McFlair Posted January 22, 2023 Report Posted January 22, 2023 Hello together, I have a FLX S24 with version 7.7 and would like to update. I have now tested 3 different USB stick (all in FAT 32) and installed the appropriate OS on the USB stick via Windows. FLX powerless-> USB stick plugged in the back (next to the RJ45) - power on. But there it starts normally, what am I doing wrong?
kgallen Posted January 22, 2023 Report Posted January 22, 2023 Setup->Load Can’t see you’d have 7.7 on S24, desk wasn’t out at that version. Must be at least 7.9. My FLX is older and that came with 7.8.4.
Davidmk Posted January 23, 2023 Report Posted January 23, 2023 From the release notes for 7.13... "To update a console running ZerOS 7.8.2.39 or older, please visit zero88.com/manuals/zeros/software-updates/zeros-usb-creator for instructions." There are two version numbers that are displayed by the desk - one of them is the underlying LINUX version number something like 7.8.1.2 - you are not interested in this. I think the ZerOS version is displayed somewhere in the startup text and probably elsewhere. If your showfiles have a .zos extension then they were saved with v7.9.8 or later. If the version in your desk is actually newer than 7.8.2.39 then you start the desk in the usual way and use setup to initiate the software update. Try reading the release notes again, in particular the instructions on the last page. 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. Regular tech in two Milton Keynes music venues plus occasional festival work.
kgallen Posted January 23, 2023 Report Posted January 23, 2023 The manpage for the USB Creator says that method doesn't work on FLX S. FLX S came out after that legacy update procedure ended. The ZerOS version number should show in the bottom right of the internal screen at startup, and under the Z button. 1
KWR88 Posted January 23, 2023 Report Posted January 23, 2023 As mention by others above, the FLXS desk don't update with a bootable USB drive, you just copy the update file to the USB root directory and on the desk go into Setup > Load and select the .exe from the list of files and tap the load option. If you are having issue seeing the file on drive check you can see the file as ZerOS7.13.exe on a PC, in case a virus protection/firewall has change it. IF you can't see the USB drive, as you mention make sure it Fat32 or if a large capacity drive NTFS format, find windows tends to default to Ex-Fat. If you are still having issues PM me on the address in my signature. Regards, Keith Rogers Zero 88 Support: support@zero88.com
McFlair Posted January 23, 2023 Author Report Posted January 23, 2023 Yeaa, super everything has worked. Update from 7.9.7 to 7.13 . Thanks
