked into it a number of fixtures had picked up default values of 69%. (Not the fixtures complained about however!) I saved the show and reset the values, doing some minor tidying up of default and home levels. However I reloaded the show I originally saved and all was as expected. Today I got another call and a different set of lights were sitting at 92% with all faders down (ther than GM, which still controlled them). A restore of my tweaked showfile put it back to normal. I'm thinking two possiblities here, firstly maybe the 2032 needs swapping out, or secondly someone new is driving the desk and they are more "experimental" in playing back the looks, having discovered an obscure bug in the process. Has anyone else encountered something similar?
  21. Alright thanks to you both, In my memory ZerOS Remote was just easier for remote programming and I've got a project where I'm not at the console while programming (and its easier to be remote there). I saw the keyboard shortcuts on ZerOS Monitor but with the Remote you had it on the display, like the syntax or the position grid. But I'm sure I'll figure something out.
  22. Hi there. There is a specific ZerOS Monitor app that was produced for Windows. There is also a MacOS version if you prefer. However, there was not a ZerOS Remote app produced for Windows for public use (to my knowledge, I saw Edward using ZerOS Remote on Windows in a training video). Anyhow, ZerOS Monitor on a laptop or desktop does function as a sort of "remote", as it allows for keyboard shortcuts to be entered, such as R for record or U for update. They are downloadable at the links below provided by the ZerOS Software page on Vari-Lite's website. ZerOS Monitor (Windows): https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/zeros-monitor-2.0.0.zip ZerOS Monitor (iPadOS, iOS & MacOS): https://itunes.apple.com/gb/app/zeros-monitor/id1033159176 For Android, you can of course use the APK files listed in the thread, kindly provided by kgallen. If you prefer to look at the page to verify the download links: https://www.vari-lite.com/global/products/zeros-software
  23. Well there is PhantomZerOS which is a full console for Windows. But I’m not aware of a monitor/remote app for Windows, only Android/iOS devices.
  24. Thanks! So to run a Monitor like app you have to do it through a Android Emulator? There isn't one for Windows itself?
  25. Hi Archie, thanks very much for the message and the update. Funny old thing you finding that on Ebay. Yes, still have the FLX and wing to go but I have now taken that out of the touring flightcase. I suppose I better get this advertisement revised now. Anyway best of luck with the dongle and glad it is all working for you.
  26. See this thread for the Android apps:
  27. Hello, I may be a little late for this, but what exactly was the reason for ZerOS Monitor to be removed from Android and ZerOS only funtioning on iOS? Is there another way of using external devices (preferably Windows) as a Remote? I Thanks up front. Jan.
  28. [NO ACTION REQURIED] Documenting here a problem I had on my Fat Frog and the repair required. This can equally apply to other consoles in the Frog range - and in time possibly other consoles with faders. Thanks to @Edward Z88 who provided support despite having moved on from Zero88 and @RJP for providing schematics. The background: I bought my Fat Frog new in 2006, so at this point it's 19 years old. It's largely in "as new" condition as I look after my kit. I've not used it regularly since 2015 when I bought my FLX, but it has had the odd outing, most recently in 2021. I've stayed on top of the CR2032 battery replacement and I'm blessed that the original floppy drive still works perfectly. All faders are still in pristine condition. The issue: This was an intermittent problem, so hard to narrow down. The usual range of channel intensity values shown on the Output Screen is 00-FF (FF in this case means "full" or 100%, not hexadecimal 0xFF). On occasion my console would only move from a low non-zero value, say 02 to 05 (percent) up to a maximum of around 94-98 (percent). I first saw this actually on the fixtures section with the thumb wheel (so not a linear fader), where the fixture intensity would only go up to 96%. Subsequent testing showed the same issue on the generics faders (including masters). Strangely this issue also showed when playing back a memory stack (where the memories had successfully been programmed with 100% intensity values). You can enter test mode by holding the F1 key whilst powering up. In this mode, I could see the 8-bit values of the faders (all of them on the console) would only travel between about 0x05 and 0xFA rather than 0x00 to 0xFF. OK, cut to the chase, what was the issue... After some testing internally, it was identified that the reference voltage rail for the fader banks was sometimes low. This VREF should be around +5V with respect to its AGND. Practically it will be around +4.8V (and I determined that it should not go below +4V for correct operation). On occasion this reference voltage was measured as low as +2.8V and this is when the issue presented. After quite some time this was tracked down to a failed 4.7uF/16V tantalum capacitor on the Submasters PCB that is used to decouple the VREF locally to this board. There is a similar capacitor on all of the boards with faders (or potentiometers) and they are all effectively in parallel across VREF/AGND, so a failure of any one of them would result in similar failure symptoms. After removing the Submasters board it only took a couple of minutes to replace the capacitor. In this case I used a 4.7uF electrolytic, which is good enough in this application - and had to lay it down as it was slightly taller and would have fouled the front panel. So far the issue seems resolved. Hope this might help others who may have a similar issue as our Froggy friends age more. Note: Essentially the same circuit is used everywhere in Zero88 (and likely other brand) consoles for reading the faders. The faders, usually 10K, have a VREF at the top, a GND (0V) at the bottom and the wiper goes via some 4051 analogue muxes and finally feed into an ADC channel on an embedded micro. Here are a couple of photos of the Submasters board and of the failed tantalum capacitor which is clearly discoloured brown when compared to similar components.
