FX palette automatic creation not working
Sven76
 Share
Hi all
I'm having a huge issue with the FX palette on our ORB XF running ZerOS 7.9.5:
After updating the console to 7.9.5 many FX of our show are not working anymore. Many of them are even "grey" instead of "blue" now, so that I can't even select them (for instance a circle for a moving head or color FX for our RGB(W) fixtures).
I then thought: "OK, lets get rid of the old stuff and build it up new from scratch".
But with that it got even worth: I deleted all FX on the palette and pressed the "automatic create..." button. But then only  very view FX were created, they got spread all over the palette and even them do not work!
Does anybody have a similar experience?
What could i do wrong?
Is there a solution or a workaround?
BTW: Even on the Phantom the automatic creation is not working
Thanks in advance
Best regards
Sven
Hi Sven,
After installing ZerOS 7.9.5, if you press "Automatically Create Effects palettes", how many are generated? 45 auto palettes should be generated. You can then select your fixtures, and ones available for those fixtures will be highlighted.
If only one "No Effect" palette is created, you will need to reinstall ZerOS. This can be done following the instructions below...
http://support.zero88.com/1518910761
Hope this helps, if you have any questions let us know.
Hi Edward
I was already able to test your suggestion.
Unfortunately it didn't work at all.
Still, when I press "Automatically create Effect palettes" only the [No Effect] button gets created.
I tried the installation 2 times and even did a fresh download and a deep formatting of the stick. No change at all.
I then tried to create a FX palette by using Phantom. Phantom was able to create a palette. But after transferring the showfile to the desk non of those FX buttons were usable (all grey).
Any further Ideas?
I also wrote an email to support including my showfile because I'm really desperate at the moment 😞
Thank you and best regards
Sven
Hi Sven,
It sounds like you installed ZerOS 7.9.5 using the old installation method, not the method described here...
Please try loading the software application directly into the console like a show file, as described in the link above, and the effects should be installed with the software.
Hope this helps, let me know how you get on.
 Share
