Uriahdemon Posted November 18, 2022 Report Posted November 18, 2022 Good morning all. I was wondering if there is any way of getting a comprehensive picture of the DMX addressing and associated channels used across all universes. I am aware of the DMX Outputs picture on 'Z' however that does not give me the info I need. Ideally the kind of info you get when adding fixtures i.e. the 512 channels picture colour coded to used and free channels. Thanks in advance. Quote
Davidmk Posted November 18, 2022 Report Posted November 18, 2022 How good are you with spreadsheets? If you recorded one cue with everything in it on the master playback and output it as a CSV then, I think, the top row would give you all the used channels and what they are used for. Turning that into what you want would require good spreadsheet knowledge but it ought to be possible. Have a look at it and see what you think. (I've used CSV output once, to get details of cues alongside the script for a play, took some doing but at least, once it was done, I could refresh it with a new CSV as the cue stack changed. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted November 22, 2022 Report Posted November 22, 2022 Hi @Uriahdemon On 11/18/2022 at 1:19 AM, Uriahdemon said: Ideally the kind of info you get when adding fixtures i.e. the 512 channels picture colour coded to used and free channels. There is no way of exporting this information. If you need to just quickly check your universes, I’d recommend tapping SETUP -> Add Fixtures -> Next -> and then type in the universe number you need to check. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
