I may be a little late for this, but what exactly was the reason for ZerOS Monitor to be removed from Android and ZerOS only funtioning on iOS?
Is there another way of using external devices (preferably Windows) as a Remote? I
Thanks up front.
Jan.
FLX S24 for work in my old school
Thanks!
So to run a Monitor like app you have to do it through a Android Emulator?
There isn't one for Windows itself?
Hi there.
There is a specific ZerOS Monitor app that was produced for Windows. There is also a MacOS version if you prefer.
However, there was not a ZerOS Remote app produced for Windows for public use (to my knowledge, I saw Edward using ZerOS Remote on Windows in a training video).
Anyhow, ZerOS Monitor on a laptop or desktop does function as a sort of "remote", as it allows for keyboard shortcuts to be entered, such as R for record or U for update.
They are downloadable at the links below provided by the ZerOS Software page on Vari-Lite's website.
If you prefer to look at the page to verify the download links: https://www.vari-lite.com/global/products/zeros-software
Archie - Student
Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Sirius 24 & 48 (x2), Sirius 500, Lightmaster XLS, Fat Frog, Diablo, Orion, Alphapack 2, 4x Zero 88 Focus 650 Fresnels
Alright thanks to you both,
In my memory ZerOS Remote was just easier for remote programming and I've got a project where I'm not at the console while programming (and its easier to be remote there). I saw the keyboard shortcuts on ZerOS Monitor but with the Remote you had it on the display, like the syntax or the position grid.
But I'm sure I'll figure something out.
  • 2 weeks later...
Hey again,
little thing to ask again about the Monitor. (btw, got Remote working via Emulator thanks for providing the link)
In the attached file 5 of the Briteq Theatres intensity are marked blue while one is green. Is that to indicate a change from the previous Cue? My first thought was, it indicates dynamic change of Int. in a Cue i.g. like a ramp up effect, but the theatres dont have any like that on in the Cue.
This is no problem but im interested as for why this is.
Jan
Hi @SoleJan
Blue UP to the sky, green DOWN to the grass. (Blue means that channel intensity went up, green it went down.)
White, it's a blocking value, purple it's tracked.
Red from the programmer (highest priority), yellow for some other controller. Red background is Parked. Grey background (for a short time) is moving on dark.
They're all here:
https://www.zero88.com/manuals/zeros/desktops-windows/output-window#colours
Outputcolours
  • Like 2
  • Thanks 1
  • 2 weeks later...
Thanks again,
btw our project went smooth besides one or two small things.
I hope no one minds me asking more on here. For some reason ZerOS Monitor works on Apple Watches even tho the only good function a friend found is Rem Dim.
Nowww, i guessed it means like remote dimmer or so but the true problem is, the program for the watch crashes quite often and we haven't found a way to deactivate Rem Dim besides the watch feature - The keyboard shortcut on Windows didn't wanna work either. It ended in us having to restart the console multiple times throughout programming.
So, what actually is it and does it, and how can I deactivate it without a force reboot?
Sorry to keep y'all up with my stuff.
Jan
I haven't used Rem Dim (or Highlight for that matter) but, checking the manual, I see that it applies to selected fixtures so I guess it is removed when you clear the programmer.
Check the manual yourself for more details including the Apple watch app. Don't select a desk type as the S series may not have these features or at least not the MFKs to set to them.
2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes.
Regular tech in two Milton Keynes music venues plus occasional festival work.
This is why we’re here! Keep asking/sharing and we’ll do our best.
If you can help out another user - either directly by asking a question of your own which is answered, or more directly, then even better. That’s how this forum works, especially now the Vari-lite support is minimal.
  • Like 1
That's the thing, clearing doesn't undo it, nor deselecting or in that matter anything (at least when we tried). But i'll look into it, and maybe I'll come back here this evening
That's a nuisance. It was late when I scanned through the manual so, if I missed something about releasing it, I apologise.
Rem Dim (or Remainder Dim) is a feature common on most lighting desks which dims all active outputs to 0%, and sends all channels you have selected to 100%. This feature is particularly useful during focusing sessions or rig checks.
E.G. Dimmers 1 thru 12 are at 50%. You want to specifically pick out dimmer 6 to allow you to focus it better. Select channel 6 and 'Rem Dim', channels 1 thru 5, and 7 thru 12 go to 0% and channel 6 goes to 100%. In ZerOS, channels affected by Rem Dim are shown in Yellow as @kgallen has pointed out earlier.
I don't believe Rem Dim is a feature that is enabled on the FLX S range consoles, and is exclusive to full FLX only (unaware of other legacy consoles). On review of the ZerOS Shortcuts (https://www.zero88.com/manuals/zeros/shortcuts/keyboard-shortcuts?filter=1) "Shift + F" enables Rem Dim on FLX but I have tried this on Phantom and it doesn't work for FLX S. This may be an error that this feature works via an Apple Watch (unable to test this unfortunately!)
You do have access to the 'Highlight' feature (Shift + Home) on FLX S range. Highlight allows you to temporarily bump the intensity of a selected fixture up to 100%, which again can also be useful during focusing.
During testing on Phantom ZerOS, both Rem Dim and Highlight can be 'CLEAR CLEAR'-ed.
Hope this is of some help! Good luck!
  • Thanks 1
Yea I went through the manual and it doesn't seem to be designed for the FLX S, so that its available for the Watch thingy is kinda not right, at least for the FLX S.
I saw Highlight working tho.
But yea after clearing the programmer we weren't able to get the fixtures working again, besides the one selected throu Rem Dim. Idk, maybe that's just an individual problem or so.
Solved it by basically not allowing my friend to use Rem Dim anymore, works fantastic.
Thanks again to you all.
