I am trying to update the fixture library on my TLXtra from 36 to 38. The new library starts loading normally but just before completion 90%  it fails with error code 108. Thoughts please?
This desk has always been a nightmare to update!
I cleared the user files.
I tried to load the blank file and got a wrong file type error.
I am still getting the Failed 108 message at 95%
Just to confirm I am loading gft38_ft.ift  I once managed to pick up a rogue file from the website at one point in the past.
Hi Terry,
If you are currently running fixture library v36, you'll need to load in the "BlankLib.ift" library file before loading in gft38.
Once you have downloaded the blank library file from the article, are you extracting the file to the root of a USB stick?
If you are simply copying it, it won't have been unzipped, and therefore the Jester won't be able to read it.
Let me know how you get on.
Ok I solved it! I needed to do the OS upgrade from 4.0 to 4.1 first. The blank file then loaded and then the new library.
Thanks for the info about the blank file.
Thanks Edward
  • 5 years later...
Hi,
I have bought a pair of 19x15 LED Moving heads from Amazon 2Pcs 19 LED 285W Wash Zoom Moving Head, RGBW 4 in 1 Professional Focus Dye Stage Light with Light Strip and 4 Control Modes for Party KTV Concert Music Festival Christmas Wedding Celebrations : Amazon.co.uk: Musical Instruments & DJ and I have created a fixture for it using the Zero88 software but my Jester 24 ML is not recognising the file type when I attempt to update the library. Any suggestions?
Thanks,
Tim
Did you use Fixture Tools 2.6 and save an ift file?
It should just work…
Can you elaborate more on what you did? Maybe upload your fixture file here and we can take a look.
I see you started a new thread - maybe we can continue on that (but please avoid double-posting, you won’t get help any quicker…).
Thanks for the reply. I started the new thread when I noticed how old the previous one was - I'm delighted you are here.
I have attached the 2 files I created using the software on this link (2.6): https://vari-lite.s3.eu-west-1.amazonaws.com/software-firmware/zero-88-fixture-tools-2.6.zip
It is very possible I set one of the parameters incorrectly - I am not (by any means) a lighting expert.
I have also attached the channel descriptors for the light in case you are able to spot any errors - assuming you are happy to give the time.
Thanks again,
Tim
LeLight LED Moving 17ch.ift LeLight LED Moving 25ch.ift
A JOS file is likely to be a showfile.
A fixture personality file is an IFT file so it may be they way you're trying to load the IFT file? Found this from Ed on another forum...
The <Update Library> option in Super User can be used to update the fixture library on the console. If you just wish to load in a fixture file, not a whole library, please see page 49 of the Jester TL manual for information on assigning fixtures… https://www.zero88.com/storage/downloads/5ebda1d3-7348-4727-ae31-fecedf299a46/Jester-TL-and-TLXtra-Manual-3.0.pdf#page=49
  • Like 2
Hi @Tim Molyneux, the above post should definitely solve your problem (thank you @mikeb) as you are trying to load in a fixture personality file in the way of loading a fixture library file onto the desk. Using 'Assign Fixtures' -> USB as described in the manual above will work.
11 hours ago, Tim Molyneux said:
I wonder if it should be a JOS file?
Regarding this, I thought I'd just chip in and mention about file formats for future reference:
  • JOS files are the file format for the Jester operating system when updating the console's OS.
  • JSF files are showfiles for Jesters in the 12/24 and 24/48 range.
  • JML files are showfiles for Jesters in the ML range, TL and TLextra range.
I hope this is of use for the future for file format knowledge.
Edit: To add, I have attempted to upload the IFT file provided above on my own JesterML console using the method in the manual via 'Assign Fixtures' and it does load in correctly.
  • Like 1
Archie - Student
Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Juggler (x3), Level 6, Level 6 DMX, Level 12, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, Linebacker, Demux 48 (x2)
Thanks everyone for you support - I'm delighted to say the file has loaded correctly using 'assign fixtures' from USB as you advised. Your time and help are really appreciated.
One last query - will the file be stored in the console library for future use now that it is in the desk?
Thanks,
Tim
Hi @Tim Molyneux, I'm glad the above solution worked for you.
Indeed. You can use 'User File' instead of selecting 'USB' on the MFKs, which allows you to recall fixture profiles from a file previously loading in to the console via USB.
At any time if you wish to delete these files from the internal console memory, you can do so by navigating to the <Update Fixture Lib> menu within setup.
From there, you can select <Delete User Files>. Use the arrow keys to navigate which file you would like to delete from the internal console memory.
Hope this helps!
Archie - Student
