jmd Posted January 8, 2024 Report Posted January 8, 2024 Bonjour, je rencontre un souci quand j'enregistre des mémoires dans le master playback, quand j'utilise les projecteurs halogènes j'ai bien les temps de monter et de descente, mais quand j'utilise simplement des projecteurs LED RVB je n'ai pas accès au temps de monter et de descente simplement de couleur est-ce normal ? Merci jmd
kgallen Posted January 8, 2024 Report Posted January 8, 2024 If your LED fixtures only have RGB DMX channels then you will need to map a different fixture definition that includes "virtual intensity". Virtual Intensity is a feature that allows the console to scale the fixture's RGB channels proportionally to act as an overall intensity. First, check if your fixture has its own in-built intensity or dimmer DMX channel and if so, swap to using a more suitable fixture definition.
jmd Posted January 8, 2024 Author Report Posted January 8, 2024 Je précise que j'ai désactivé colour dans dans setup et playback
jmd Posted January 8, 2024 Author Report Posted January 8, 2024 Je vais regarder, Sinon comment procès de ton sur le pupitre ou sur les appareils LED ?
kgallen Posted January 8, 2024 Report Posted January 8, 2024 7 minutes ago, jmd said: Je précise que j'ai désactivé colour dans dans setup et playback 3 minutes ago, jmd said: Je vais regarder, Sinon comment procès de ton sur le pupitre ou sur les appareils LED ? Désolé, je ne comprends pas.
jmd Posted January 8, 2024 Author Report Posted January 8, 2024 Pardon, je voulais savoir si il y avait une manipulation a faire sur le pupitre ?
kgallen Posted January 8, 2024 Report Posted January 8, 2024 30 minutes ago, jmd said: Sorry, I wanted to know if there was anything to do on the console? If the patched fixture only has R, G, B colour "handles" then that is all you have to work with. If you want an "intensity" channel then the fixture definition loaded for your LED projector has to tell the desk to create a "virtual intensity" and what real fixture channels to scale. If your LED fixture is only R-G-B then the ZerOS library will already include an R-G-B-(VI) fixture definition which you could use. Alternatively, if your fixture has other channels (strobe, program etc) then FLX now has an inbuild fixture definition tool you could use. I've never used it though, sorry. Maybe@Edward Z88 can advise. https://www.zero88.com/manuals/zeros/patching/add-fixtures/fixture-creator Edit: Having quickly watched the video, I'm not sure if virtual intensity channels can be created in the on-console fixture generator.
Edward Z88 Posted January 8, 2024 Report Posted January 8, 2024 22 minutes ago, kgallen said: Edit: Having quickly watched the video, I'm not sure if virtual intensity channels can be created in the on-console fixture generator. When creating a fixture in the ZerOS Fixture Editor, if a Virtual Intensity parameter is required, ZerOS will automatically create one to scale LED emitters. 1 Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
jmd Posted January 8, 2024 Author Report Posted January 8, 2024 Ok, pourquoi les temps de monter et descente sont automatiques avec de l'halogène mais pas avec les led rgbwa ( seulement le temps de couleurs est disponible) ? Merci
Edward Z88 Posted January 8, 2024 Report Posted January 8, 2024 Si une mémoire contient uniquement des informations sur la couleur, où seules les valeurs de couleur changent lors de l'entrée dans la mémoire, vous ne verrez qu'un temps de fondu affiché pour la couleur. Vous ne verrez les temps de fondu affichés pour « Up » et « Down » que si le signal inclut des changements dans les valeurs d'intensité. If a cue just contains colour information, where only colour values change when going into the cue, you will only see a fade time shown for colour. You will only see fade times shown for "Up" and "Down" if the cue includes changes in intensity values. Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted January 8, 2024 Report Posted January 8, 2024 Halogen only has intensity. When you patch a "Dimmer" fixture that gives you an intensity control. If you don't have up/down for your LED then either: (1) Your LED doesn't have an intrinsic dimmer channel, or you patched the wrong definition or (2) The cue you programmed didn't have a change in intensity If you respond to some of the points in my earlier comments, then we can narrow this down more. At the moment you've given me no more information to help you. I'm guessing what the problem is.
jmd Posted January 8, 2024 Author Report Posted January 8, 2024 Bonsoir et merci, je vais faire quelques essais ce soir. Je reviendrais vers vous si je n'y arrive pas. Merci Jm
jmd Posted January 9, 2024 Author Report Posted January 9, 2024 Bonjour, je reviens vers vous. J'ai fait quelques essais hier soir concernant les temps de monter et descente. Je rencontre le problème suivant avec des projecteurs led RVBGW J'enregistre le 1er effet avec couleur dans Master playback a 100% j'ai bien faders UP et fade down sont enregistrés Effet 2 je baisse et remonte à 100% avec couleurs les mêmes faders et fade UP et fade down n'apparaissent plus. La même chose pour les effets suivants. Je ne comprends pas 🙏 Merci
kgallen Posted January 9, 2024 Report Posted January 9, 2024 @jmd Can you attach your showfile please, then @Edward Z88 can take a look (save to USB stick then on PC drag and drop into a new comment). 9 minutes ago, jmd said: Effet 2 je baisse et remonte à 100% avec couleurs les mêmes faders et fade UP et fade down n'apparaissent plus. Can you explain this again please. Is this one cue that drops intensity to 0% and then a following cue that increases intensity to 100%?
jmd Posted January 9, 2024 Author Report Posted January 9, 2024 Oui, avec le même fader j'enregistre une couleur de 0 a 100% effet un Je baisse le même fader, Je remonte à 100 % et je n'ai plus Fade UP et fade down
kgallen Posted January 9, 2024 Report Posted January 9, 2024 8 minutes ago, jmd said: Yes, with the same fader I record a color from 0 to 100% effect one I lower the same fader, I go back to 100% and I no longer have Fade UP and fade down If I understand you correctly, the 0% and 100% need to be two separate cues. Cue 1: 27 minutes ago, jmd said: I record the 1st effect with color in Master playback at 100% I have faders UP and fade down are recorded Cue 2: 27 minutes ago, jmd said: Effect 2 I lower and raise to 100% with colors the same faders Cue 3: 27 minutes ago, jmd said: Effect 2 I lower and raise to 100% with colors the same faders
kgallen Posted January 9, 2024 Report Posted January 9, 2024 I will add that if you want your LEDs to automatically do 0% then 100%, then you can set Cue 3 as AUTO (after) with a wait time (maybe 1 second?). 1
