FLX 45 started following Master fader not working with channels why?
"FLX running recent ZerOS update. Grand Master fader has no effect on channel faders in Channels mode. Previously used Grand Master to blackout all channels during a show. Individual channel faders work correctly. Playback faders also not responding to Master fader. Has Grand Master behaviour in Channels mode changed in a recent update? How do I restore this functionality?"
FLX 45 joined the community
Davidmk started following FLX S48 Effect Parameters
I have been doing what you describe. It does work for me but there are limitations. The first is that you cannot separate speed and size. When you use the fader to control FX it has to control both speed and size. The second is that for most of the faders travel you don't get a visible effect just a messy mixture of colours until the fader reaches about 75% and the speed/size has to be adjusted in the last 25% I don't use colour mixing faders though - my colours are set by a playback with a cue for each colour and I use OSC to trigger the cue for the colour I want.
Hi Archie, That's correct - the ZerOS Startup Tool only allows ZerOS .exe installers to be loaded. If you have tried various USB drives of different sizes, each formatted with ZerOS 7.8.2.39, and you have tried different USB ports, but the console is refusing to boot into the installer, it may be worth checking the BIOS is configured correctly. From memory, these instructions for Orb will also apply to Frog 2... Allowing-Orb-&-OrbXF-consoles-to-install-software-from-a-bootable-USB-drive.pdf Edward
Rye started following FLX S48 Effect Parameters
Hey, I've been trying to solve this problem for a while - I've checked as many different forums posts as I could find to no avail. I'm using an FLX S48 console, with a bunch of different Tungsten and LED lights for a venue I work at. The end result I'm hoping for is a playback fader that can fade a rainbow colour effect in and out over the top of various other colours. For instance, I'll have a Blue wash on stage, and I want to fade that into a blue tinted rainbow effect, and then keep the moving colour effect but change the tint to red or green or whatever colour. I've tried a bunch of different methods with mixed results, but finally managed to get something close to what I wanted. I have some Playbacks with various colours - and then what I've been calling my Rainbow Fader. On this fader I've saved every LED with a Rainbow Effect at the speed/offset I want, but not recording the intensity; and with the colour values set to 0/ignored instead of the default 127. I've also set the fader to control Effect. Now, when I have the Rainbow Fader up, then fade in another colour like blue on a different playback, it fades into a nice blue-ish rainbow effect. Very nice, was what I was hoping for. The slight problem is doing it the other way around. If I have the colour up already and fade in the Rainbow Fader, it does indeed fade into the effect - but it also fades in the recorded Effect Speed, meaning if I fade it up fast, the colours rapidly shift around all over the place as it alters the effect speed really fast until it reached the recorded value. I've sort of been able to work around this by putting in a Raise/Lower time of like, 5 seconds. It helps smooth the effect speed transition, but is a bit limiting. What I was hoping for was to be able to control the Effect Size on the fader, but keep the Effect Speed the same the whole time. I've tried using stuff like the Speed Override, but either I'm not doing it correctly or it doesn't seem to work. I thought it would work like controlling the individual colour values on playback faders - where you can select/de-select the RGB values before recording, just with the Effect Parameters instead (Intensity, Speed, Size, Offset) I can also imagine other scenarios where this could be useful - maybe you have a moving head effect where you want the size to stay consistent - but be able to control the speed on a fader. Or maybe you want the speed/size to stay the same and control the offset on a fader. Would anyone know if there's a way of achieving something like the effect I'm hoping for, or perhaps a way of doing something like I described? Any helps would be appreciated. Thanks
Rye joined the community
No worries, great to hear.
BEF joined the community
JB5 joined the community
