  1. Past hour
  2. Hello, Question for FLXS24: I have two transmiters HF , one is Lumen radio Luna WDMX , the other is Electroconcept HF. With Luna the ideal signal DMX is "Continu" but with Electroconcept HF is "Delta". I have micro signal cuts in "Continu" with my Electroconcept , why ?? coupure ligth02.MOV
  3. Yesterday
  4. Hello @alg, Move on Dark can be enabled via entering your playback's settings (hold SETUP + Tap Playback's button) -> Move on Dark -> Enabled. The 'General', 'Chase', 'Raise and Lower' etc. that you see along the top are tabs to access groupings of playback settings, they aren't buttons to adjust actual settings. By default, when opening a playback's settings window, 'General' will always be the first tab selected (hence you see General every time you open the window), as they are general playback settings which aren't necessarily specific to other tabs such as 'Raise and Lower' or 'Chase'. If you're perhaps thinking of playback defaults found in SETUP -> Defaults -> Playback Defaults, these settings will only be applied to newly created playbacks and will not change existing ones. (D:3.0) in a fade time cell of a cue indicates a delay, with the time before it (0.0 in your case) indicating the actual fade time. If a cue had "5.0 (D:2.0)" in the "Up" cell, when going into that cue the console would delay executing the fade for fading up lights in that cue for two seconds, then proceed with the five second fade. This can be useful in cases for example where you don't want a moving light to come up until it has actually snapped into its position to prevent seeing it swoosh across stage during an intensity fade up or for staggering fades. Hope this helps, if you have any other questions please don't hesitate to ask. Archie
  5. I have been plotting a show and found that I couldn't select "Move on Dark". It appear that at some point earlier the playback setting had been set to "General". Having plotted the show found that I needed Move on Dark but each time I made the change in Playback Defaults and saving it and closing defaults, the next time I looked in Playback Defaults it had been changed back to "General"! Any ideas why I can't select Move on Dark after plotting a show? I have also had a problem with another, the Colour fade time default, this had been set to 3 sec. Again after plotting I found that I needed to change the time to 0 secs. This changed on the Q stack page but had (D3.0) on the Q line as well as 0.0. It appears that the default was held and was overriding the 0.0 setting I had entered. To get the fade to work as I wanted I had to deleted the Q and reprogramme it with the Colour fade time as 0.0. The (D 3.0) was removed and the fade working correctly. Again any ideas on what was happening here. I'm not sure if these are related problems or separate
  6. Last week
  7. Hi all - unfortunately, I fear that this post may not get very far as most Frog 2 users have completely moved on (to my knowledge), but here goes.. On my Frog 2, I wish to access the ZerOS Startup Tool. Usually, you'd keep tapping F1 while the console is booting. If I do this on my Solution XL, it works as expected. Frog 2, nope... After the console's blue BIOS splash screen on the external monitor saying "Loading, please wait..." disappears, I keep tapping/holding F1 but the console boots straight into the main ZerOS application. The tapping/holding down of F1 is mentioned both in the online manual, and in a comment by Simon (original software developer for Frog2OS - that's ZerOS now). One theory that I've been thinking about - usually when updating the console with a bootable USB drive (old method), a screen would appear with an 'Update Software' button, I think that is using the Startup Tool application on the console's CF card (separate from the main ZerOS application). Even when I plug in a bootable USB or use the original 7.8.2.39 software CD to try and bring that update window up, still nothing. My conclusion is that the startup tool application doesn't actually exist on the desk's CF card. At some time, I plan to open the console and extract the CF card, pop it into my CF reader and see if the Startup Tool application exists on it. If it doesn't, I think I would be able to extract it from the Solution CF card (from memory the Startup Tool is from 2007 across all desks, so I think it should work fine) and put it on the Frog 2 one. Before I do that, are they any ideas anybody may have as to why this is happening? Many thanks for any assistance with this. Archie
  8. Earlier
  9. Just replying to bookmark this in my account for when I need the Apps on a new phone.
  10. Following the problems we've had with our FLX and knowing that a bug fix was going to be released some time I check the web site about once a month just to see if if anything had been released. We'll get it loaded next month as we've got a hire in at the moment and see how it performs on the next show.
  11. @Phil Kiernan How did you hear about this? It passed me by. Not that I care much, I didn't upgrade to 8.0.0 and probably won't risk 8.0.1. @kgallenI'm going shopping for ChamSys once the new tax year starts.
  12. Ah... Secret Squirrel releases now then is it... https://www.vari-lite.com/global/products/zeros-software https://vari-lite.s3.eu-west-1.amazonaws.com/graphics/technical/documents/ZerOS-8.0.1-release-notes.pdf
  13. New version was made available on March 3rd and is on the web site. Anybody had time to download and try it?
  14. Hi Ian, That's great news, glad to hear you got it sorted. Have a good day, Archie
  15. Archie, Many thanks for your reply. After reading your reply above, I swapped from selecting all the fixtures and applying a default, and stepped through all fixtures one by one and applied the default also fixture by fixture. As I did I could see some colour information that way. All working now - fades occur as expected - some blackout cues had to be rebuilt - but overall we are now working. I've learnt something new - I had never checked or tested the default settings before, and I am delighted it now works as I expect it to. Only change to workflow is creating new scenes I now have to select a fixture and chose the colour I want first, as of course the intensity comes up black now. But easily manageable. Reading the old threads led me down the path of 'Select all' Spin all colours to '0' 'Record' 'Home' 'Defaults' - which was not applying default to black on all fixtures. Changing to 'Select Fixture 1' 'Spin all Colours to 0' 'Record' 'Home' 'Defaults', and then 'Fixture 2' 'Spin all Colours to 0' 'Record' 'Home' 'Defaults', and so on was the solution. Thanks again Ian
  16. Hi @Ian_p, Please could you upload your showfile here? We may then be able to figure out if it's a problem with the fixture itself, or if the fixture has some funny channel on it in the profile causing this erratic flashing behaviour, thank you. The previous 'Edit Fixtures' window to see and change defaults of fixtures was removed in ZerOS 7.9.3 in favour of the new Fixture Schedule section of SETUP. To see a fixture's defaults, you could select the fixture(s) and page through the different attributes and see each individual parameter value on the internal touchscreen of FLX S.
  17. Good afternoon @Richard Elv, You can purchase a Phantom ZerOS Unlock Dongle from one of the distributors, or from here on StageGear. For outputting DMX with Phantom ZerOS, the Unlock Dongle must be plugged into your computer. If it is unplugged, DMX output will stop until the dongle is present again. Regarding methods of actually getting DMX out of your computer from Phantom ZerOS, you have two options. The first, is to output over the network using protocols such as ArtNet or streamingACN. The second, using a USB to DMX device (ones which support the ENTTEC protocol). Personally, I recommend the ENTTEC DMX USB Pro, which is generally considered to be a very high quality device and can be configured straight from ZerOS in SETUP -> Devices. Each of these devices will output one full universe of DMX. When running Phantom ZerOS as a FLX, you have access to 16 full universes of DMX (8192 DMX channels) over 64 patchable universes. If you're already used to using FLX, using a Phantom ZerOS Unlock Dongle will be ideal as it will give you the front panel you are already familiar with - just virtually. This can be used with a touchscreen, along with the external monitor for multi-touch functionality. Yes, the ZerOS Wing can be used with Phantom ZerOS running on a PC via USB as if you were using it with a physical console, therefore you will be able to use it across both your FLX and Phantom setup. Using a ZerOS Wing is the best option to give you more faders at one time. I hope this helps, Archie Bonjour @Richard Elv, Vous pouvez acheter une clé de déverrouillage Phantom ZerOS auprès de l'un des distributeurs ou directement sur StageGear. Pour la sortie DMX avec Phantom ZerOS, la clé de déverrouillage doit être branchée à votre ordinateur. Si elle est débranchée, la sortie DMX s'interrompt jusqu'à ce qu'elle soit reconnectée. Pour récupérer le signal DMX depuis votre ordinateur avec Phantom ZerOS, deux options s'offrent à vous. La première consiste à utiliser le réseau via des protocoles tels qu'ArtNet ou streamingACN. La seconde, à utiliser un convertisseur USB vers DMX (compatible avec le protocole ENTTEC). Je recommande personnellement l'ENTTEC DMX USB Pro, généralement considéré comme un appareil de très haute qualité et configurable directement depuis ZerOS dans le menu CONFIGURATION -> Appareils. Chacun de ces appareils génère un univers DMX complet. Lorsque Phantom ZerOS est utilisé comme FLX, vous avez accès à 16 univers DMX complets (8192 canaux DMX) répartis sur 64 univers patchables. Si vous utilisez déjà FLX, l'utilisation d'une clé de déverrouillage Phantom ZerOS sera idéale car elle vous permettra de retrouver virtuellement le panneau avant que vous connaissez déjà. Vous pourrez l'utiliser avec un écran tactile, ainsi qu'avec un moniteur externe pour une utilisation multitouch. Oui, la ZerOS Wing est compatible avec Phantom ZerOS installé sur un PC via USB, comme si vous l'utilisiez avec une console physique. Vous pourrez donc l'utiliser à la fois avec votre configuration FLX et Phantom. L'utilisation d'une ZerOS Wing est la meilleure solution pour disposer de plus de faders simultanément. En espérant que cela vous soit utile, Archie
  18. Bonjour. Merci pour cette réponse claire et complète. Où peut-on acheter une clé de déverrouillage pour zérOs phantom et un d’ongle usb/xlr compatible en France? Je suis professionnel. Est ce que le Wing est utilisable avec zerOs phantom comme si il était raccordé sur Flx? Pour être complet dans mes demande j’ai besoin de temps en temps d’ėtendre ma Flx avec quelques Fader supplémentaires et je comprend d’après vos explications que le mieux c’est le wing. Mais j’ai également besoin bien plus souvent d’une autre console indépendante. Je cherchais une solution pour éviter d’avoir à multiplier les produits. Un grand merci pour vos réponse. cordialement Richard
  19. All, I've read all the threads I can about default settings - but I'm still having issues with an intermittent flash to white when fading between cues. Worse if the fade is more than a second. FLX S24, V8 software, using playback 0 in a theatrical cue stack. All conventional dimmer lanterns are on page 1 and 3 - no issue with these. All LED fixtures are on page 2 for convenience. I select all by holding first channel button and pressing the last and then I can see RGBW on the inbuilt screen - moved these to 0, press 'Record', 'Home', 'Default'. Only it doesn't seem to work. Still getting the flash - but only sometimes not every fade which baffles me. Do I need to set default fixture by fixture...? Is there a way to look at the config of a fixture and see what the defaults are? At present I seems I can only overwrite the default - without seeing its present state. Any assistance would be gratefully received! Cheers Ian
  20. Hi @Richard Elv, Welcome to the Zero 88 Forum! Ultimately, it is highly recommended to use a ZerOS Wing to expand the available faders that can be used at one time on your console. However, using another console such as the FLX S24 is possible, but quite limited in comparison to a Wing. For instance, with this method, when you bring up a fader of a fixture on the FLX S24, it won't automatically be selected on your main FLX console, whereas on a Wing it interacts with the console and does select it automatically (depending on the 'Auto select channels' setting in SETUP -> Settings -> Operational -> Auto select channels). You also won't be able to do record, delete, SETUP + Tap playback button etc using the method described below, DMX Input. For using a FLX S24, you will need to configure one of your DMX output ports on the main FLX to be a DMX input instead. To do this, go to SETUP -> Universes, and tap 'DMX in' on the DMX output you wish to be a DMX input instead. On the FLX S24, you can patch in a bunch of dimmer channels (I recommend patching in the maximum available on ZerOS 8.0, which is 96). Then, connect the first DMX output port on the FLX S24 to your defined DMX input on the main FLX. You will need an adapter for the correct XLR connector to link the consoles together as they are both female XLR outputs. After this has been done, you now have a 'DMX In' column in your Fixture Schedule within SETUP. This lets you define a DMX In address for each individual fixture patched in, so when the console receives DMX data from the defined DMX input port (e.g. I raise channel 1 on the FLX S24 which has DMX address 1 -> FLX receives that data -> Fixture 200 in the FLX has a DMX input address of 1 -> Fixture 200's intensity raises), it will respond as configured. For playbacks, you can set a playback's DMX input address via SETUP -> Triggers -> DMX In. From there, you can tap 'Add' to add a playback to configure ready for DMX Input. In the example below (image attached), I have set Playback 1 on a FLX to be raised and lowered with DMX input address 25 coming from a FLX S24. I have done this so my first page of dimmer channels on the FLX S24 control fixtures, whereas the second page controls playbacks. (1-24 fixture control, 25-48 playback control). If you wish to use the Channels/Playbacks switcher button on the FLX S24, you could set up 96 dimmer channels (4 pages of dimming), use the first 72 (3 pages of dimming) as fixture control, but individually record each of the remaining 24 dimming channels at full as a playback each (playback 1-24), and on the main FLX you set the DMX Input address for each of your playbacks to the last page of dimming on the FLX S24. If you require control of more than 24 playbacks, you could go back further than the last page of dimming and use some of the third page too of the FLX S24. Overall, the ZerOS Wing has been designed to interact with the FLX or any other ZerOS console, and was produced for the reason of adding extra faders that can be used at one time. Using DMX Input is rather limited, so my recommendation is to use a Wing. But, I hope this helps, and if you have any further questions please don't hesitate to ask. Apologies for not translating, I figured if I did then this message would be colossal. Archie
  21. Bonjour Est-il possible d'étendre les fadeurs sur Flx avec une autre console s24 par exemple ? Avoir les mêmes fonctions qu'un Wing mais au moyen d'une S24 une fonction maître esclave cordialité Richard
  22. Worked like a charm, many thanks.
  23. I’ve got one of these. Make sure you are on a modern version of zeros and search for the showtec act fresnel 150 RGBAL. That is a library fixture. You can then edit it and rename to the act profile as it has an identical DMX patch. Let me know any problems. Link to the manual below if you’re not sure how to edit and rename fixture. The only thing you need to change though is the name. Also don’t use RDM or rigsync as that will complicate things. https://www.zero88.com/manuals/zeros/patching/add-fixtures/edit-export Brian
  24. I'm trying to install this fixture on my FLX S48, but can't seem to find it on the ZerOS library. Does anyone have or know where I can find the patch? I'm not experienced enough to manually install it myself.
  25. Archie D
    Chauvet P7
  26. Desgeorge
    Chauvet P7
  27. kgallen
    Chauvet P7
  28. kgallen
    Chauvet P7
  29. Desgeorge
    Chauvet P7
