Rye started following FLX S48 Effect Parameters
Hey, I've been trying to solve this problem for a while - I've checked as many different forums posts as I could find to no avail. I'm using an FLX S48 console, with a bunch of different Tungsten and LED lights for a venue I work at. The end result I'm hoping for is a playback fader that can fade a rainbow colour effect in and out over the top of various other colours. For instance, I'll have a Blue wash on stage, and I want to fade that into a blue tinted rainbow effect, and then keep the moving colour effect but change the tint to red or green or whatever colour. I've tried a bunch of different methods with mixed results, but finally managed to get something close to what I wanted. I have some Playbacks with various colours - and then what I've been calling my Rainbow Fader. On this fader I've saved every LED with a Rainbow Effect at the speed/offset I want, but not recording the intensity; and with the colour values set to 0/ignored instead of the default 127. I've also set the fader to control Effect. Now, when I have the Rainbow Fader up, then fade in another colour like blue on a different playback, it fades into a nice blue-ish rainbow effect. Very nice, was what I was hoping for. The slight problem is doing it the other way around. If I have the colour up already and fade in the Rainbow Fader, it does indeed fade into the effect - but it also fades in the recorded Effect Speed, meaning if I fade it up fast, the colours rapidly shift around all over the place as it alters the effect speed really fast until it reached the recorded value. I've sort of been able to work around this by putting in a Raise/Lower time of like, 5 seconds. It helps smooth the effect speed transition, but is a bit limiting. What I was hoping for was to be able to control the Effect Size on the fader, but keep the Effect Speed the same the whole time. I've tried using stuff like the Speed Override, but either I'm not doing it correctly or it doesn't seem to work. I thought it would work like controlling the individual colour values on playback faders - where you can select/de-select the RGB values before recording, just with the Effect Parameters instead (Intensity, Speed, Size, Offset) I can also imagine other scenarios where this could be useful - maybe you have a moving head effect where you want the size to stay consistent - but be able to control the speed on a fader. Or maybe you want the speed/size to stay the same and control the offset on a fader. Would anyone know if there's a way of achieving something like the effect I'm hoping for, or perhaps a way of doing something like I described? Any helps would be appreciated. Thanks
Rye joined the community
No worries, great to hear.
BEF joined the community
JB5 joined the community
Good afternoon @Richard Elv, You can purchase a Phantom ZerOS Unlock Dongle from one of the distributors, or from here on StageGear. For outputting DMX with Phantom ZerOS, the Unlock Dongle must be plugged into your computer. If it is unplugged, DMX output will stop until the dongle is present again. Regarding methods of actually getting DMX out of your computer from Phantom ZerOS, you have two options. The first, is to output over the network using protocols such as ArtNet or streamingACN. The second, using a USB to DMX device (ones which support the ENTTEC protocol). Personally, I recommend the ENTTEC DMX USB Pro, which is generally considered to be a very high quality device and can be configured straight from ZerOS in SETUP -> Devices. Each of these devices will output one full universe of DMX. When running Phantom ZerOS as a FLX, you have access to 16 full universes of DMX (8192 DMX channels) over 64 patchable universes. If you're already used to using FLX, using a Phantom ZerOS Unlock Dongle will be ideal as it will give you the front panel you are already familiar with - just virtually. This can be used with a touchscreen, along with the external monitor for multi-touch functionality. Yes, the ZerOS Wing can be used with Phantom ZerOS running on a PC via USB as if you were using it with a physical console, therefore you will be able to use it across both your FLX and Phantom setup. Using a ZerOS Wing is the best option to give you more faders at one time. I hope this helps, Archie Bonjour @Richard Elv, Vous pouvez acheter une clé de déverrouillage Phantom ZerOS auprès de l'un des distributeurs ou directement sur StageGear. Pour la sortie DMX avec Phantom ZerOS, la clé de déverrouillage doit être branchée à votre ordinateur. Si elle est débranchée, la sortie DMX s'interrompt jusqu'à ce qu'elle soit reconnectée. Pour récupérer le signal DMX depuis votre ordinateur avec Phantom ZerOS, deux options s'offrent à vous. La première consiste à utiliser le réseau via des protocoles tels qu'ArtNet ou streamingACN. La seconde, à utiliser un convertisseur USB vers DMX (compatible avec le protocole ENTTEC). Je recommande personnellement l'ENTTEC DMX USB Pro, généralement considéré comme un appareil de très haute qualité et configurable directement depuis ZerOS dans le menu CONFIGURATION -> Appareils. Chacun de ces appareils génère un univers DMX complet. Lorsque Phantom ZerOS est utilisé comme FLX, vous avez accès à 16 univers DMX complets (8192 canaux DMX) répartis sur 64 univers patchables. Si vous utilisez déjà FLX, l'utilisation d'une clé de déverrouillage Phantom ZerOS sera idéale car elle vous permettra de retrouver virtuellement le panneau avant que vous connaissez déjà. Vous pourrez l'utiliser avec un écran tactile, ainsi qu'avec un moniteur externe pour une utilisation multitouch. Oui, la ZerOS Wing est compatible avec Phantom ZerOS installé sur un PC via USB, comme si vous l'utilisiez avec une console physique. Vous pourrez donc l'utiliser à la fois avec votre configuration FLX et Phantom. L'utilisation d'une ZerOS Wing est la meilleure solution pour disposer de plus de faders simultanément. En espérant que cela vous soit utile, Archie
