  1. Yesterday
  2. Thank you for letting me know. I have informed our website team, and have emailed you a download link for the software.
  3. Thanks again for your answer. Yes, I visited this page, but the links are down, they redirect to https://www.vari-lite.com/global/home?brandRedirect=1
  4. All of the software/fixture library files can be found here... 500 SERIES CONSOLE | Vari-Lite Hope this helps.
  5. Hello afx I see That you re using a IPad Pro 13 ”… is it interesting to have a 13” images ? Having more information on screen ? or other screen dimension looks to be good too ? This question is not about price ! 13” look to be bigger on hands and using on stage ? thank a lot eric
  6. Thank you very very much! Would you know where I could find other useful files for this model? I'm thinking fixture libraries, update files, etc. Have a nice day!
  7. Hi @EuLightTech Welcome to the forum. Manual for the 500 Series consoles: 300 and 500 Series Console Manual.pdf Hope this helps.
  8. Hello everyone, I recently got an old Strand 520i console from the 500 series. I'm looking for the operator manual, but I couldn't find it anywhere. All I found for now are some specifications documents of 4-5 pages that don't explain how to operate the console. Most of the websites that appear in my internet researches are down, except for Vari-Lite's one, but the page for this console does not contain any downloadable file (or the links are down). Would someone happen to have something to help me? Best regards.
  9. Last week
  10. Ok, thanks, kgallen and Ed. Big help. Cheers.
  11. Well spotted. I have reached out to our gel database provider regarding this. Please let me know if you have any questions.
  12. One thing I noticed when doing compilation was in the Piety mood folder Lee 707 was incorrectly labeled as ultimate frost which should be ultimate violet. I use ultimate violet as a brighter colour than Lee 181 congo blue. The andoid Lee Filters app has Lee 707 as Ultimate Violet. No uppercase in mood boards but uppercase in other sources.
  13. I am using the Pluto 2000 at a show in a UWA theatre, they were patched into an ION desk using the etc library. The Pluto 2000 strobed when trying to use pan so it looks like an undocumented firmware change in the display control board in three Pluto 2000 zoom wash I recently replaced. Wil have to chase up the service centre. The fixtures worked ok in 16 channel mode on the ION. Will have to wait 2 weeks to do more tests as The Gondoliers starts a 2 week season on Thursday.
  14. Problème résolu, simplement un câble USB défectueux. Merci
  15. Bonjour, j'utilise la version 714.2 Mais la configuration tactile ne fonctionne pas, j'ai bien la croix sur mon écran tactile ,mais impossible de le configurer. J'ai pourtant bien lu la documentation et cet écran est pourtant compatible avec la flx s48
  16. Salut @jmd Tout d’abord, assurez-vous que votre FLX S48 exécute un logiciel à jour. Si vous n'êtes pas sûr de la version utilisée par votre console, veuillez me le faire savoir. Ensuite, veuillez calibrer le moniteur externe. Veuillez consulter le lien ci-dessous pour plus d'informations, notamment sur la marche à suivre si l'écran tactile ne répond pas... https://www.zero88.com/manuals/zeros/setup/settings/displays#calibration Si l'écran tactile ne répond toujours pas, veuillez fournir un lien vers la page Web de votre moniteur sur le site Web d'Iiyama, et nous pourrons enquêter plus en détail. Hi @jmd Firstly, please ensure your FLX S48 is running up to date software. If you're not sure what version your console is running, please let me know. Then, please calibrate the external monitor. Please see the link below for more information, including what to do if the touchscreen does not respond... https://www.zero88.com/manuals/zeros/setup/settings/displays#calibration If the touchscreen is still not responding, please provide a link to your monitor's webpage on the Iiyama website, and we can investigate further.
  17. Bonjour, J'ai un écran tactile ilyama prolite t2452MSC et je n'arrive pas à le configurer. J'ai pourtant suivi la documentation mais l'écran tactile ne répond pas. Vous pouvez m'aider ce serait génial merci 🙏
  18. I have patched the Chauvet Intimidator Spot 155 in both modes, and on FLX S this is correctly defaulting to 0% intensity, and correctly homing to 100% intensity. If the fixture is defaulting to 100% on your console, this intensity percentage will be shown in yellow in the Output window. If this is what you are seeing on your console, this confirms the fixture's default values have been edited in your show file. If you wish to reset all fixture defaults back to their library values, tap DELETE, and then tap the Home icon. You can then confirm you wish to remove all custom default values. Please let us know if you have any questions.
  19. I have checked the Show Technology Pluto 2000 in PERSON2 mode, and the DMX map/parameter defaults in the ZerOS Library appear to match the information in the fixture's manual. The Shutter/Strobe parameter is correctly defaulting to 0 (no strobe). Fixtures in the ZerOS Library can be extracted in the .zfix format. However, the "old" Zero 88 Fixture Editor cannot open .zfix files. As @kgallen & @Davidmk have mentioned, fixtures in the ZerOS Library can be edited in the ZerOS fixture creator. Have you tried controlling the fixture in any of the other modes? Does the same issue occur in all modes? Please let me know if you have any questions.
  20. You can set the intensity of a fixture then RECORD HOME will allow you to reprogramme the Home or Default values. https://www.zero88.com/manuals/zeros/controlling-fixtures/defaults
  21. Hi. I have an FLX S24, and am a novice to moving lights. I have a pair of Chauvet Intimidator Spot 155. I’m wanting the default or home state to be dark. It’s currently defaulting to 100%. does anyone have experience of how to fix this? many thanks.
  22. I have been trying another way to find colours within Lee Filters Mood Boards and have cut and pasted the moods with a description for each one from the Lee Filers web site and The Art Of Light publication. I have not done the Inspired By ones yet. Lee Mood Boards ZerOS 7 Screenshots.pdf
  23. This might be helpful as well... https://www.zero88.com/manuals/zeros/patching/add-fixtures/edit-export
  24. You should be able to use the on-desk Fixture Creator to do this (although I never have!). Let me see if I can find a manual reference… https://www.zero88.com/manuals/zeros/patching/add-fixtures/fixture-creator
