  1. Today
  2. Hi @Worcester RGSTech, I've sent you an email that may help. Kind regards
  3. Our Solution has decided that it is not going to start beyond showing 'Loading, please wait...' following changing the CR2032 coin cell battery. Any ideas on the forum? Thank you.Simon IMG_2693.MOV
  4. Yesterday
  5. Has anyone got any experience with the Pknight Art-Net ecosystem? Their CR011R and CR021R prices seem too good to be true when comparing to similar devices listed on stage depot or Thomann. Their website feels like their products are technically sound and both devices seem to be opto-isolated which feels like a good sign. https://www.pknightpro.com/products/pknight-bi-directional-artnet-controller-cr011r https://www.pknightpro.com/products/pknight-artnet2-cr021 There is a comment in a review about it being incompatible with the FLX S24. Although I'm not planning on using it to convert DMX to Art-Net and (as the comment is of limited detail) I suspect is user error here seemed a reasonable place to see whether anyone has any experience using one. My own use will be to fire DMX signals from QLAB
  6. Last week
  7. Earlier
  8. Hi @DALX, Yes, Brian has already kindly sent the manual, but for future reference you can find it on the ZerOS Software page inside the Fixture Tools 2.6 ZIP download as a PDF. Here is a direct download link to that ZIP file. Fixture Tools is the general package that Zero 88 released, whereas Fixture Type Editor is an individual application within that package used to create/edit .ift files and export to .ift or .uft formats. Fixture Tools also includes the Common Fixture Manager application for the original Frog Range. Hope this helps!
  9. Thanks Brian, thats what I was looking for.
  10. Found this a while back, can't remember where. It only mentions the legacy desks but that's when this software dates back to. Fixture Editor User Guide_260902_181930.pdf
  11. Is there a manual for Fixture Tools please ? Is Fixture Tools a rename of Fixture Type Editor ? I want to add gobo selection and images to a moving head spot thanks.
  12. Hi @alg, ZerOS 8.0.0 contained minor bugs that could crash consoles, but this has been resolved with ZerOS 8.0.1 and user feedback has been generally positive about this bugfix from what I've seen. The CRDOWNLOAD file you see is a general file that is put in place for a file that is currently being downloaded or paused and hasn't finished downloading. This is normal to see while a file is downloading. You can try downloading Phantom ZerOS 8.0.1 again here from the ZerOS Software page. I hope this helps.
  13. I have just discovered that there is a new Zeros 8.0.1 update. There seemed to be a number of generally negative comments about this. What is the position on this new version? Is it worth it. I have tried to run the Phantom version to test it but it only seems to download a file version CRDOWLOAD File, Microsoft wont open this. Any suggestions?
  14. Replaced the 3 incorrect caps. Tested ok. Earth leakage now <1mA as expected.
  15. Information for users (if anyone still cares!). I recently purchased (2nd hand) two Chilli Jr dimmers for an install at a local voluntary art space. As is my usual approach, I always inspect, refurbish and electrically test equipment before I deploy it. On one of the Chilli Jr dimmers I purchased I observed an unusually high earth leakage current compared to the other Chilli Jr dimmer, when testing with my Megger PAT tester. Around 5mA compared to the <1mA observed on the other (#2) Chilli Jr dimmer. I've tracked this down to the fitting of incorrect EMI capacitors at some locations on the phase trigger PCB. There is no evidence of any rework or repair on this board, so this looks like a factory pick/assembly error. These capacitors are used (correctly) elsewhere on the same PCB. The phase trigger board takes the three mains phases (or three copies of single phase mains) and derives the zero-crossing trigger signals for the triacs. For EMI purposes, there are X2 and Y2 capacitors employed across the line, neutral and earth supply terminals. - X2 capacitors are used line-neutral and fail short to trigger over-current protective devices. - Y2 capacitors are used line-earth and neutral-earth and fail open circuit to avoid creating a shock hazard on the metal casing (since these dimmers are Class 1 devices). I've found X2 class capacitors fitted where Y2 class capacitors should be fitted in one of the Chilli Jr dimmers. Photos show 0.1uF (100nF) X2 EMI capacitors fitted where 0.01uF (10nF) Y2 EMI capacitors should be fitted. As can be seen in the following photos, the X2 capacitors are grey, the Y2 capacitors are blue. Incorrect X2 (grey) caps fitted N-E on all three phases. Correct Y2 (blue) caps fitted L-E on all three phases. Correct X2 (grey) caps fitted L-N on phases 2 and 3 (phase 1 has transformer isolation). This is confirmed by observing in the Chilli Jr dimmer #2 the correct components fitted in these locations - blue Y2 caps. Correct Y2 (blue) caps are used correctly N-E and L-E. Correct X2 (grey) caps are fitted L-N on phases 2 and 3. On Chilli Jr #1 I'm replacing the three incorrect X2 N-E caps with TDK Y2 caps of the correct value (10nF) and lead pitch (15mm). Users beware.
  16. Thanks for looking. My desk is at a school so tried it with Phantom ZerOS without success, will try it on the desk tomorrow.
  17. Hi Rye, Great to hear you were able to get it working. Correct, fixtures that have red text in the Fixture Schedule are non-library fixtures. Yes, the on-board Fixture Creator & Editor within ZerOS allows for longer parameter names than Fixture Tools does. This is because Fixture Tools supports legacy desks (such as the Frog Range, Jester Range, Illusion 500 etc.) which only supported a certain amount of characters for parameter names. The ZerOS Fixture Editor allows for longer names because it doesn't have to contain compatibility for legacy desks which hold that limitation. Fixture Tools only supports loading .ift files and not .zfix files. This means that zfix files cannot be loaded into Fixture Tools to be edited, and can only be modified on the desk. One of the reasons of that is zfix files can contain multicell information, and Fixture Tools does not support multicell functionality. However, once you load in a .ift fixture file into the desk (SETUP -> Load), you can actually edit it in the ZerOS Fixture Editor from Add Fixtures. Beware though, making any edits to anything in that fixture personality within ZerOS will remove all parameter detail information you have added from Fixture Tools as it writes new parameter information when you re-save the file (in the zfix format this time), so lengthening parameter names once loaded into ZerOS isn't possible. I would only recommend doing so if you don't have any parameter detail information in that profile that is important. I hope this helps, let me know if you have any questions.
  18. Thanks Archie It took a bit of experimenting, trial and error and then a while inputting all of the details but I was able to get it all working. The fixture is showing up Red in the Fixture Schedule - which I assume is because it's a non-library fixture The only very minor gripe I had was the Fixture Editor only let me have parameter names with a max of 7 characters, so I had to shorten the parameter names - but not actually a big deal. I didn't end up needing to - but is there a way to like, export an existing fixture from the desk to then edit in the Fixture Editor? I tried to do something like that, but since the desk exports as .zfix files and the Editor only uses .ift I'm guessing you can't edit an existing fixture, so you'd have to create a new one from scratch, which is what I did
  19. Hi @DALX, Slight query - I can't seem to replicate your copying procedure using syntax. Typing the syntax to copy cue 1 on playback 1 to cues 5, 10, 15, 20 gives invalid syntax at the second period (1/1 Copy To 5.10. <-) as only one decimal point is allowed. This means cue 1 can only be copied to cue 5.1, disallowing the period to be used as a separator. Alternatively, using the copy window (Z/Shift -> Copy).. From 1 To 5.10.15.20 returns a new cue numbered 5.1. ZerOS is interpreting my entry as a point cue here too rather than multiple cue numbers, given that point cue numbers can only be up to 2 decimal places. The second period invalidates the further numbers anyway. In ZerOS, you can copy multiple cues to a single cue number. That single cue number acts as the starting number. For example, copying cues 1>5 to cue 10 will create cues 10 to 15. Copying cues 1+3+5 to cue 30 will create cues 30, 31 and 32. In the Copy Window, only the 'From' input box allows + and > whereas the 'To' input box doesn't. Please could you elaborate further on what you're doing to achieve this? I might be missing something. Many thanks
  20. During a lighting workshop last week I was asked can you copy one cue to multiple cue locations at the same time to speed up plotting. I tried Copy To 5.10.15.20 as a syntax and it copied a cue to cue numbers 5, 10, 15 and 20 using the period . as a separator. I have tried to find this in the ZerOS handbook but have not found it. I know it works but I was hoping to find a description to see more Copy syntax options ? Can someone point me in the right direction please ?
  21. Hi @Rye, The extra window that opens when you press the encoder wheel's centre button is to display the 'Details' of that parameter on that encoder wheel. These are defined within the fixture profile itself. The on-board fixture editor (found in SETUP -> Add Fixtures -> Create new fixture, or from editing an existing fixture) is designed for quick and easy operations and doesn’t contain the ability to add or edit details of parameters. Details in a parameter are defined ranges that can be labelled, have a colour or image attached etc. For example, 0-20 is Macro 1, 21-40 is Macro 2. You'll notice the labels changing as you scroll through ranges on the encoder wheels. Details are then assigned as buttons in the window you found, its a quick way to jump to parameter ranges saving endless scrolling on the encoder wheels. To add details to parameters, you’ll need to use the Fixture Tools application. This requires a Windows PC, or a computer running Wine to emulate the Windows application (works on my Mac). Within each parameter is a 'Details' tab. Note that Fixture Tools will export fixture files in a .ift file format rather than the modern .zfix format. This means multi-cell can only be done in the on-board fixture editor in ZerOS - just something to be aware of. I’ve had a look for the manual of that fixture too, and it doesn’t seem to be anywhere. If you can find out what each channel does on your fixture, you can start to build up a fixture profile in Fixture Tools. Then, you can specify parameter detail ranges for the Macros along with any other parameter that requires the same. I hope this helps. Feel free to ask any questions. Apologies if any formatting went weird, typing this up on a phone!
  22. For context, we have these lights (AVE Pro-Can HEB12) that, as far as I can tell, are discontinued and also the manual for it just doesn't seem to exist. It also doesn't appear in any exisiting lighting fixture libraries as from what I've seen. I was able to figure out how to make a custom fixture, and even using the filter setting to find an existing one that's similar enough to it, so no problems there It has a Colour Mix/Macro Select for the last 2 channels on it's 10 Channel mode - and when you click on the parameter for lights for these it takes you to another window with with all the options for that Macro For example, for the BeamZ BBP96 (the closest similar light I found), on the 9th channel it has Colour Mix Macro Select, with a bunch of options like Colour Auto Run, Colour Gradient, Sound, Strobes etc. The lights we have have a similar selection of Macro options, but not quite the same. But as far as I can tell, you can't seem to be able to edit/create the options for these. Is there some way to do this that I just haven't found? Either for making a new fixture or editing an existing one.
  23. Hi Martin, Really glad to hear this - I'm glad you've got it sorted. Nice find on the extra setting for the NVRAM! Happy to help. Archie
  24. Hi Archie - yes, it is the Flat Panel Type setting which needs to be 'XGA 1x18' rather than 'Auto' which is what the default setting is. For information, the only other setting which needs to be changed after defaults have been loaded is under Advanced Chipset Control, where 'Enable Memory Gap' needs to be set to 'Extended' rather than 'Disabled'. Otherwise you get a permanent 'Non-volatile RAM Fail/Replace Battery' message at boot-up. Very many thanks for your help - this was driving me insane! Martin
  25. @Archie D has made this assumption because you have posted in FLX S. If you actually have a full FLX then recording a macro that is then triggered by OSC would be the way to go. However, all may not be lost if you are really on FLX S. You could record a cue that releases playbacks (see manual here) and then trigger that from OSC. A similar cue could also trigger all the cues you want to run. I'm not sure of the timings (whether releases are done before or after triggers) but you could even try putting all your releases and triggers on the same cue.
  26. Hi @Rye, The easiest option here if you were using a full-size FLX would be to use macros. Macros have the ability to capture press and hold events on front-panel buttons, therefore you can record a macro that records key presses (not syntax commands), hold CLEAR and tap the Fader Function button (same as the FLX S Channels/Playbacks button). You could then execute this macro via OSC.. /zeros/macro/1 for example. As you're on FLX S however, the above won't work as user macros are not a feature of FLX S consoles. There isn't an OSC command to release all playbacks, so you're right - you would have to release each one with its own individual network cue. To simplify operation though, you could make each network cue follow on from the previous one so you can trigger the first playback release network cue and each playback (1-96) gets released at the same time. If you were using QLab, this could be done with a group cue instead. I hope this helps. Archie
  27. Silly me - yes, that of course could have been a possibility. Probably was unstable in some way, making the main console drop out so the backup took over as the main was considered 'offline'. Fantastic to hear your main FLX didn't crash. Anyway - I hope the show went well, great pic!
  28. Maybe there is a better way of doing this - but I'm setting up a show with Audio/Light cues that sync up - and found Multiplay to be a great tool. I've been able to get it to work no problem so far - but I was wondering if there's an OSC command that like, essentially just clears all current lighting/playbacks. We have a bunch of random colour playbacks set up at the moment, and a handful of other cue stacks for some old shows. I've occasionally run into issues where something I'm doing on OSC/Multiplay can be interferred if there's any pre-existing playbacks that happen to already be running. I know there's the option to clear all Playbacks by holding Clear and then tapping the Channels/Playbacks button, but I was wondering if there's a Trigger command that does the same thing. There's the Blackout one, but that just dims without clearing/releasing. There's also the Release command - but that only does a specific Playback or the current Playback. Best thing I could think of was just running like, 96 commands to manually clear every single Playback - but that seemed like overkill and a hassle.
  29. Not sure really! I was running two switches, three Art-Net Nodes, one Wi-Fi AP, one Stream Deck, and a local laptop networked in for running ZerOS Monitor. Vari-Lite email support could only offer the suggestion that it would have been due to an unstable network. There could be some mileage in that as my laptop did occasionally drop connection to ZerOS Monitor. Anyway, its all over and done with now, I never ran them in tracking, however was ready to rapidly connect in the backup ethernet cable if my primary desk crashed during a show, which it didn't (hooray!) Pic for prosperity - stuck at the back of the box behind the venue desks - main sound FOH, running audio feeds into venue mixer
