daseffx Posted October 24, 2018 Report Posted October 24, 2018 If Playback 1 is red, Playback 2 green and Playback 3 blue (for choosen LED) , it´s possible to mix the Colour live (like a ordinary submaster will do)? Well, that will be nice. Quote
kgallen Posted October 24, 2018 Report Posted October 24, 2018 (edited) See: https://www.zero88.com/manuals/zeros/cues-playbacks/playing-back-cues/rgb-colour-mixing-on-playbacks Edited April 22, 2024 by Edward Z88 Link updated. Quote
O Thompson Posted May 22, 2019 Report Posted May 22, 2019 First post, so please excuse the naivety... We have recently purchased an FLX for use in a educational performance space. My questions relates to the way the FLX has to be set up for LED RGB Colour mixing. Using the guides above i am able to make this work easily, but my questions is more about why this is necessary... Specifically, the need to use a latch button to ensure intensity is at 100 and the RGB channels are at 0 unless triggered by a programmed PB? For example, I have PB 1-3 recorded as Red, Green, or Blue for a set of LED pars. I have recorded just a single colour parameter (R, G,or B ) and intensity of the fixture to the PB and set the fader to allow for colour control. If i then select all of the fixtures, and bring manually bring down the RGB levels to 0 using the touch screen, I can mix RGB using the PB's. However as soon as a fader hits 0 (<5%) the colour assigned to that playback with defaults to 100. I understand that recording the colour values at 0, and the intensity at 100 to a UDK allows me to work around this, but why is this step necesary? Why do the colour parameters default to 100%? Sorry if this is a daft question. From exhaustive googling, i realise this seems to be t he only way to achieve this, but my mind keeps asking why... Kind Regards Olly Quote
Erics Posted May 22, 2019 Report Posted May 22, 2019 Hi Olly, I think that depends on the default fixtures values. In the normal fixture profiles it is programmend that all RGB Values are @ 100%. So when you select a fixture with a fader it will light up white when you moves the fader up. So the normal oparator do not have to select a color when he wants only light on stage. I don't like this behaver, so it is good that i can change the default values on the FLX S desks with ZerOs 7.9.5 now. Quote I use: Zero 88 FLX S48 / Chamsys MQ70 / Madrix / mostly Astera Lights
O Thompson Posted May 22, 2019 Report Posted May 22, 2019 That makes a lot of sense. I hadn't considered the fixture profile default settings. You suggest that these values can be changed? how would you do this? With the 7.9.5 OS, i have discovered that i can remove the "release" option when a fader is at 0. This prevents the default 100 values returning when the fader is down, however i still need to use a UDK to bring down the RGB values on startup or after programming a PB. Thanks for your reply Erics Quote
Edward Z88 Posted May 23, 2019 Report Posted May 23, 2019 Hello, As Eric says, this is due to the fixture defaults for RGB fixtures having Red, Green and Blue at full, to give white. For information on how to change this to achieve colour mixing, you can use the guide below... http://support.zero88.com/975070091 This guide is for our Solution and ORB consoles, but you'll be able to use the same process. For more information on configuring fixture Defaults, see the article below... http://support.zero88.com/1011707631 Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Antti Posted March 9, 2021 Report Posted March 9, 2021 I'm looking for a solution for this exact problem, but all the links in this thread are not working for some reason. Are those contents deleted or moved to another location? Antti Quote
Edward Z88 Posted March 9, 2021 Report Posted March 9, 2021 Hi Antti, Welcome to the Zero 88 Forum. 1 hour ago, Antti said: I'm looking for a solution for this exact problem, but all the links in this thread are not working for some reason. Are those contents deleted or moved to another location? Antti For information on how to do this, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playing-back-cues/rgb-colour-mixing-on-playbacks Those old links pointed to our support.zero88.com site, which has now been retired. All information for ZerOS consoles now lives in the relevant sections of the online manual... https://zero88.com/manuals/zeros Hope this helps, if you have any questions let me know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
Antti Posted March 10, 2021 Report Posted March 10, 2021 15 hours ago, Edward- Z88 said: Hi Antti, Welcome to the Zero 88 Forum. For information on how to do this, see the link below... https://zero88.com/manuals/zeros/cues-playbacks/playing-back-cues/rgb-colour-mixing-on-playbacks Those old links pointed to our support.zero88.com site, which has now been retired. All information for ZerOS consoles now lives in the relevant sections of the online manual... https://zero88.com/manuals/zeros Hope this helps, if you have any questions let me know. Edward Thanks Edward! I found the solution independently. Is there a reason for removing the possibility to edit these values in the setup? Key combos are quick to use, but not always the most easiest to figure out. Quote
Edward Z88 Posted March 10, 2021 Report Posted March 10, 2021 Hi Antti, 17 minutes ago, Antti said: Is there a reason for removing the possibility to edit these values in the setup? Key combos are quick to use, but not always the most easiest to figure out. I assume this is regarding changing a fixture's defaults or home values, which used to be done inside Setup? The ability to record a fixtures defaults and home values just like another lighting state, allows you to use the standard Record, Update or Delete commands. Worth mentioning you don't need to edit a fixture's defaults to use the RGB colour mixing method in my previous post. For more information on fixture defaults, see the link below... https://zero88.com/manuals/zeros/controlling-fixtures/defaults Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
