Davidmk Posted October 14, 2020 Report Posted October 14, 2020 30 minutes ago, Edward- Z88 said: Setup -> Triggers, MIDI Notes is set to playbacks, and the Channel is left at 0 (to receive Notes commands from all channels), or set to the channel number set on the Novation. Your octaves will likely be set to "Separate", to give you access to playbacks 0 to 127. Almost certainly that, not absolutely sure about Channel but, if it isn't 0 then it probably should be. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Davidmk Posted October 14, 2020 Report Posted October 14, 2020 2 minutes ago, Uriahdemon said: Off down to set up the FLX with the USB Midi Hub and controller in the next few days and see where we go from there. Best of luck. Patience and the event display will be your friends but shout if you need more help. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Uriahdemon Posted October 14, 2020 Author Report Posted October 14, 2020 1 minute ago, Davidmk said: Best of luck. Patience and the event display will be your friends but shout if you need more help. Patience I am good with as long as I am confident I am not shooting in the dark. This info ensures this is not the case !!! Thanks Quote
Uriahdemon Posted October 16, 2020 Author Report Posted October 16, 2020 Hi David, Given all this great advice I now have my FLX and Launchpad set up and have MIDI control. I am using the files you sent over so need to adjust the playbacks on the FLX for notes 1-64 to trigger what I need and of course my own colours. There is one question please on Note #1 on the top row furthest left. That is triggering PB2 as opposed to PB1 have you any idea why that may be happening please.... did you come across that and just ignore PB 1.......?? Apart from that they are all triggering the PB's in sequence. Rgds Mac Quote
Edward Z88 Posted October 16, 2020 Report Posted October 16, 2020 Hi Mac, 3 minutes ago, Uriahdemon said: That is triggering PB2 as opposed to PB1 have you any idea why that may be happening please.... did you come across that and just ignore PB 1.......?? MIDI Notes 0, will trigger playback 1, and MIDI Note 1 will trigger playback 2 and so on. This may be what you are seeing? Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted October 16, 2020 Author Report Posted October 16, 2020 4 minutes ago, Uriahdemon said: Hi David, Given all this great advice I now have my FLX and Launchpad set up and have MIDI control. I am using the files you sent over so need to adjust the playbacks on the FLX for notes 1-64 to trigger what I need and of course my own colours. There is one question please on Note #1 on the top row furthest left. That is triggering PB2 as opposed to PB1 have you any idea why that may be happening please.... did you come across that and just ignore PB 1.......?? Apart from that they are all triggering the PB's in sequence. Rgds Mac I think I may have found it.... seems the midi notes start at Zero i.e. a 'C' so Zero (0) is triggering PB1 Quote
Uriahdemon Posted October 16, 2020 Author Report Posted October 16, 2020 2 minutes ago, Edward- Z88 said: Hi Mac, MIDI Notes 0, will trigger playback 1, and MIDI Note 1 will trigger playback 2 and so on. This may be what you are seeing? Edward Indeed it is Ed, just sussed that out this end..... thanks for your help !!!! Quote
Edward Z88 Posted October 16, 2020 Report Posted October 16, 2020 Hi Mac, 1 minute ago, Uriahdemon said: Indeed it is Ed, just sussed that out this end..... thanks for your help !!!! No problem - in a future update we will ensure MIDI Notes are patched 1:1 with playbacks, which will also allow the Master Playback to be triggered. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted October 16, 2020 Report Posted October 16, 2020 (edited) Now you two have me worried that my setup is wrong. I thought button one was c# and triggering pb1. I'll have to get my desk out and see what I've done. I haven't been able to try it on stage yet although the 1-64 file is an amended version of one I've used on a few live shows so it ought to have been right. The desk is still on the last-but-one version of ZerOS - don't know if that makes a difference. It thought it looked OK on Capture though. Apologies for any inconvenience caused though. Edited October 16, 2020 by Davidmk Typo Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Uriahdemon Posted October 16, 2020 Author Report Posted October 16, 2020 6 minutes ago, Davidmk said: Now you two have me worried that my setup is wrong. I thought button one was c# and triggering pb1. I'll have to get my desk out and see what I've done. I haven't been able to try it on stage yet although the 1-64 file is an amended version of one I've used on a few live shows so it ought to have been right. The desk is still on the last-but-one version of ZerOS - don't know if that makes a difference. It thought it looked OK on Capture though. Apologies for any inconvenience caused though. No inconvenience caused at all David given all you and Ed have input to this. Now it is my turn to do you a favour. If you give me a couple of days I will re-map the 1-64 PB's and of course include PB1. I will send a copy over to you but you will of course have to update your colouring. Quote
Edward Z88 Posted October 16, 2020 Report Posted October 16, 2020 Hi David, 26 minutes ago, Davidmk said: The desk is still on the last-but-one version of ZerOS - don't know if that makes a difference. It thought it looked OK on Capture though. This has been how MIDI Notes has operated on ZerOS since it was introduced - the first note (note 0) triggering playback 1. Therefore if your configuration was working, a software update won’t change that. So not sure where the problem Mac has found has arisen from? When we do come to map the MIDI Notes 1:1 with playback’s, you will need to remap your set up. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted October 16, 2020 Report Posted October 16, 2020 OK now I'm more confused. Attached screenshot shows midi note-on arriving and what happened on the playback LEDs. The wing was showing page 1, the desk page 6 (where the pb/cue triggered by pb1/cue 1 is located). It behaved as expected and the correct cue was triggered so pb LED 25 is presumably pb1. The above suggests note 1 triggers pb 1 which does not tally with what Edward said 6 hours ago, Edward- Z88 said: MIDI Notes 0, will trigger playback 1 therefore I must be misunderstanding something. I've stopped playing with the desk (I'm a fan of Vera on ITV right now) but I've left it set up and I'll continue tomorrow. One thing I'll be looking at is advice I had when first playing with notes, something about a setting which I can't find now. Dont read too much into that, it was last year sometime and an even earlier version of ZeroOS. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Uriahdemon Posted October 17, 2020 Author Report Posted October 17, 2020 Hi David, I was simply going by the info in the pix. Components - shows top left button = PB1 with Note value of C# and Octave value of -2. But according to the midi notes chart the first midi note is 0 (Zero) and value is C and Octave value of -2. For me I tested this and my PB1 is now triggering fine. I even downloaded your file again to ensure I had not loaded a file that I had been messing around with. Quote
Davidmk Posted October 17, 2020 Report Posted October 17, 2020 I've got the same for the first button but it fires pb1 not two. Edward said midi 0 would fire pb1 and you said midi 1 was firing pb2 1 if that is true then my desk must be operating in a parallel universe (or, being 2 versions behind is making the difference). I'll play some more after I've walked the dogs. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Uriahdemon Posted October 17, 2020 Author Report Posted October 17, 2020 I am not sure what settings are different between you and myself David however if yours is working as you need then.....?? I will pass over the file when I have set it up for your perusal. Quote
Edward Z88 Posted October 17, 2020 Report Posted October 17, 2020 Hi David, 2 hours ago, Davidmk said: I've got the same for the first button but it fires pb1 not two. Edward said midi 0 would fire pb1 and you said midi 1 was firing pb2 1 if that is true then my desk must be operating in a parallel universe (or, being 2 versions behind is making the difference). I reckon I have worked out where the confusion may be. If you tap SETUP -> Triggers -> Combine Octaves, what is your “First Note” set to? By default, this should be 0. This will mean in Channels, a Note 1 triggers fixture 1, in Cues Note 1 triggers cue 1, and in Playbacks Note 0 triggers playback 1. If you have the First Note set to 1, and then click Separate Octaves, in Playbacks Note 1 will trigger playback 1. Note 0 will have no function. Could this be what you’re seeing? If so, to save @Uriahdemon remapping all the Novation buttons, you can tap Combine Octaves, change the First Note to 1, and then click Separate Octaves. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Davidmk Posted October 17, 2020 Report Posted October 17, 2020 46 minutes ago, Edward- Z88 said: SETUP -> Triggers -> Combine Octaves That was the setting I couldn't find!!! Why doesn't it show up on separate octaves? Bug, surely Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted October 17, 2020 Report Posted October 17, 2020 4 minutes ago, Davidmk said: Why doesn't it show up on separate octaves? Bug, surely Correct. Unfortunately the “First Note” field is applicable for “Separate Octaves”, however is incorrectly hidden when Separate Octaves is chosen. Logged on our system, to be fixed in a future update. Most people will just live in “Separate Octaves” with the default of the First Note of 0. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Uriahdemon Posted October 17, 2020 Author Report Posted October 17, 2020 4 hours ago, Edward- Z88 said: Hi David, I reckon I have worked out where the confusion may be. If you tap SETUP -> Triggers -> Combine Octaves, what is your “First Note” set to? By default, this should be 0. This will mean in Channels, a Note 1 triggers fixture 1, in Cues Note 1 triggers cue 1, and in Playbacks Note 0 triggers playback 1. If you have the First Note set to 1, and then click Separate Octaves, in Playbacks Note 1 will trigger playback 1. Note 0 will have no function. Could this be what you’re seeing? If so, to save @Uriahdemon remapping all the Novation buttons, you can tap Combine Octaves, change the First Note to 1, and then click Separate Octaves. Edward Just the ticket, thanks Ed Quote
Uriahdemon Posted October 17, 2020 Author Report Posted October 17, 2020 @stowedout@Davidmk What did you use to mark up your buttons please.....?? Quote
Davidmk Posted October 17, 2020 Report Posted October 17, 2020 White gaffer. None of the controllers I've tried will accept anything else. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Davidmk Posted October 17, 2020 Report Posted October 17, 2020 If you find anything better then please let me know. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Uriahdemon Posted October 17, 2020 Author Report Posted October 17, 2020 14 minutes ago, Davidmk said: If you find anything better then please let me know. Well... I have just tried the dymo label maker and they will not stick. The pads have some give in them so the application has to be very thin and very sticky. I guess it may have to be gaffer Quote
Davidmk Posted October 17, 2020 Report Posted October 17, 2020 1 hour ago, Uriahdemon said: dymo label maker Yep, tried that, and transparent printer labels. Thought about trying sandpaper to give some grip and/or wiping the keys with meths before applying labels. Suppose you could cling film it and put labels on that. Do they make keyboard protectors (like you get for keyboards or tills in bars) for it? Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
stowedout Posted October 20, 2020 Report Posted October 20, 2020 Hi @Davidmk@Uriahdemon and @Edward- Z88 Looks like you guys are putting a power of work in to this. I agree though my Dymo looked nice all printed out but it is peeling off! Quote
