Bikearl Posted May 22, 2021 Report Share Posted May 22, 2021 Hello guys, I was wondering if i can convert a .isf file to .pdf file? Or in the best case, convert it to .Ascii or .Sho Best regards Nico Quote Link to comment Share on other sites More sharing options...
kgallen Posted May 27, 2021 Report Share Posted May 27, 2021 Getting printable output of fixtures/cues etc for documentation is not well (at all) supported unfortunately. Various enhancement requests have been filed over the years, but as yet nothing much in the products... FLX will happily gobble ASCII cues written out by e.g. ETC/Strand desks but doesn't honour that in the other direction (boot on the other foot and all that) [a little naughty/slightly immoral]. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted May 27, 2021 Report Share Posted May 27, 2021 Hi Nico, Welcome to the Zero 88 Forum. On 5/22/2021 at 2:32 PM, Bikearl said: I was wondering if i can convert a .isf file to .pdf file? Or in the best case, convert it to .Ascii or .Sho Apologies for the delayed reply, I somehow missed your post. It is not possible to export ZerOS show files to ASCII or PDF. You can export cue lists as CSV files. For clarity, show files saved in ZerOS 7.9.7 and earlier use the file extension .isf. In recent software versions show files will be saved in the .zos format. 13 minutes ago, kgallen said: FLX will happily gobble ASCII cues written out by e.g. ETC/Strand desks but doesn't honour that in the other direction Exporting as ASCII is definitely something we'd like to do. Currently there are features with much higher priority being worked on, so this is yet to be implemented. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
david6 Posted October 28, 2021 Report Share Posted October 28, 2021 (edited) J'ai une solution à votre problème. C'est une question très courante que tout le monde se pose. Je connais un outil gratuit en ligne dans lequel vous pouvez fusionner pdf, ajouter plusieurs images et les convertir sous n'importe quelle forme. Il est très facile de convertir un pdf dans cet outil, essayez-le une fois. Merci... Edited October 29, 2021 by david6 link don't appear Quote Link to comment Share on other sites More sharing options...
DALX Posted October 28, 2021 Report Share Posted October 28, 2021 To get a list or printout of the channels of a fixture file I have been viewing the file in the fixture editor then I use the Microsoft Snipping Tool to save it so it can be printed out. Quote Link to comment Share on other sites More sharing options...
