Hi Dan,
Welcome to the Zero 88 Forum.
As @kgallen states, there’s no shut down procedure on FLX consoles, just flick the power switch when you’re done.
Only thing to mention is that changes made in Setup are not automatically saved until you exit Setup. So if you make changes in Setup and then switch off the console, the changes will not have been saved.
Hope this helps,
  • Like 1
