james_ Posted August 24, 2022 Report Posted August 24, 2022 Hi, my school has had a Flx s 24 for over a year now and they have recently hired me as a technician I've been trying to patch an isolutions imove 7s to the rig and I've had no luck I was wondering if I could get some support thanks
Davidmk Posted August 25, 2022 Report Posted August 25, 2022 If you haven't already, check the manual here. Can you be more specific about your problem? For example, can you find your fixture in the library? Is there an error message? Does it suggest both channel number and DMX address? Are you on the latest version of software, or at least a recent one? Is the library up to date? 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted August 25, 2022 Report Posted August 25, 2022 Hi @james_ 9 hours ago, james_ said: I've been trying to patch an isolutions imove 7s The iSolutions iMove 7S is included in the latest ZerOS software for FLX S24 consoles... If you cannot find this fixture in Add Fixtures, I'd recommend updating your console's software. As this fixture doesn't have "modes", it should be as simple as adding the iMove 7S to your daisy chain, and assigning it a DMX address that matches the address patched in the console. Keith has replied to your email to fixturesupport@zero88.com this morning. If you have any questions, please let us know. Edward Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
DALX Posted August 25, 2022 Report Posted August 25, 2022 I find the FLXS24 needs an external monitor for easier use, this forum article may help Monitor for Flx 24 . It is for the FLXS24. I use a laptop with a cross connect cable. You can use a monitor with a mouse and keyboard connected to the FLXS24 USB port.
KWR88 Posted August 26, 2022 Report Posted August 26, 2022 Hi James, Have replied to you mail you sent to the fixture support box this morning. Regards, Keith Rogers Zero 88 Support: support@zero88.com
