13
Everything posted by Archie D
JesterML LCDs blank [still backlit] and MFK lcd top row malformed
Archie D replied to Archie D's topic in Jester Range
--Rewritten for clarity-- Thank you, I do look forward to the news of this, apologies that I was no use of advice. My issue, with the help of others, was thought to be a section of a ribbon cable had come partially disconnected or loose, not allowing data to come through fully to the LCDs.. if not at all while still being back-lit. Not sure if that is the case or not but we shall hopefully find out, I still have yet to open my Jester ML yet again to find the issue.. been a bit busy over the holidays! Issue hasn't happened in some time though, still keeping an eye out for it. -
That is true.. I received a Juggler which had no PSU so I was stuck with the single one from the JesterML I have.
There was one on eBay a few weeks ago with a flight case, I think it has gone though. To get a genuine power supply, it could be a possibility to buy or search for a really really beaten up old desk, use that power supply and either grab spares from that desk/try to restore it?
Not sure what you could do with this or whether it's any help, but here is the original supplier and model of switching power supply that Zero 88 used for their desks. https://sinpro.com/en/product/show.aspx?num=441&find1=8 https://sinpro.com/en/product/pro_search_show.aspx?num=441&page=2&spcnum=4955
Is it possible that this was caused (even though you downgraded to a previous version than 8.0.0) by the show file being an 8.0.0 show file (e.g. you created the show file while on v8.0.0) instead of a show file of the version you downgraded to? I'm not entirely sure but could it possibly be the case?
Probably looks slightly different from when you saw it if the website had a partial redesign on the frontend after you saw it.
Thank you, I might have a go then. Best wishes, Archie -
Thank you very much for your advice. At the moment, I don’t feel confident enough to do this by myself so I think I will leave it for now, try and get my confidence up and look about doing it when I’ve got a bit more experience or I can ask somebody to help me. Thank you for your advice, I really appreciate it. Kind regards, Archie -
Don't worry, with the page you provided me with the 'common' subdomain, there are workarounds 😉 https://backstage.zero88.com/a-z Thank you very much.
Hi, an update. Not too successful, but partially. We lay the console down, unscrewed the six access screws holding the front panel on, (i also put the earthing wriststrap on before doing this), and upon opening the console there was no obvious disconnection of the ribbon cable but we pushed down the clips to make sure it was secure. One was solid, the other flexed a bit on pushing. We then closed the console up, securing one screw top and bottom in the middle of the set of screwholes and turned it on. All worked perfectly. So we turned it back over, put the four remaining corner screws in, turned it over, plugged it back in, the fault was back. Do you think I need to replace the clip that had some flex in it? Do you think that is the issue with the intermittent fault on the LCD displays? -
Ordered yesterday, arrived today. I'll see if I can do anything tomorrow with the desk. Thank you again for the advice. -
Thanks for your reply @kgallen, that's something great to go off if I take a look inside. Do you use an earthing wristband thingy when you open up your Fat Frog? -
Just an update - I've turned on the desk again to see if the issue had gone (due to intermittence) and I am now presented with this on the bottom LCD: However, when tapping C, B or P buttons, the top LCD goes back to normal instead of the offset lines as shown below: -
Hi all, I have an issue with my JesterML that seems intermittent. It appears to only have started having this issue since a few days ago. The issue is when I turn on and boot up the desk, the main LCD is blank (but still backlit), same with the wheel LCD. The top MFK lcd is showing content, but slightly malformed on the top row (see pics below). Bottom MFK lcd seems fine so far. This issue sometimes happens when I turn the desk on, and sometimes doesn't happen. DMX output still works fine, same with monitor VGA output from the back ports. Buttons all still work, so do the wheels, as the red LEDs in the buttons do change when I press them to the desired option I want to select. It's the LCDs that are the issue. Another thing to add is that on the top MFK lcd, when I select either Colour, Beamshape or Position, the four horizontal bars you see disappear and it just goes to how picture E shows. Picture A: Whole desk view Picture B: The MFK LCDs Picture C : Main LCD Picture D : Wheel LCD Picture E: four horizontal bars have now disappeared after selecting C, B or P Pictures are attached below. If anyone knows the problem here, I would be incredibly grateful if you could help me. Thank you. Perhaps it is a loose connection inside, but maybe something damaged? I'm not sure. I wanted to be careful and not open the desk just yet in case something goes wrong. Picture A Picture B Picture C Picture D Picture E
Hi all. The iOS apps are now back on the App Store in their original capacity and under the same links they were before. ZerOS Monitor -> https://apps.apple.com/gb/app/zeros-monitor/id1033159176 ZerOS Remote -> https://apps.apple.com/gb/app/zeros-remote/id367342433 (cc: @Charlie Newman @Philh @ATC Tech)
Perhaps the crashes within programming are related to something memory-wise within ZerOS 8.0? You may be right there. I don't have a FLX myself, but as @SimonH mentioned, the desks running 8.0 crashed especially when programming moving lights, which usually handle more parameters than regular LED stuff and of course dimmers. I'm not entirely sure, but could the issue be related to where as you are programming a LX state, the data for parameters are held in some sort of temporary memory system (aka you know where in the output window, all the intensity values are red when not recorded/saved anywhere yet), and once recorded it never gets cleared from that internal memory as it usually should (due to the fact there is no reason to hold what you are currently programming, as it has been recorded) leading to the desk overloading itself to the point where the memory becomes full and eventually resulting in a crash. Obviously, once a reboot is performed, that temporary memory is cleared and all is well until the memory builds up again. Just a thought and a theory.
Hi all, just an update regarding this. Things are looking hopeful! I got a reply from them two hours ago. I hope they won't mind me posting the email here for others to see: Good Afternoon Archie Thank you for your email. We have an IT issue with the Apple Store at the moment and the IT team are working in getting this resolved asap. We are hoping to get this back up and running by next week Kind regards
Bad luck then. By chance do you (or anyone else) happen to remember the URL to that page, or have it saved anywhere? We could always check https://web.archive.org/ on the wayback machine to see if anybody archived it.. Or do you mean this page? https://backstage.zero88.com/control (further down it has legacy products - they just give the same descriptions as on the Vari-Lite pages)
Hi @Tim Molyneux, I'm glad the above solution worked for you. Indeed. You can use 'User File' instead of selecting 'USB' on the MFKs, which allows you to recall fixture profiles from a file previously loading in to the console via USB. At any time if you wish to delete these files from the internal console memory, you can do so by navigating to the <Update Fixture Lib> menu within setup. From there, you can select <Delete User Files>. Use the arrow keys to navigate which file you would like to delete from the internal console memory. Hope this helps!
Strange, I did hear somewhere that the Jester did, although it just could be my head playing tricks on me. You are probably right in what you've presented here with the line-up of consoles, so I appreciate the confirmation. It also can store memories (or 'steps' as it calls them, each step being part of a 'sequence') as well as having the ability of being in 2 preset mode. I've had a play with mine at home and although rather simple in the operation of it, I admire its simplicity. Thank you for the information you have provided me regarding the data sheet and the manual dates, I think I can try and work on figuring out dates with the info provided. I will continue to do some more digging on the forums as you have advised. Thank you again and have a lovely day!
Hi all, hope you are well. I was just curious.. from when to when were the Jugglers being manufactured? Usually, on a page (for example the Jester Series https://www.vari-lite.com/global/products/jester-series) it tells you when they were manufactured, this case being 2008-2017 for the ML range. However, on the Juggler page (https://www.vari-lite.com/global/products/juggler) it does not mention the manufacture date anywhere. I am aware that the Jester Series superseded the Juggler, but does anybody know this information per chance? Many thanks for any info you can supply me with.
Just to be sure, people in this thread who have already emailed support (@ATC Tech and @Charlie Newman) and haven't got a reply, have you used one of the old email routes, or the functional one? I've used this address, 'zero88support@signify.com' and have got replies before.
Unfortunately, same issue here too. I cannot seem to find any trace of the ZerOS Monitor and Remote apps on the Apple App Store, even in the ‘My Purchases’ section which is meant to show every app on your device added via the App Store. Luckily I have them downloaded already on two iPhones and two iPads and they still work. Hopefully we shall see what happens with the email to Signify. If I remember correctly, these apps were still under the Eaton Apple Developer App Store account. Not sure.
Hi @Tim Molyneux, the above post should definitely solve your problem (thank you @mikeb) as you are trying to load in a fixture personality file in the way of loading a fixture library file onto the desk. Using 'Assign Fixtures' -> USB as described in the manual above will work. Regarding this, I thought I'd just chip in and mention about file formats for future reference: JOS files are the file format for the Jester operating system when updating the console's OS. JSF files are showfiles for Jesters in the 12/24 and 24/48 range. JML files are showfiles for Jesters in the ML range, TL and TLextra range. I hope this is of use for the future for file format knowledge. Edit: To add, I have attempted to upload the IFT file provided above on my own JesterML console using the method in the manual via 'Assign Fixtures' and it does load in correctly.
Hi all. I just wanted to share this news with you regarding Invision Community, the forum software that this forum runs. Obviously, spam has been a massive issue for a long time on this forum, including many other forums as well. However, I have recently had a look at their plans on their website, and I noticed on every plan there is 'Spam Protection' which utilises Artificial Intelligence to detect it and it is 'coming soon'. Regarding this, I'm not sure if when it becomes available an admin has to enable it via the administration panel, or if it automatically gets enabled. (We can cross that bridge when we need to). I'm also not sure what paid plan this forum is on for Invision, which determines what level of AI Spam Protection we get here (standard/enhanced). I have attached an image below outlining the AI Spam Protection offered in the plan(s) provided by Invision. If this comes relatively soon, some of our problems with spam could be sorted. When it does come, it would likely result in the Invision Community software having to be updated for the forum, where an administrator would have to do so. I hope this is of interest!
