  1. Today
  2. Last week
  3. Hello Kisi When you start creating a fixture file with Fine or 16 bit resolution, select Pan then select 16-Bit on the bottom line, then when you select OK, CH1 will be Pan and CH2 will be Pan fine. Then when you select CH3 and select Tilt, the Fixture creator will put Tilt as Ch 3 and Tilt Fine as CH4
  4. No worries, give me a few minutes. Edit: Send to your email Best, Charlie
  5. @Charlie Newman Can you please send the fixture to my email kim@eventon.no Thanks best regards Kim Simensen
  6. @Charlie Newman I know. We tried and the "fine tilt" and some other stuff its missing there.
  7. Thank you for this information, it definitely sounds like ZerOS Watchdog kicked in while loading the show file. It would have displayed a list of registers and then also a stack trace. Archie
  8. It was a crash dump (like a Linux shell window?) on the monitor. but then the monitor froze and i rebooted.
  9. Hi Paul, Saving the setup within the show file as well theoretically shouldn't cause any problems. If you can recall - when the console crashed, was it a black screen with a load of white text (ZerOS Watchdog kicking in) or did the console just completely freeze, preserving monitor output too? Let me know how you get on later with LF48TEST1.zos, it has a few things disabled/removed to see if anything in the show file itself is crashing the LF48. One of my theories for this was that because the Leapfrog 48/96 came with 2 DMX universes as standard, with an optional upgrade card while the Solution comes with 4 universes straight from the factory, that ZerOS was trying to index a universe from the Solution (3 & 4) that didn't exist on the Leapfrog when loading in the show file (if the optional upgrade card for 2 more outputs isn't present). Hence, U3 and U4 are disabled in that show file. However, it is just a theory and could be wrong. It's all about experimentation to see what works! I look forward to hearing from you, thank you. Archie
  10. Hi @kisi, welcome to the forum! I should be able to do this this evening for you, however you're also able to do this within the desk itself under "SETUP" -> "Add New Fixtures" -> "Create New Fixtures" Please let me know if you have any questions. Best, Charlie
  11. Need help to build a fixture file for my new light. Name of the light is Maverix - BSW 350 Can someone help me, I use a Vari lite FLX S24 console attached is the dmx chart. Best regards Kim Simensen Maverix-BSW 350.pdf
  12. Hi Archie. I will try later. I wonder if, when i saved, i saved the showfile and setup, rather than just the showfile. Thanks Paul
  13. Earlier
  14. Hi Paul, Thank you for providing your show file. Please could you see if this file loads into your Leapfrog 48? If it doesn't and the console crashes, what does the console show on the external monitor? Please don't panic that your cues/playbacks are missing by the way for this file - I'm simply juggling things to see what does what. Thank you. LF48TEST1.zos
  15. Showfile from Solution that wouldn't load on Leapfrog. WOZ-20125a.zos
  16. Hi Paul, Sounds good, if you’re still experiencing difficulties tomorrow, please could you upload your showfile here if that’s okay? I can then see if I can potentially find anything on PhantomZerOS and my Solution XL (though if it loads fine onto a Solution and not the Leapfrog 48, I might be lost) When the Leapfrog 48 crashed, was it a ZerOS Watchdog message that appeared? I’m curious as to what it said, or what the crash behaviour was like.. Thank you and have a good rest of your day. Archie
  17. Hi Archie, Yes, I thought the solution and Leapfrog48 were the same. Both are running 7.14.4. File is a .zos. I have tried loading into phantom and saving, and will try on the desks tomorrow night. Thanks Paul
  18. Hi @Muller Light, ZerOS showfiles are cross-compatible between ZerOS-based consoles, only with some data not being loaded (for example when you load a FLX showfile into a Solution, some data from the FLX won’t be loaded in). However, this won’t happen because Leapfrog 48 and Solution are identical, you’ll only receive a warning due to the different console types, but all data will be passed over. What software version are both of your consoles running? To see this, in the Output Window click ‘Other Windows’ (top left) -> System Information -> Software Version. What format is your showfile? Is it a .isf, or .zos? Many thanks, Archie
  19. Hello all, I have a Solution and tried saving a show and then loading it on a Leapfrog48. The Leapfrog crashed and had to be rebooted. Is there a way of saving a show on the solution that makes it compatible with a leapfrog? And vice versa? Thanks
  20. Hi Simon, To adjust cue delay times on Solution, the best method is to use the MFKs (Multi Function Keys) instead of the encoder wheels. Navigate your cursor using the mouse or arrow keys to an 'Up' or 'Down' field, then tap ENTER to start editing the time. On the top right MFK, tap 'Delay'. It will now have the red LED lit, with the white background to show it is selected. Type in a time using the MFKs or an external keyboard, then hit ENTER again to submit this. For your instance editing the 'Down' field, the down delay has now been applied to your cue. You also have the option to do this at the same time when editing a regular up or down fade time for a cue for efficiency. When editing a fade time, simply switch between 'Delay' being selected or not, and when pressing ENTER to submit these changes, both changes for the regular fade time and the delay time will be applied in one go together. I hope this helps, feel free to ask any other questions you may have. Archie
  21. Hi Simon, Good to hear it seems to have fixed itself. I've just popped in to leave a few comments. You may have accidentally knocked the intensity encoder wheel slightly when making changes, so when re-recording default values with RECORD -> HOME -> Default, the intensity information is also included in the defaults of the fixture. Were you using RECORD -> HOME -> Default to do this after changing the intensity to 0%? This next bit is unlikely, but did the 'Intensity' selection button have a red indicator instead of blue? If it was blue, that intensity information won't be recorded into the defaults, so when you CLEAR CLEAR, the fixture will still go back to the original intensity default value. An image is attached with 'Intensity' under 'Attributes' having a blue indicator. The reason I say this is unlikely is because when you make a change (intensity in this case), when tapping RECORD, the changed parameters (which are therefore tagged) will be automatically in red to show they are selected. Though with this being said, in the image you have provided while trying to change fixture 5's intensity back to 0, 'Intensity' has a red indicator... Correct - the yellow D in 'Sources' as opposed to 'Intensities' indicates the intensity is coming from a default value of that fixture. A red P in 'Sources' indicates a manual programmer adjustment or modification. All in all, it is sorted, but I just thought I'd provide little segments of extra information in case anybody reading this isn't sure. Have a great week Simon. Kind regards, Archie
  22. Hmm, well that's annoying. It seems to have reset itself. I've finished working & gone back to the -1 cue at the top and all is restored. You can see on the photo above that I was on this cue and the MH lights (108, 109) had a hard 0 value, while I was trying to reset Ch5. Now, all channels are blank as it should be. Happy to delete topic if that's appropriate.
  23. Final dress rehearsal for panto tonight & just tweaking a few timings. How do I get to adjust Down Delay on a cue. When I click on Up or Down timings, I get Up Fade, Up Delay, & Down Fade on the scroll wheels but can't get to Down Delay - tried shift but can't think of anything else. Simon
  24. I was changing defaults on my moving head lights and now fixture #5 has a Default intensity value of 5. (ie. on the source screen it has yellow "D") I tried re-saving it to zero but it won't stick, reverting back to 5 when I clear, clear. Settings are as shown, and I've tried variations of tagged vs selected fixtures. Any suggestions what I'm doing wrong? I don't think any other option for the yellow D applies. Simon.
  25. I think unfortunately we've come to the stage where none of us trust the releases to a point where we want to test them live or whilst doing something due to the instability issues we've had.
  26. Thanks for that. You haven’t heard when the update is due. Although it’s only fixes it may address the problems I’m having
  27. Going back a version shouldn't give any problems with the desk however you do, obviously, lose any new features and there is, potentially, a risk that your show files do not load. In practice, if you haven't used any of the new features, these probably won't bother you, 7.14.4 was the final release for the legacy desks (Frog2, LeapFrog, Solution, Orb) - You don't want this version. You want 7.14.3 for FLX & FLX S and the main difference is that you will go back to a maximum of 48 fixtures and fewer playbacks. Make sure you backup you v8 showfile. If you have used fixture numbers or playback numbers greater than the v7 limits then edit your show file to fit v7 and back that up to load after installing v7 The beta test forum for the new version (currently known as v8.0.0 build 11) seems to have been greeted with general apathy, possibly explained by being released when pantomimes are prevalent. There are no new new features and it consists of bug fixes for live version (v8.0.0 build 8). I don't know why other testers have failed to respond - for myself, I'm a full FLX and LeapFrog user and I'm not very interested in the newer versions now that FLX S has become the focus - I prefer to stick with v7 for now but might make a move to Chamsys. There has only been one tester response. This may have been on an FLX S and was favourable but did not cover any programming functions.I suspect FLX S users are under represented among beta testers.
  28. I down loaded 8 last year and there are several problems with this software. Move on Dark is very problematic at the moment When programming a blackout the desk crashes I have read that there is an update due and is in beta at the moment when will it be released. In the short term I am considering reinstalling 17.14.3 or 4would there be any adverse problems in doing this
