  1. Past hour
  2. Hi Paul, Saving the setup within the show file as well theoretically shouldn't cause any problems. If you can recall - when the console crashed, was it a black screen with a load of white text (ZerOS Watchdog kicking in) or did the console just completely freeze, preserving monitor output too? Let me know how you get on later with LF48TEST1.zos, it has a few things disabled/removed to see if anything in the show file itself is crashing the LF48. One of my theories for this was that because the Leapfrog 48/96 came with 2 DMX universes as standard, with an optional upgrade card while the Solution comes with 4 universes straight from the factory, that ZerOS was trying to index a universe from the Solution (3 & 4) that didn't exist on the Leapfrog when loading in the show file (if the optional upgrade card for 2 more outputs isn't present). Hence, U3 and U4 are disabled in that show file. However, it is just a theory and could be wrong. It's all about experimentation to see what works! I look forward to hearing from you, thank you. Archie
  3. Today
  4. Hi @kisi, welcome to the forum! I should be able to do this this evening for you, however you're also able to do this within the desk itself under "SETUP" -> "Add New Fixtures" -> "Create New Fixtures" Please let me know if you have any questions. Best, Charlie
  5. Need help to build a fixture file for my new light. Name of the light is Maverix - BSW 350 Can someone help me, I use a Vari lite FLX S24 console attached is the dmx chart. Best regards Kim Simensen Maverix-BSW 350.pdf
  6. Hi Archie. I will try later. I wonder if, when i saved, i saved the showfile and setup, rather than just the showfile. Thanks Paul
  7. Yesterday
  8. Hi Paul, Thank you for providing your show file. Please could you see if this file loads into your Leapfrog 48? If it doesn't and the console crashes, what does the console show on the external monitor? Please don't panic that your cues/playbacks are missing by the way for this file - I'm simply juggling things to see what does what. Thank you. LF48TEST1.zos
  9. Showfile from Solution that wouldn't load on Leapfrog. WOZ-20125a.zos
  10. Hi Paul, Sounds good, if you’re still experiencing difficulties tomorrow, please could you upload your showfile here if that’s okay? I can then see if I can potentially find anything on PhantomZerOS and my Solution XL (though if it loads fine onto a Solution and not the Leapfrog 48, I might be lost) When the Leapfrog 48 crashed, was it a ZerOS Watchdog message that appeared? I’m curious as to what it said, or what the crash behaviour was like.. Thank you and have a good rest of your day. Archie
  11. Hi Archie, Yes, I thought the solution and Leapfrog48 were the same. Both are running 7.14.4. File is a .zos. I have tried loading into phantom and saving, and will try on the desks tomorrow night. Thanks Paul
  12. Hi @Muller Light, ZerOS showfiles are cross-compatible between ZerOS-based consoles, only with some data not being loaded (for example when you load a FLX showfile into a Solution, some data from the FLX won’t be loaded in). However, this won’t happen because Leapfrog 48 and Solution are identical, you’ll only receive a warning due to the different console types, but all data will be passed over. What software version are both of your consoles running? To see this, in the Output Window click ‘Other Windows’ (top left) -> System Information -> Software Version. What format is your showfile? Is it a .isf, or .zos? Many thanks, Archie
  13. Hello all, I have a Solution and tried saving a show and then loading it on a Leapfrog48. The Leapfrog crashed and had to be rebooted. Is there a way of saving a show on the solution that makes it compatible with a leapfrog? And vice versa? Thanks
  14. Last week
  15. Hi Simon, To adjust cue delay times on Solution, the best method is to use the MFKs (Multi Function Keys) instead of the encoder wheels. Navigate your cursor using the mouse or arrow keys to an 'Up' or 'Down' field, then tap ENTER to start editing the time. On the top right MFK, tap 'Delay'. It will now have the red LED lit, with the white background to show it is selected. Type in a time using the MFKs or an external keyboard, then hit ENTER again to submit this. For your instance editing the 'Down' field, the down delay has now been applied to your cue. You also have the option to do this at the same time when editing a regular up or down fade time for a cue for efficiency. When editing a fade time, simply switch between 'Delay' being selected or not, and when pressing ENTER to submit these changes, both changes for the regular fade time and the delay time will be applied in one go together. I hope this helps, feel free to ask any other questions you may have. Archie
  16. Hi Simon, Good to hear it seems to have fixed itself. I've just popped in to leave a few comments. You may have accidentally knocked the intensity encoder wheel slightly when making changes, so when re-recording default values with RECORD -> HOME -> Default, the intensity information is also included in the defaults of the fixture. Were you using RECORD -> HOME -> Default to do this after changing the intensity to 0%? This next bit is unlikely, but did the 'Intensity' selection button have a red indicator instead of blue? If it was blue, that intensity information won't be recorded into the defaults, so when you CLEAR CLEAR, the fixture will still go back to the original intensity default value. An image is attached with 'Intensity' under 'Attributes' having a blue indicator. The reason I say this is unlikely is because when you make a change (intensity in this case), when tapping RECORD, the changed parameters (which are therefore tagged) will be automatically in red to show they are selected. Though with this being said, in the image you have provided while trying to change fixture 5's intensity back to 0, 'Intensity' has a red indicator... Correct - the yellow D in 'Sources' as opposed to 'Intensities' indicates the intensity is coming from a default value of that fixture. A red P in 'Sources' indicates a manual programmer adjustment or modification. All in all, it is sorted, but I just thought I'd provide little segments of extra information in case anybody reading this isn't sure. Have a great week Simon. Kind regards, Archie
  17. Hmm, well that's annoying. It seems to have reset itself. I've finished working & gone back to the -1 cue at the top and all is restored. You can see on the photo above that I was on this cue and the MH lights (108, 109) had a hard 0 value, while I was trying to reset Ch5. Now, all channels are blank as it should be. Happy to delete topic if that's appropriate.
  18. Final dress rehearsal for panto tonight & just tweaking a few timings. How do I get to adjust Down Delay on a cue. When I click on Up or Down timings, I get Up Fade, Up Delay, & Down Fade on the scroll wheels but can't get to Down Delay - tried shift but can't think of anything else. Simon
  19. I was changing defaults on my moving head lights and now fixture #5 has a Default intensity value of 5. (ie. on the source screen it has yellow "D") I tried re-saving it to zero but it won't stick, reverting back to 5 when I clear, clear. Settings are as shown, and I've tried variations of tagged vs selected fixtures. Any suggestions what I'm doing wrong? I don't think any other option for the yellow D applies. Simon.
  20. I think unfortunately we've come to the stage where none of us trust the releases to a point where we want to test them live or whilst doing something due to the instability issues we've had.
  21. Thanks for that. You haven’t heard when the update is due. Although it’s only fixes it may address the problems I’m having
  22. Going back a version shouldn't give any problems with the desk however you do, obviously, lose any new features and there is, potentially, a risk that your show files do not load. In practice, if you haven't used any of the new features, these probably won't bother you, 7.14.4 was the final release for the legacy desks (Frog2, LeapFrog, Solution, Orb) - You don't want this version. You want 7.14.3 for FLX & FLX S and the main difference is that you will go back to a maximum of 48 fixtures and fewer playbacks. Make sure you backup you v8 showfile. If you have used fixture numbers or playback numbers greater than the v7 limits then edit your show file to fit v7 and back that up to load after installing v7 The beta test forum for the new version (currently known as v8.0.0 build 11) seems to have been greeted with general apathy, possibly explained by being released when pantomimes are prevalent. There are no new new features and it consists of bug fixes for live version (v8.0.0 build 8). I don't know why other testers have failed to respond - for myself, I'm a full FLX and LeapFrog user and I'm not very interested in the newer versions now that FLX S has become the focus - I prefer to stick with v7 for now but might make a move to Chamsys. There has only been one tester response. This may have been on an FLX S and was favourable but did not cover any programming functions.I suspect FLX S users are under represented among beta testers.
  23. I down loaded 8 last year and there are several problems with this software. Move on Dark is very problematic at the moment When programming a blackout the desk crashes I have read that there is an update due and is in beta at the moment when will it be released. In the short term I am considering reinstalling 17.14.3 or 4would there be any adverse problems in doing this
  24. Earlier
  25. Forgive me if I've misunderstood the original post, but following this, here's a fixture file.. With this, we're using sub-fixtures instead of regular parameters in one single fixture like other fixtures would. This allows you to separate two parts of what we want to achieve here - to use this singular fixture as having the 'Lamp' (Intensity) defined as your actual dimming light (in your case - two linked to the same channel), and then configure the 'Scroll' part separately of the fixture to be on a different address, achieving your initial wish to 'link' the scrollers to the 'Intensity' of your incandescent fixture, where both the Intensity and two scrollers (together) can be as far apart in the DMX universe as you need, but the lamp must be the lower address (meaning the scroll can only be a DMX address after the lamp). Note that if you define the Scroll part of the fixture to be on e.g. DMX 57, that will be the first scroller. The second scroller will therefore be on DMX 58, with the Intensity being anywhere you wish (e.g. DMX 3 - completely away from the scrollers), again 'linking' the scrollers to the intensity. You will need to replace the Dimmer fixture you currently have patched in for your intensity with this one, but don't worry - the lamp intensity will work exactly the same, but giving you the additional scrollers. The scrollers will then actively 'listen' to the intensity and when it is at 0, the scrollers will use Move on Dark. We can see this in action with the grey background of fixture 1 on the second screenshot - the Scroll1 and Scroll2 values were both moving on dark at that time. And remember to always back up your show file before making critical changes like this. When patching this new fixture in after loading the .ift via SETUP > Load > IFT File, a 'Part' column will be added to the Fixture Schedule. This will indicate the Lamp and Scroll parts of the fixture as described above. See pictures and fixture file (.ift) below... Lamp + 2 Scrollers.ift
  26. yea as @Davidmk says I don’t think you can keep the dummy lamp dark, you might as well just patch a scroller. Is there any scope to duplicate DMX address patching? Can’t currently get my brain sufficiently off work to think this through but I’ll give it some thought.
  27. @drscoop If you need this then using the same address is not possible. (Well, it is if you arrange the colour rolls appropriately but that would be a faff and still might be impractical.) @kgallen, as always, makes a good point but wouldn't keeping the dummy fixtures dark just mean that they skip straight to the last state in the cue list? Surely the dummies need to follow the real fixtures. Maybe they should be added to the same desk channel as the dimmer?
  28. I think this is the way forward. It can go waaaay up theDMX and fixture list and always be dark. The scrollers will only ever move the other “real” fixture is dark, so it shouldn’t go rogue if the dummy one is never lit…. I think!!
  29. I think this is what we’ll do next time - presently they’re set so we can apply asymmetric colour washes to the stage… so each one can be controlled individually. I’d hoped there may be a fix so that we could use 1 DMX address for the lamp but then add in 2 addresses for the scrollers. Using dummy fixtures may be the way forward if we want to retain this feature….
  30. OK this is 10 years old comment, but this is where Jon told me the association of dimmer has to be within the fixture. I think at the time I was trying to do something vaguely similar to you where I had a patched Source 4 and wanted to associate the scroller with it to support move on dark.
