Rye Posted July 14 Report Posted July 14 Maybe there is a better way of doing this - but I'm setting up a show with Audio/Light cues that sync up - and found Multiplay to be a great tool. I've been able to get it to work no problem so far - but I was wondering if there's an OSC command that like, essentially just clears all current lighting/playbacks. We have a bunch of random colour playbacks set up at the moment, and a handful of other cue stacks for some old shows. I've occasionally run into issues where something I'm doing on OSC/Multiplay can be interferred if there's any pre-existing playbacks that happen to already be running. I know there's the option to clear all Playbacks by holding Clear and then tapping the Channels/Playbacks button, but I was wondering if there's a Trigger command that does the same thing. There's the Blackout one, but that just dims without clearing/releasing. There's also the Release command - but that only does a specific Playback or the current Playback. Best thing I could think of was just running like, 96 commands to manually clear every single Playback - but that seemed like overkill and a hassle. Quote
Archie D Posted July 14 Report Posted July 14 Hi @Rye, The easiest option here if you were using a full-size FLX would be to use macros. Macros have the ability to capture press and hold events on front-panel buttons, therefore you can record a macro that records key presses (not syntax commands), hold CLEAR and tap the Fader Function button (same as the FLX S Channels/Playbacks button). You could then execute this macro via OSC.. /zeros/macro/1 for example. As you're on FLX S however, the above won't work as user macros are not a feature of FLX S consoles. There isn't an OSC command to release all playbacks, so you're right - you would have to release each one with its own individual network cue. To simplify operation though, you could make each network cue follow on from the previous one so you can trigger the first playback release network cue and each playback (1-96) gets released at the same time. If you were using QLab, this could be done with a group cue instead. I hope this helps. Archie Quote Archie - Student Student of lighting design & operation Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Level 6 DMX, Level 12, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Lightmaster 1200 (MK1), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, 4x Zero 88 Focus 650 Pebble Convex's, Linebacker, Demux 48 (x2)
Davidmk Posted July 17 Report Posted July 17 On 7/14/2026 at 11:51 PM, Archie D said: As you're on FLX S @Archie D has made this assumption because you have posted in FLX S. If you actually have a full FLX then recording a macro that is then triggered by OSC would be the way to go. However, all may not be lost if you are really on FLX S. You could record a cue that releases playbacks (see manual here) and then trigger that from OSC. A similar cue could also trigger all the cues you want to run. I'm not sure of the timings (whether releases are done before or after triggers) but you could even try putting all your releases and triggers on the same cue. 1 Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
