Joshdd Posted March 21, 2022 Report Posted March 21, 2022 Hi I have 2 equinox fusion 140 and I can't find them do I need to get in contact with zero88 to have make the fixture up or are they under and different name Fusion_140_User_Manual.pdf Quote
Davidmk Posted March 22, 2022 Report Posted March 22, 2022 Have you got the up to date library (v3)which can be found here? There is a list of the fixtures in this version here. If your fixture isn't in the latest version there's a link on the home page of the forum ("Fixture Support & profile requests") specifically for this. If that isn't going to be fast enough for you then you can also create your own using the fixture editor which you can download here. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted March 22, 2022 Report Posted March 22, 2022 Hi @Joshdd 11 hours ago, Joshdd said: Hi I have 2 equinox fusion 140 and I can't find them do I need to get in contact with zero88 to have make the fixture up or are they under and different name The Equinox Fusion 140 is already included in the latest software for FLX S consoles, under the "Prolight" manufacturer. If you cannot find this fixture under "Prolight", I would recommend updating your FLX S console's software. If you would like more information regarding software updates, please let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Joshdd Posted March 22, 2022 Author Report Posted March 22, 2022 Thanks @Edward Z88 I just had a look and I found it under prolight 27 minutes ago, Edward Z88 said: Hi @Joshdd The Equinox Fusion 140 is already included in the latest software for FLX S consoles, under the "Prolight" manufacturer. If you cannot find this fixture under "Prolight", I would recommend updating your FLX S console's software. If you would like more information regarding software updates, please let us know. Edward 1 Quote
