FBhatti Posted July 30, 2018 Report Posted July 30, 2018 With Software version 7.9.4 after booting the console I can not see the patch view so that I can add dimmers. The options available are Add fixtures and fixture schedule.
kgallen Posted July 31, 2018 Report Posted July 31, 2018 A dimmer is a fixture, so use the Add Fixture tool and there is a generic section at the top of the list which contains dimmer. You can patch multiple at a time, so you could add for example 24 dimmers in one step if needed.
Edward Z88 Posted July 31, 2018 Report Posted July 31, 2018 Hello, As Kevin says, use Add Fixtures to patch your fixtures- when adding Dimmers tap Add Fixtures, and then simply tap Next, as dimmer will be pre-selected for you. Add Fixtures is a new and improved, easier to use and more advanced replacement for Patch Wizard. You will then be able to view your patched fixtures in the Fixture Schedule, which is also where you can configure them. Hope that helps, any questions let us know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
