Shanebyrne96 Posted February 5, 2020 Report Posted February 5, 2020 Programming a show with fade times on cue parameters. Colours and positions are  snapping despite having a 4 second fade time. i have a speed over ride fader but it is not allowing me to control anything.  what am I missing Â
kgallen Posted February 5, 2020 Report Posted February 5, 2020 Attach your showfile here is the quickest way the Z88 chaps can help you with this.Â
Edward Z88 Posted February 5, 2020 Report Posted February 5, 2020 Hi Shane, As Kevin says, either attaching your show file to this thread, or emailing it to us at support@zero88.com is the best way of us seeing what is going on. If you tap Z/Shift, the second encoder wheel displays Speed Override. If you tap the middle button of this encoder, this will disable speed override. Are you finding it is just the parameter fade times that aren't working, or are intensity fades not working either? If you have any questions let us know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Shanebyrne96 Posted February 6, 2020 Author Report Posted February 6, 2020 I can confirm held set up and go  fader controls where untaggedÂ
Edward Z88 Posted February 6, 2020 Report Posted February 6, 2020 Hi Shane, 5 hours ago, Shanebyrne96 said: Emailed it on Thanks, we’ll take a look into this. 4 hours ago, Shanebyrne96 said: I can confirm held set up and go  fader controls where untagged Thanks for letting me know. Yes if an attribute is enabled under fader controls, this attribute’s cue fade times will be ignored. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Mark Alington Posted June 5, 2020 Report Posted June 5, 2020 Hello again! I am using playback #1 to run a number of cues, each of which is a macro to call other playbacks (37 - 42), each of which has a chase programmed; it also releases the previous chase. Mostly it is working fine, but the chases are cross-fading from one to the next over about 2 - 3 secs rather than changing as a snap. I'll want to run through these quickly (less than 3secs per Go). Another fader #2 is programmed to release all the above chases, which it does instantly. (it is these different chase patterns which I want to be able to change the colours over as per my previous query). Outdoor cinema stage 1.isf
Edward Z88 Posted June 6, 2020 Report Posted June 6, 2020 Hi Mark, If you program a completely blank cue (as it sounds like you have in playback 1 to use as macro triggers), there won’t be a fade time displayed, as that cue itself has no information for intensities to change. Triggers and releases uses the cue fades, so if you need to customise the timings, you’ll need to put dummy intensity information into each of your macro cues - you could do this by just patching an extra dimmer channel you don’t need, and just have it fade on and off from 0% to 1%. This will bring the fade time controls back for you to configure. Hope this helps, Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted June 6, 2020 Report Posted June 6, 2020 I think I've had this "issue" before too. So, sorry to sound like a broken record Edward, but this it yet again a valuable nugget of information, so please make another of your KB "How To:"s 🙂 Also whilst I'm being a pain, and watching your "Programming cues onto playbacks" video - that tip to set your playback button to Go (Snap) to "prep in dark" the fixtures ready for raising the fader - that definitely needs to be a How To: too!
Edward Z88 Posted June 6, 2020 Report Posted June 6, 2020 How to’s added to my to-do list! Cheers Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted June 6, 2020 Report Posted June 6, 2020 I'll have filled it up by Monday morning 😈 5 minutes ago, Edward- Z88 said: How to’s added to my to-do list! Â
Edward Z88 Posted June 6, 2020 Report Posted June 6, 2020 21 minutes ago, kgallen said: I'll have filled it up by Monday morning 😈  😆 Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Mark Alington Posted June 6, 2020 Report Posted June 6, 2020 Thanks for your help Edward - everything is doing what I want. I have yet to see what it actually looks like! I have noticed various helpful pages with hints/videos/forums etc, but there could be a better way of getting from one to the other than going back to Google 🙂
Edward Z88 Posted June 6, 2020 Report Posted June 6, 2020 Hi Mark, 1 hour ago, Mark Alington said:  Thanks for your help Edward - everything is doing what I want. I have yet to see what it actually looks like!  Great, glad to hear it. 1 hour ago, Mark Alington said: I have noticed various helpful pages with hints/videos/forums etc, The below resources should get you started... https://www.zero88.com/live  http://support.zero88.com/Consoles/FLX-S/  If there’s anything else you need let me know. Hope this helps, Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
