- Past hour
mxmwall7 joined the community
Paullex492 joined the community
If you’re in cue-only mode then I thought the console records ‘everything’. In which case your ‘No Effect’ should have worked regardless. Maybe that’s not how ZerOS works! In cue-only I wonder if move on dark can ever work. Hmmm. Others more experienced with cue-only may know! -
Archie D started following Forum Software News - Spam Protection
Hi all. I just wanted to share this news with you regarding Invision Community, the forum software that this forum runs. Obviously, spam has been a massive issue for a long time on this forum, including many other forums as well. However, I have recently had a look at their plans on their website, and I noticed on every plan there is 'Spam Protection' which utilises Artificial Intelligence to detect it and it is 'coming soon'. Regarding this, I'm not sure if when it becomes available an admin has to enable it via the administration panel, or if it automatically gets enabled. (We can cross that bridge when we need to). I'm also not sure what paid plan this forum is on for Invision, which determines what level of AI Spam Protection we get here (standard/enhanced). I have attached an image below outlining the AI Spam Protection offered in the plan(s) provided by Invision. If this comes relatively soon, some of our problems with spam could be sorted. When it does come, it would likely result in the Invision Community software having to be updated for the forum, where an administrator would have to do so. I hope this is of interest!
Sven76 started following ssh into console?
Hi friends, does someone know if there is a way to ssh or telnet or rlogin into the console? As the console is legacy and now also no new SW will be developed I'm curious and would like to look around a bit 😉 Best regards! Sven
Somehow you have to get a "No Effect" instruction in there otherwise even if your next movers cue is at a new position, they'll just start dancing around that new position. I'm not familiar with Solution but as it's a "modern" ZerOS console (i.e. post Frog2/LF94/ORB) I would expect it to have Smart Tag, assuming you're not in "Cue Only" mode. So I'm not clear why your Record and Update options boxes don't show a usable Smart Tag button. -
Davidmk started following Bug and crash on flx s48 - ZerOS 8.0.0 , New ETC Coloursource V Zoom PAR and Remote Control
ETA if my instructions are not clear, Edward documented the process in this paragraph (although again for FLX series). As he says, you might need to Track Forward, depending on where your cue is programmed/when you do the Update process: -
